Re: [mpich-discuss] Error building mpich-3.1.2 on Solaris 10 withgcc-4.9.0
Hi Ken,
I was able to reproduce the issue on my machine. Libtool seems to not be able to handle the rpath value specified in LDFLAGS in combination with its own rpath setting. Modifying your configure time LDFLAGS like this should allow you to complete the build:
LDFLAGS=-m64 -L/usr/lib/amd64 -Wl,-rpath -Wl,/usr/lib/amd64
Yes, I was able to build mpich-master-v3.2a1-5-gb293734d on Solaris Sparc and x86_64 with gcc-4.9.0, when I use LDFLAGS="-m64 -L/usr/lib/sparcv9 -Wl,-rpath -Wl,/usr/lib/sparcv9" and LDFLAGS="-m64 -L/usr/lib/amd64 -Wl,-rpath -Wl,/usr/lib/amd64". Thank you very much for your help. Kind regards Siegmar
I'm going to keep investigating, though, why this only appears in this specific configuration.
Ken
On 09/07/2014 03:58 PM, Siegmar Gross wrote:
Thanks, Siegmar. Are you seeing some errors with â?omake t testingâ?àor are all tests failing? On some platforms, s some tests take longer and hence show up as â?otimeoutsâ?ÃÂ, but they are not really hanging. But the number of such tests should be small.
I see some bus errors on Solaris 10 Sparc. I attached the log files for both Solaris 10 Sparc and x86_64, so that you can see yourself the results.
Kind regards
Siegmar
Can you send the output of:
gcc -v g++ -v gfortran -v
Just want to double check the build configuration so I can match it on my test setup.
Solaris 10 x86_64: ==================
sunpc1 root 2 gcc -v Using built-in specs. COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/export2/prog/SunOS_x86_64/gcc-4.9.0/bin/../libexec/gcc/i386 -pc-solaris2.10/4.9.0/lto-wrapper
Target: i386-pc-solaris2.10 Configured with: ../gcc-4.9.0/configure --prefix=/usr/local/gcc-4.9.0 --with-gmp=/usr/local --with-mpfr=/usr/local --with-mpc=/usr/local --with-isl=/usr/local --with-cloog=/usr/local --without-gnu-ld --with-ld=/usr/ccs/bin/ld ABI=32 --enable-languages=c,c++,objc,obj-c++,fortran --disable-nls --enable-threads=posix --disable-libgcj --with-system-zlib --enable-shared --enable-bootstrap Thread model: posix gcc version 4.9.0 (GCC)
sunpc1 root 3 g++ -v Using built-in specs. COLLECT_GCC=g++
sunpc1 root 4 gfortran -v Using built-in specs. COLLECT_GCC=gfortran
Target: i386-pc-solaris2.10 Configured with: ../gcc-4.9.0/configure --prefix=/usr/local/gcc-4.9.0 --with-gmp=/usr/local --with-mpfr=/usr/local --with-mpc=/usr/local --with-isl=/usr/local --with-cloog=/usr/local --without-gnu-ld --with-ld=/usr/ccs/bin/ld ABI=32 --enable-languages=c,c++,objc,obj-c++,fortran --disable-nls --enable-threads=posix --disable-libgcj --with-system-zlib --enable-shared --enable-bootstrap Thread model: posix gcc version 4.9.0 (GCC) sunpc1 root 5
Solaris 10 Sparc: =================
tyr root 2 gcc -v Using built-in specs. COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/export2/prog/SunOS_sparc/gcc-4.9.0/bin/../libexec/gcc/sparc -sun-solaris2.10/4.9.0/lto-wrapper
Target: sparc-sun-solaris2.10 Configured with: ../gcc-4.9.0/configure --prefix=/usr/local/gcc-4.9.0 --with-gnu-as --with-as=/usr/local/bin/as --without-gnu-ld --with-ld=/usr/ccs/bin/ld --enable-nls --with-system-zlib --enable-languages=c,c++,objc,fortran,java --enable-java-gc=boehm --enable-multilib --disable-libgcj --enable-bootstrap Thread model: posix gcc version 4.9.0 (GCC)
tyr root 3 g++ -v Using built-in specs. COLLECT_GCC=g++
tyr root 4 gfortran -v Using built-in specs. COLLECT_GCC=gfortran
Target: sparc-sun-solaris2.10 Configured with: ../gcc-4.9.0/configure --prefix=/usr/local/gcc-4.9.0 --with-gnu-as --with-as=/usr/local/bin/as --without-gnu-ld --with-ld=/usr/ccs/bin/ld --enable-nls --with-system-zlib --enable-languages=c,c++,objc,fortran,java --enable-java-gc=boehm --enable-multilib --disable-libgcj --enable-bootstrap Thread model: posix gcc version 4.9.0 (GCC) tyr root 5
Kind regards
Siegmar
participants (1)
Siegmar Gross
