Re: [mpich-discuss] mpich hangs in MPI_Send() - multi threaded environment
After reviewing Nenad's code, it looks like this was indeed the issue — the code was assuming that the send would complete before the receive is called. That's obviously an incorrect code, not an issue with MPICH. Bsend could help, but it has other problems. Most importantly, the buffer attach is not communicator-safe. So if another library is using Bsends as well, it might use up your buffer space, and you'll be back in this deadlock mode. A better approach is to not make this assumption if possible. If you are sending to yourself, can you use MPI_Sendrecv instead? Or prepost the receive before calling the send? -- Pavan From: Nenad Vukicevic Reply-To: "[email protected]<mailto:[email protected]>" Date: Monday, July 20, 2015 at 3:41 PM To: Jeff Hammond, "[email protected]<mailto:[email protected]>" Cc: Gary Funck Subject: Re: [mpich-discuss] mpich hangs in MPI_Send() - multi threaded environment Yes. Send did not have a matching tag receive as thread was waiting for something else. Switching to Bsend should help? On 7/17/2015 9:03 PM, Jeff Hammond wrote: Blocking Send to self will hang if Irecv not pre-posted. You doing that? Jeff On Friday, July 17, 2015, Nenad Vukicevic <<mailto:[email protected]>[email protected]<mailto:[email protected]>> wrote: I will via separate mail. But, I see that I made a mistake in my description as pthread does MPI_Send () to itself and not to another rank. I'll try reversing the order (send to others then to yourself). On 7/17/2015 4:26 PM, Balaji, Pavan wrote: You should not need to pass any additional configuration options. MPICH is thread-safe by default. Can you send us a simple program that reproduces the error? -- Pavan On 7/17/15, 6:16 PM, "Nenad Vukicevic" <[email protected]<mailto:[email protected]>> wrote: I am having a problem where the system locks up inside the MPI_Send() routine. In my test, each MPI rank has an additional pthread and system locks up when: - main thread does MPI_Recv from ANY rank - pthread does MPI_Send to another rank I verified with MPI_Init_thread() that I can run MPI_THREAD_MULTIPLE environment. The same thing happened on MPICH with Fedora 20 (3.0.4) and the one build from 3.2b3 sources. When building from sources I provided '--enable-threads=multiple' option. I also tried to play with '--enable-thread-cs' option but got build failure when 'per-object' was selected. Is this supposed to work? Thanks, Nenad I am attaching traces form GDB for the rank that locks up. (gdb) info thread Id Target Id Frame 2 Thread 0x7ffff6a5a700 (LWP 29570) "barrier_test" 0x0000003ef040bca0 in pthread_cond_wait@@GLIBC_2.3.2<mailto:pthread_cond_wait@@GLIBC_2.3.2> () from /usr/lib64/libpthread.so.0 * 1 Thread 0x7ffff7a64b80 (LWP 29568) "barrier_test" 0x00007ffff7c58717 in MPIU_Thread_CS_yield_lockname_recursive_impl_ ( lockname=0x7ffff7cdc8b1 "global_mutex", mutex=<optimized out>, kind=MPIU_Nest_global_mutex) at ../src/src/include/mpiimplthreadpost.h:190 (gdb) where #0 0x00007ffff7c58717 in MPIU_Thread_CS_yield_lockname_recursive_impl_ (lockname=0x7ffff7cdc8b1 "global_mutex", mutex=<optimized out>, kind=MPIU_Nest_global_mutex) at ../src/src/include/mpiimplthreadpost.h:190 #1 0x00007ffff7c5db42 in MPIDI_CH3I_Progress (progress_state=progress_state@entry=0x7fffffffd2c0, is_blocking=is_blocking@entry=1) at ../src/src/mpid/ch3/channels/nemesis/src/ch3_progress.c:507 #2 0x00007ffff7b5e795 in PMPI_Recv (buf=0x7fffffffd61c, count=1, datatype=1275069445, source=-2, tag=299, comm=1140850688, status=0x7fffffffd620) at ../src/src/mpi/pt2pt/recv.c:157 #3 0x0000000000401732 in receive_int () at comm.c:52 #4 0x0000000000400bf2 in main (argc=1, argv=0x7fffffffd758) at barrier_test.c:39 (gdb) thread 2 [Switching to thread 2 (Thread 0x7ffff6a5a700 (LWP 29570))] #0 0x0000003ef040bca0 in pthread_cond_wait@@GLIBC_2.3.2<mailto:pthread_cond_wait@@GLIBC_2.3.2> () from /usr/lib64/libpthread.so.0 (gdb) where #0 0x0000003ef040bca0 in pthread_cond_wait@@GLIBC_2.3.2<mailto:pthread_cond_wait@@GLIBC_2.3.2> () from /usr/lib64/libpthread.so.0 #1 0x00007ffff7c5d614 in MPIDI_CH3I_Progress_delay (completion_count=<optimized out>) at ../src/src/mpid/ch3/channels/nemesis/src/ch3_progress.c:566 #2 MPIDI_CH3I_Progress (progress_state=progress_state@entry=0x7ffff6a59710, is_blocking=is_blocking@entry=1) at ../src/src/mpid/ch3/channels/nemesis/src/ch3_progress.c:347 #3 0x00007ffff7b632ec in PMPI_Send (buf=0x7ffff6a5985c, count=1, datatype=1275069445, dest=0, tag=199, comm=1140850688) at ../src/src/mpi/pt2pt/send.c:145 #4 0x0000000000400e42 in barrier_thread_release (id=0) at barrier.c:115 #5 0x0000000000401098 in barrier_helper (arg=0x0) at barrier.c:186 #6 0x0000003ef0407ee5 in start_thread () from /usr/lib64/libpthread.so.0 #7 0x0000003eef8f4d1d in clone () from /usr/lib64/libc.so.6 _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
