Re: [mpich-discuss] A problem in running mpi code on ubuntu 13.10
I still have the problem with mpi On Mon, Jan 27, 2014 at 4:47 PM, ehsan saei <[email protected]> wrote:
which mpicxx returns: /usr/bin/mpicxx
On Mon, Jan 27, 2014 at 4:44 PM, Reuti <[email protected]> wrote:
Am 27.01.2014 um 16:41 schrieb ehsan saei:
I compile the code with: mpicxx main.cpp and run it with: mpiexec -n 8 ./a.out
Does `which mpicxx` resp. `which mpiexec` point to the intended target?
-- Reuti
I use a single computer with dual core core i3
On Mon, Jan 27, 2014 at 4:39 PM, Wesley Bland <[email protected]> wrote: The code is fine. The problem is most likely either the way you're executing your code or the way you installed it. Can you tell us how you executed in on the command line to start?
Thanks, Wesley
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
ehsan saei
