Re: [mpich-discuss] code from different version of LINUX
You can copy MPI libraries installed on the Ubuntu machine to the Suse machine, then add that path to LD_LIBRARY_PATH on the Suse. --Junchao Zhang On Wed, Nov 26, 2014 at 9:55 AM, Shuchi Yang <[email protected]> wrote:
I met some problem. The question is that I compile a fortran code at ubuntu, but I need run the code at Suse Linux, I was always told * error while loading shared libraries: libmpifort.so.12: cannot open shared object file: No such file or directory*
Furthermore, will this be a problem, I mean, if I compile the code with mpich-gcc and run the code at another type of Linux?
Shuchi
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Junchao Zhang
