Re: [mpich-discuss] Implementation of MPICH collectives
Hm, I have set that variable and then I have stepped through a program that calls MPI_Bcast (using mpiexec -n 2 <program> on a single node). The MPI_Bcast still seems to use memcpy() while I would expect it to use the sockets interface. Is the memcpy() to be expected? --Jiri On Fri, Sep 13, 2013 at 10:25 AM, Pavan Balaji <[email protected]> wrote:
Yes, you can set the environment variable MPIR_PARAM_CH3_NOLOCAL=1.
-- Pavan
On Sep 13, 2013, at 7:53 AM, Jiri Simsa wrote:
Pavan,
Thank you for your answer. That's precisely what I was looking for. Any chance there is a way to force the intranode communication to use tcp?
--Jiri
Within the node, it uses shared memory. Outside the node, it depends on the netmod you configured with. tcp is the default netmod. -- Pavan On Sep 12, 2013, at 2:24 PM, Jiri Simsa wrote:
The high-order bit of my question is: What OS interface(s) does MPICH use to transfer data from one MPI process to another?
On Thu, Sep 12, 2013 at 1:36 PM, Jiri Simsa <[email protected]> wrote: Hello,
I have been trying to understand how MPICH implements collective operations. To do so, I have been reading the MPICH source code and stepping through mpiexec executions.
For the sake of this discussion, let's assume that all MPI processes are executed on the same computer using: mpiexec -n <n> <mpi_program>
This is my current abstract understanding of MPICH:
- mpiexec spawns a hydra_pmi_proxy process, which in turn spawns <n> instances of <mpi_program> - hydra_pmi_proxy process uses socket pairs to communicate with the instances of <mpi_program>
I am not quite sure though what happens under the hoods when a collective operation, such as MPI_Allreduce, is executed. I have noticed that instances of <mpi_program> create and listen on a socket in the course of executing MPI_Allreduce but I am not sure who connects to these sockets. Any chance someone could describe the data flow inside of MPICH when a collective operation, such as MPI_Allreduce, is executed? Thanks!
Best,
--Jiri Simsa
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss -- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Jiri Simsa
