Re: [mpich-discuss] Building MPE for use with OpenMPI
Hi Jeff, Thanks. Unfortunately, that is basically the same source code from ftp://ftp.mcs.anl.gov/pub/mpi/mpe/mpe2.tar.gz where I had the issues with the conflicting declarations as Pavan talked about. I could remove the deprecated routines as most of the problems are caused by them, but it looks like some non-deprecated routines also have the const issue, e.g. visual_mess.c:560: error: conflicting types for 'MPI_Issend' /u/hschilli/local/include/mpi.h:1543: error: previous declaration of 'MPI_Issend' was here BTW, that repo for MPE doesn't appear to have a configure file. I know I could create it with autogen.sh but the INSTALL file doesn't say that. It just says run configure. Might be confusing for some people, I think! Thanks for everyone's help On Dec 1, 2015, at 2:03 PM, Jeff Hammond <[email protected]<mailto:[email protected]>> wrote: MPE lives here now: http://git.mpich.org/mpe.git/ Jeff On Tue, Dec 1, 2015 at 10:15 AM, Schilling, Herbert W. (GRC-VE00) <[email protected]<mailto:[email protected]>> wrote: Hi Jeff, Thanks. Pardon my ignorance but I I wanted to just use MPE with an existing OpenMPI installation and it's not clear to me ( even after searching and reading ), how to do that from the full MPICH code base at that repo. I can't really even find MPE in that code at all. What am I missing? Thanks On Dec 1, 2015, at 10:03 AM, Jeff Hammond <[email protected]<mailto:[email protected]>> wrote: Herbert: Please try https://github.com/jeffhammond/mpich/tree/hammond-mpi2-deprecated-functions-... and let me know if you see any problems. Best, Jeff On Tue, Dec 1, 2015 at 5:46 AM, Schilling, Herbert W. (GRC-VE00) <[email protected]<mailto:[email protected]>> wrote: Hi Jeff and Pavan, Thanks for all the help on this. Jeff, when you have the fix up there, I can give it a shot! On Dec 1, 2015, at 1:15 AM, Jeff Hammond <[email protected]<mailto:[email protected]>> wrote: Facepalm. Indeed, changing the header but not the implementation was pretty dumb on my part. I'll fix that tomorrow. I have no opinion on the ABI situation, particularly since I know there are other folks that Intel that do. Jeff On Mon, Nov 30, 2015 at 9:00 PM, Balaji, Pavan <[email protected]<mailto:[email protected]>> wrote: Thanks, Jeff. The actual function definitions should be modified as well, which your patch seems to miss. But I think the potentially time consuming part is to get buy-in from all the ABI consortium folks for this change. It doesn't exactly break ABI for applications, but will be an annoying change for tools. Ken is looking into this. -- Pavan
On Nov 30, 2015, at 10:54 PM, Jeff Hammond <[email protected]<mailto:[email protected]>> wrote:
Pavan:
See hammond-mpi2-deprecated-functions-noconst branch on mpich-review. I found three functions where this change should be made. I do not know if that is the full list, so someone should verify.
Best,
Jeff
On Mon, Nov 30, 2015 at 8:08 PM, Balaji, Pavan <[email protected]<mailto:[email protected]>> wrote:
MPI_Type_struct is not a part of the MPI standard anymore and is replaced by MPI_Type_create_struct. Both MPICH and Open MPI decided to retain it, but followed different directions for it. MPICH decided to follow the same convention as MPI_Type_create_struct with the const additions. Open MPI decided to keep the old prototypes as is.
Unfortunately, MPE got stuck in between the two. The best approach would be to simply remove those functions from MPE and this problem just goes away. Would you be able to do that and contribute a patch?
More generally, I think MPICH was overzealous in trying to constify prototypes for the deleted functions. It should have just left them as they are, like what Open MPI did. We'll figure out what to do about that internally, but that's not going to be a quick change because of ABI and other such stuff.
-- Pavan
On Nov 30, 2015, at 8:14 PM, Schilling, Herbert W. (GRC-VE00) <[email protected]<mailto:[email protected]>> wrote:
I am trying to build MPE for use with OpenMPI. I built from source Version 1.10.1 of OpenMPI.
I am using this version of MPE ftp://ftp.mcs.anl.gov/pub/mpi/mpe/mpe2.tar.gz
Should this work fine? I followed the instructions to build like this:
${MPE_SRC_DIR}/configure MPI_CC=${OPENMPI_INSTALL_DIR}/bin/mpicc \ CC=<C_COMPILER_used_to_build_OpenMPI> \ MPI_F77=${OPENMPI_INSTALL_DIR}/bin/mpif77 \ F77=<FORTRAN_COMPILER_used_to_build_OpenMPI> \ --with-java2=/usr/local/j2sdk-1.4.2 --prefix=<MPE_INSTALL_DIR> make make install
I keep running into problems with conflicting declarations
log_mpi_core.c:5611: error: conflicting types for 'MPI_Type_struct' /u/hschilli/local/include/mpi.h:1796: error: previous declaration of 'MPI_Type_struct' was here
I think the issue is that MPE's declaration uses some const qualifiers while OpenMPI does not.
I tried hacking my way through this with the macro
HAVE_CONST_IN_MPI_DECL and MPE_CONST but no luck so far.
What am I doing wrong?
Thanks in advance.
--------- Herb Schilling Scientific Applications and Visualization Team http://ocio.grc.nasa.gov/gvis Office of the Chief Information Officer NASA Glenn Research Center [email protected]<mailto:[email protected]>
_______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss --------- Herb Schilling Scientific Applications and Visualization Team http://ocio.grc.nasa.gov/gvis Office of the Chief Information Officer NASA Glenn Research Center [email protected]<mailto:[email protected]> _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss --------- Herb Schilling Scientific Applications and Visualization Team http://ocio.grc.nasa.gov/gvis Office of the Chief Information Officer NASA Glenn Research Center [email protected]<mailto:[email protected]> _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected]<mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss --------- Herb Schilling Scientific Applications and Visualization Team http://ocio.grc.nasa.gov/gvis Office of the Chief Information Officer NASA Glenn Research Center [email protected]<mailto:[email protected]> _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
