Re: [mpich-discuss] MPICH 3.2 on BlueGene/Q
Dear Rob, I have built your fork of mpich on bg-q and I see below error while testing simple example of MPI_File_iwrite_all: ○ → srun -n 2 ./nonblock_io Abort(1) on node 0: 'MPI_IN_PLACE' requries support for `PAMI_IN_PLACE` Abort(1) on node 1: 'MPI_IN_PLACE' requries support for `PAMI_IN_PLACE` 2016-02-25 21:45:18.183 (WARN ) [0xfffacbf8f50] 424617:ibm.runjob.client.Job: normal termination with status 1 from rank 0 I have compiled the mpich as: ./configure --enable-threads=multiple --host=powerpc64-bgq-linux --with-device=pamid --prefix=$INSTALL_PREFIX --with-file-system=gpfs:BGQ --with-bgq-install-dir=/bgsys/drivers/V1R2M0/ppc64 --with-pami=/bgsys/drivers/V1R2M0/ppc64/comm/sys --with-pami-include=/bgsys/drivers/V1R2M0/ppc64/comm/sys/include --with-pami-lib=/bgsys/drivers/V1R2M0/ppc64/comm/sys/lib --enable-fast=nochkmsg,notiming,O3 --with-assert-level=0 --disable-error-messages --disable-debuginfo MPICHLIB_CXXFLAGS="-qhot -qinline=800 -qflag=i:i -qsaveopt -qsuppress=1506-236" MPICHLIB_CFLAGS="${MPICHLIB_CXXFLAGS}" MPICHLIB_FFLAGS="${MPICHLIB_CXXFLAGS}" MPICHLIB_F90FLAGS="${MPICHLIB_CXXFLAGS}" make -j12 make install Let me know if I have missing anything. -Pramod On Thu, Feb 25, 2016 at 8:04 PM, pramod kumbhar <[email protected]> wrote:
Dear All,
I came across below thread in the archives about mpich 3.2 on BG-Q.
I am testing non-blocking collectives, i/o functions on cluster and would like to do the same on BG-Q. I have following questions:
1. Last email from Dominic suggest that last "compilable" version doesn't support async progress. Is there any version that has non-blocking support and compiles on bg-q? (the fork from Rob?)
2. Do I have to consider anything specific on bg-q while benchmarking non-blocking functions (from mpi-3) ?
Thanks in advance!
Pramod
p.s. I am copying the email thread from archive, not sure if this will be delivered to the correct thread...
Hi All,
Here is an update:
MPICH 3.1.3 is the last version that passed the nonblocking test, even without setting PAMID_THREAD_MULTIPLE. However, setting PAMID_ASYNC_PROGRESS=1 will cause error.(Abort(1) on node 7: 'locking' async progress not applicable...)
[chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> coll.bak]$ which mpif90 ~/apps/mpich/3.1.3/bin/mpif90 [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> coll.bak]$ make nonblocking CC nonblocking.o CCLD nonblocking [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> coll.bak]$ srun -n 2 ./nonblocking No errors [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> coll.bak]$ srun -n 4 ./nonblocking No errors [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> coll.bak]$ srun -n 16 ./nonblocking No errors
Thanks all!
Regards, Dominic
On 11 Jan, 2016, at 2:29 pm, Dominic Chien <chiensh.acrc at gmail.com <https://lists.mpich.org/mailman/listinfo/discuss>> wrote:
* Thank you Jeff and Halim, *> >* Halim, I have tried 3.1.4 but it does not return 0 (error) when the program is finished, e.g. for a helloworld program *>* ================================================================== *>* program hello *>* include 'mpif.h' *>* integer rank, size, ierror, tag, status(MPI_STATUS_SIZE) *> >* call MPI_INIT(ierror) *>* call MPI_COMM_SIZE(MPI_COMM_WORLD, size, ierror) *>* call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierror) *>* print*, 'node', rank, ': Hello world' *>* call MPI_FINALIZE(ierror) *>* end *>* ================================================================== *> >* Using MPI 3.1.rc4 *>* ================================================================== *>* [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> test]$ which mpif90 *>* ~/apps/mpich/3.1.rc4/bin/mpif90 *>* [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> test]$ srun -n 2 ./a.out *>* node 1 : Hello world *>* node 0 : Hello world *>* [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> test]$ *>* ================================================================== *>* Using MPI 3.1.4 *>* ================================================================== *>* [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> test]$ which mpif90 *>* ~/apps/mpich/3.1.4/bin/mpif90 *>* [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> test]$ srun -n 2 ./a.out *>* node 1 : Hello world *>* node 0 : Hello world *>* 2016-01-11 14:24:25.968 (WARN ) [0xfff7ef48b10] 75532:ibm.runjob.client.Job: terminated by signal 11 *>* 2016-01-11 14:24:25.968 (WARN ) [0xfff7ef48b10] 75532:ibm.runjob.client.Job: abnormal termination by signal 11 from rank 1 *>* ================================================================== *> > >* Jeff, after I set PAMID_THREAD_MULTIPLE=1 and PAMID_ASYNC_PROGRESS=1, it seems to have some "improvement": nonblocking test can run for up to 4 processes sometime, but sometime it just get a "deadlock", (see below) *>* ========================================================== *>* [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> coll.bak]$ srun --nodes=4 --ntasks-per-node=1 nonblocking *>* MPIDI_Process.* *>* verbose : 2 *>* statistics : 1 *>* contexts : 32 *>* async_progress : 1 *>* context_post : 1 *>* pt2pt.limits *>* application *>* eager *>* remote, local : 4097, 4097 *>* short *>* remote, local : 113, 113 *>* internal *>* eager *>* remote, local : 4097, 4097 *>* short *>* remote, local : 113, 113 *>* rma_pending : 1000 *>* shmem_pt2pt : 1 *>* disable_internal_eager_scale : 524288 *>* optimized.collectives : 0 *>* optimized.select_colls: 2 *>* optimized.subcomms : 1 *>* optimized.memory : 0 *>* optimized.num_requests: 1 *>* mpir_nbc : 1 *>* numTasks : 4 *>* mpi thread level : 'MPI_THREAD_SINGLE' *>* MPIU_THREAD_GRANULARITY : 'per object' *>* ASSERT_LEVEL : 0 *>* MPICH_LIBDIR : not defined *>* The following MPICH_* environment variables were specified: *>* The following PAMID_* environment variables were specified: *>* PAMID_STATISTICS=1 *>* PAMID_ASYNC_PROGRESS=1 *>* PAMID_THREAD_MULTIPLE=1 *>* PAMID_VERBOSE=2 *>* The following PAMI_* environment variables were specified: *>* The following COMMAGENT_* environment variables were specified: *>* The following MUSPI_* environment variables were specified: *>* The following BG_* environment variables were specified: *>* No errors *>* ========================================================== *>* [chiensh at cumulus <https://lists.mpich.org/mailman/listinfo/discuss> coll.bak]$ srun --nodes=4 --ntasks-per-node=1 nonblocking *>* MPIDI_Process.* *>* verbose : 2 *>* statistics : 1 *>* contexts : 32 *>* async_progress : 1 *>* context_post : 1 *>* pt2pt.limits *>* application *>* eager *>* remote, local : 4097, 4097 *>* short *>* remote, local : 113, 113 *>* internal *>* eager *>* remote, local : 4097, 4097 *>* short *>* remote, local : 113, 113 *>* rma_pending : 1000 *>* shmem_pt2pt : 1 *>* disable_internal_eager_scale : 524288 *>* optimized.collectives : 0 *>* optimized.select_colls: 2 *>* optimized.subcomms : 1 *>* optimized.memory : 0 *>* optimized.num_requests: 1 *>* mpir_nbc : 1 *>* numTasks : 4 *>* mpi thread level : 'MPI_THREAD_SINGLE' *>* MPIU_THREAD_GRANULARITY : 'per object' *>* ASSERT_LEVEL : 0 *>* MPICH_LIBDIR : not defined *>* The following MPICH_* environment variables were specified: *>* The following PAMID_* environment variables were specified: *>* PAMID_STATISTICS=1 *>* PAMID_ASYNC_PROGRESS=1 *>* PAMID_THREAD_MULTIPLE=1 *>* PAMID_VERBOSE=2 *>* The following PAMI_* environment variables were specified: *>* The following COMMAGENT_* environment variables were specified: *>* The following MUSPI_* environment variables were specified: *>* The following BG_* environment variables were specified: *>* (never return from here) *>* ========================================================== *> >* Thanks! *> >* Regards, *>* Dominic *> > >* On 11 Jan, 2016, at 12:08 pm, Halim Amer <aamer at anl.gov <https://lists.mpich.org/mailman/listinfo/discuss>> wrote: *> >>* Dominic, *>> >>* There were a bunch of fixes that went to PAMID since v3.1rc4. You could try a release from the 3.1 series (i.e. from 3.1 through 3.1.4). *>> >>* Regards, *>>* --Halim *>> >>* www.mcs.anl.gov/~aamer <http://www.mcs.anl.gov/~aamer> *>* On 11 Jan, 2016, at 11:30 am, Jeff Hammond <jeff.science at gmail.com <https://lists.mpich.org/mailman/listinfo/discuss>> wrote: *>>* I recall MPI-3 RMA on BGQ deadlocks if you set PAMID_THREAD_MULTIPLE (please see ALCF MPI docs to verify exact name), which is required for async progress. *>> >>* ARMCI-MPI test suite is one good way to validate MPI-3 RMA is working. *>> >>* Jeff *>
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
pramod kumbhar
