If you run mpiexec -f hosts -n 40 ldd pw.x do all instances show correct linkage? On 12/3/18 11:36 PM, Haider Abbas via discuss wrote:
Dear all,
I have prepared a 10 node cluster (each having 4 core). I have installed GAMESS and QUANTUM ESPRESSO. Gamess is running fine, but when I run quantum espresso with the command
mpiexec -n 4 ./pw.x -i relax2.in <http://relax2.in> > out.out &
I get no error and everything is fine. And the job run on all 4 core a single node.
But when I run the same job on the 10 node with the command
mpiexec -f hosts -n 40 ./pw.x -i relax2.in <http://relax2.in> > out.out &
I get the error
mpiuser@master:~/qe-29-11/bin$ ./pw.x: error while loading shared libraries: liblapack.so.3: cannot open shared object file: No such file or directory
However, I have "liblapack.so.3" in the same directory from where I am running the job.
I sought your help. Thanking in advance. with regards
Haider Abbas
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Raffenetti, Kenneth J.
