Re: [mpich-discuss] mpich issues when configuring
It appears that the configure script is discovering a version of icc in your path, but it is unable to compile with it. Your system may not be configured to use it. I would suggest trying different compilers if you have them available. I.e. add "CC=gcc CXX=g++ FC=gfortran" to your configure line. Ken On 08/21/2015 12:37 PM, Jie Ren wrote:
I met a problem when I was configuring the mpich on my linux machine as below. I also attached the package of c.txt, config.log(the main one, openpa one and mpl one, looks like I don't have the other two config.log files when I got the errors).
Jie
configure: error: in `/data/Research/Task 17 SU2 Study/mpich-3.1.1/src/openpa': configure: error: C compiler cannot create executables See `config.log' for more details configure: error: OpenPA configure failed
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
