Re: [mpich-discuss] Problems running MPICH jobs under SLURM
Hi Pavan,
Markus: does this happen only with SLURM or can you reproduce this without SLURM as well?
It seems to happen only when hydra queries the host list from SLURM. I tried executing two different setups on the head node, both listing two compute nodes in a hostfile: 1) mpiexec -f hostfile -n 4 ./hello Since the SLURM PAM module was disabled, SSH login to the nodes was possible and the job run as expected, with two ranks on each node. SLURM's sinfo showed both nodes as state 'idle' and the HYDRA_DEBUG output said '--rmk user --launcher ssh'. 2) mpiexec -f hostfile -rmk slurm -n 4 ./hello This job ran as well, with the nodes allocated via SLURM and shown as 'alloc'. Debug output: '--rmk slurm --launcher slurm'. Specifying a hostfile with mpiexec within a SLURM batch job also worked, but that's obviously not what you normally want to do... Hope this helps. If there is anything else I should try out to help tracking down the issue, please let me know. Thanks, Markus -- Dr. Markus Geimer Juelich Supercomputing Centre Institute for Advanced Simulation Forschungszentrum Juelich GmbH 52425 Juelich, Germany Phone: +49-2461-61-1773 Fax: +49-2461-61-6656 E-mail: [email protected] WWW: http://www.fz-juelich.de/jsc/ ------------------------------------------------------------------------------------------------ ------------------------------------------------------------------------------------------------ Forschungszentrum Juelich GmbH 52425 Juelich Sitz der Gesellschaft: Juelich Eingetragen im Handelsregister des Amtsgerichts Dueren Nr. HR B 3498 Vorsitzender des Aufsichtsrats: MinDir Dr. Karl Eugen Huthmacher Geschaeftsfuehrung: Prof. Dr. Achim Bachem (Vorsitzender), Karsten Beneke (stellv. Vorsitzender), Prof. Dr.-Ing. Harald Bolt, Prof. Dr. Sebastian M. Schmidt ------------------------------------------------------------------------------------------------ ------------------------------------------------------------------------------------------------
participants (1)
Markus Geimer
