Re: [mpich-discuss] OFI poll failed error if using more than one cluster node
Since there is no update to this after posting the Debug messages, I have since got a new suggestion from someone. I was told that MPICH was only built with PMIx support whereas mpiexec.hydra only provides a PMI server. Could that be the source of the problem? On Mon, 29 Jul 2024 at 11:15, Stephen Wong <[email protected]> wrote:
For the build configured with --with-device=ch4:ofi, I got
==== Various sizes and limits ==== sizeof(MPIDI_per_vci_t): 192 Required minimum FI_VERSION: 0, current version: 10014 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp;ofi_rxm, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: udp;ofi_rxd, score = 5, pref = -2, FI_SOCKADDR_IN [16] 192.168.1.5 provider: udp;ofi_rxd, score = 5, pref = -2, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: udp;ofi_rxd, score = 5, pref = -2, FI_SOCKADDR_IN [16] 127.0.0.1 provider: udp;ofi_rxd, score = 5, pref = -2, FI_SOCKADDR_IN6 [28] ::1 provider: shm, score = 4, pref = -2, FI_ADDR_STR [14] - fi_shm://4595 provider: shm, score = 4, pref = -2, FI_ADDR_STR [14] - fi_shm://4595 provider: udp, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: udp, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: udp, score = 0, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: udp, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: tcp, score = 0, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: tcp, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: tcp, score = 0, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp, score = 0, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: tcp, score = 4, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: sockets, score = 3, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: sockets, score = 3, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: sockets, score = 3, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: sockets, score = 3, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN [16] 192.168.1.5 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN6 [28] fe80::1ff:fe23:4567:890a provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN [16] 127.0.0.1 provider: sockets, score = 5, pref = 0, FI_SOCKADDR_IN6 [28] ::1 provider: sm2, score = 3, pref = 0, FI_ADDR_STR [13] - fi_sm2://4595 provider: sm2, score = 3, pref = 0, FI_ADDR_STR [13] - fi_sm2://4595 Required minimum FI_VERSION: 10005, current version: 10014 ==== Capability set configuration ==== libfabric provider: sockets - 192.168.1.0/24 MPIDI_OFI_ENABLE_DATA: 1 MPIDI_OFI_ENABLE_AV_TABLE: 1 MPIDI_OFI_ENABLE_SCALABLE_ENDPOINTS: 1 MPIDI_OFI_ENABLE_SHARED_CONTEXTS: 0 MPIDI_OFI_ENABLE_MR_VIRT_ADDRESS: 0 MPIDI_OFI_ENABLE_MR_ALLOCATED: 0 MPIDI_OFI_ENABLE_MR_REGISTER_NULL: 1 MPIDI_OFI_ENABLE_MR_PROV_KEY: 0 MPIDI_OFI_ENABLE_TAGGED: 1 MPIDI_OFI_ENABLE_AM: 1 MPIDI_OFI_ENABLE_RMA: 1 MPIDI_OFI_ENABLE_ATOMICS: 1 MPIDI_OFI_FETCH_ATOMIC_IOVECS: 1 MPIDI_OFI_ENABLE_DATA_AUTO_PROGRESS: 0 MPIDI_OFI_ENABLE_CONTROL_AUTO_PROGRESS: 0 MPIDI_OFI_ENABLE_PT2PT_NOPACK: 1 MPIDI_OFI_ENABLE_TRIGGERED: 0 MPIDI_OFI_ENABLE_HMEM: 0 MPIDI_OFI_NUM_AM_BUFFERS: 8 MPIDI_OFI_NUM_OPTIMIZED_MEMORY_REGIONS: 0 MPIDI_OFI_CONTEXT_BITS: 20 MPIDI_OFI_SOURCE_BITS: 0 MPIDI_OFI_TAG_BITS: 31 MPIDI_OFI_VNI_USE_DOMAIN: 1 MAXIMUM SUPPORTED RANKS: 4294967296 MAXIMUM TAG: 2147483648 ==== Provider global thresholds ==== max_buffered_send: 255 max_buffered_write: 255 max_msg_size: 9223372036854775807 max_order_raw: -1 max_order_war: -1 max_order_waw: -1 tx_iov_limit: 8 rx_iov_limit: 8 rma_iov_limit: 8 max_mr_key_size: 8 ==== Various sizes and limits ==== MPIDI_OFI_AM_MSG_HEADER_SIZE: 24 MPIDI_OFI_MAX_AM_HDR_SIZE: 255 sizeof(MPIDI_OFI_am_request_header_t): 416 sizeof(MPIDI_OFI_per_vci_t): 52480 MPIDI_OFI_AM_HDR_POOL_CELL_SIZE: 1024 MPIDI_OFI_DEFAULT_SHORT_SEND_SIZE: 16384 ==== OFI dynamic settings ==== num_vcis: 1 num_nics: 1 ======================================
*mpiexec -host host1,host2 -n 2 cpi*
Abort(883025295) on node 1: Fatal error in internal_Init: Other MPI error, error stack: internal_Init(48306).............: MPI_Init(argc=0x7ffcb8c7aedc, argv=0x7ffcb8c7aed0) failed MPII_Init_thread(265)............: MPIR_init_comm_world(34).........: MPIR_Comm_commit(823)............: MPID_Comm_commit_post_hook(222)..: MPIDI_world_post_init(660).......: MPIDI_OFI_init_vcis(842).........: check_num_nics(891)..............: MPIR_Allreduce_allcomm_auto(4726): MPIC_Sendrecv(306)...............: MPIC_Wait(91)....................: MPIR_Wait(780)...................: MPIR_Wait_state(737).............: MPIDI_progress_test(134).........: MPIDI_OFI_handle_cq_error(791)...: OFI poll failed (ofi_events.c:793:MPIDI_OFI_handle_cq_error:Input/output error) Abort(883025295) on node 0: Fatal error in internal_Init: Other MPI error, error stack: internal_Init(48306).............: MPI_Init(argc=0x7fff18beee1c, argv=0x7fff18beee10) failed MPII_Init_thread(265)............: MPIR_init_comm_world(34).........: MPIR_Comm_commit(823)............: MPID_Comm_commit_post_hook(222)..: MPIDI_world_post_init(660).......: MPIDI_OFI_init_vcis(842).........: check_num_nics(891)..............: MPIR_Allreduce_allcomm_auto(4726): MPIC_Sendrecv(306)...............: MPIC_Wait(91)....................: MPIR_Wait(780)...................: MPIR_Wait_state(737).............: MPIDI_progress_test(134).........: MPIDI_OFI_handle_cq_error(791)...: OFI poll failed (ofi_events.c:793:MPIDI_OFI_handle_cq_error:Input/output error)
On Fri, 26 Jul 2024 at 19:04, Zhou, Hui <[email protected]> wrote:
Could you run cpi with MPIR_CVAR_DEBUG_SUMMARY=1 and post the output?
Hui Zhou ------------------------------ *From:* Stephen Wong via discuss <[email protected]> *Sent:* Friday, July 26, 2024 4:46 AM *To:* [email protected] <[email protected]> *Cc:* Stephen Wong <[email protected]> *Subject:* [mpich-discuss] OFI poll failed error if using more than one cluster node
Hi, (I sent this previously without a subject line. ) I am using MPICH 4. 2. 2 on Ubuntu 24. 04 testing with the small program cpi that calculates the value of pi using MPI. I can start on host1 to run cpi on either host1 or host2 alone and I can ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd Hi,
(I sent this previously without a subject line.)
I am using MPICH 4.2.2 on Ubuntu 24.04 testing with the small program cpi that calculates the value of pi using MPI. I can start on host1 to run cpi on either host1 or host2 alone and I can start on host2 to run cpi on either host2 or host1 alone. The problem occurs only if I try to use both host1 and host2 together.
This is done using, for example, the command *mpiexec -host host1,host2 -n 2 cpi* then it ends with the error
Abort(77718927) on node 1: Fatal error in internal_Init: Other MPI error, error stack: internal_Init(48306).............: MPI_Init(argc=0x7ffdb68e7fec, argv=0x7ffdb68e7fe0) failed MPII_Init_thread(265)............: MPIR_init_comm_world(34).........: MPIR_Comm_commit(823)............: MPID_Comm_commit_post_hook(222)..: MPIDI_world_post_init(660).......: MPIDI_OFI_init_vcis(842).........: check_num_nics(891)..............: MPIR_Allreduce_allcomm_auto(4726): MPIC_Sendrecv(306)...............: MPIC_Wait(91)....................: MPIR_Wait(780)...................: MPIR_Wait_state(737).............: MPIDI_progress_test(134).........: MPIDI_OFI_handle_cq_error(791)...: OFI poll failed (ofi_events.c:793:MPIDI_OFI_handle_cq_error:Input/output error) Abort(77718927) on node 0: Fatal error in internal_Init: Other MPI error, error stack: internal_Init(48306).............: MPI_Init(argc=0x7ffcb5b28adc, argv=0x7ffcb5b28ad0) failed MPII_Init_thread(265)............: MPIR_init_comm_world(34).........: MPIR_Comm_commit(823)............: MPID_Comm_commit_post_hook(222)..: MPIDI_world_post_init(660).......: MPIDI_OFI_init_vcis(842).........: check_num_nics(891)..............: MPIR_Allreduce_allcomm_auto(4726): MPIC_Sendrecv(306)...............: MPIC_Wait(91)....................: MPIR_Wait(780)...................: MPIR_Wait_state(737).............: MPIDI_progress_test(134).........: MPIDI_OFI_handle_cq_error(791)...: OFI poll failed (ofi_events.c:793:MPIDI_OFI_handle_cq_error:Input/output error) I searched through the archive of this mailing list and there is only one thread that has this OFI poll failed error. In the thread, it mentioned this has something to do with the device configuration of ch4:ofi ? I checked my configure log and it has device : ch4:ofi (embedded libfabric) in the configuration when I built the MPI. So I am wondering if I should switch this option to something else? If this will fix it. I am not too sure what other option I could substitute for ch4:ofi.
Next I tried running configure for a build with the --enable-device = ch3:nemesis option. Now again I can run the cpi on any of host1 or host2 alone. If I run it on host1 and host2 together, it just crashed with a core dump.
Using the --enable-device = ch3:sock configure option resulted in more or less the same problem but now it just quits silently when running on host1 and host2 together.
Any ideas? Thanks! Stephen.
participants (1)
Stephen Wong
