Re: [mpich-discuss] Wrapping routines with choice buffers from Fortran
Sorry, the mail was intended to be PM :/ Translation inline below Am 20.02.25 um 17:16 schrieb Joachim Jenke via discuss:
Hallo Gregor,
beim gucken, was es dazu in mpich so gibt bin ich darüber gestolpert:
grepping trough MPICH source I found:
https://github.com/pmodels/mpich/blob/main/test/mpi/f08/profile/ profile1f90.f90#L70
Hast du den present check für ierr auf dem Schirm?
Are you aware of the necessary present check? - Joachim
- Joachim
Am 20.02.25 um 16:56 schrieb Gregor Corbin via discuss:
Hi everyone,
I am developing a set of wrappers for the C and Fortran 2008 ('use mpi_f08') bindings. The F08 wrappers are intercepting the Fortran routines, for instance
subroutine mpi_send_f08ts_(buf, count, datatype, dest, tag, comm, ierror) use :: mpi_f08, only: MPI_Comm, MPI_Datatype, PMPI_Send implicit none ! argument declarations ... ! wrapper code ... call PMPI_Send(buf, count, datatype, dest, tag, comm, ierror) end subroutine
In MPICH, the call to PMPI_Send is forwarded to MPIR_Send_cdesc which then calls MPI_Send internally. Since I also wrap MPI_Send in C, calls from Fortran go through both wrappers, which is not intended. This only happens for routines with choice buffers, though. Routines without buffers call into the PMPI interface (e.g. mpi_wait_f08_ calls MPIR_Wait_c which binds directly to PMPI_Wait). I attached a small example that demonstrates the issue.
Is this behavior intended? How can I correctly wrap these choice buffer routines?
Best,
Gregor Corbin
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Dr. rer. nat. Joachim Jenke IT Center Group: High Performance Computing Division: Computational Science and Engineering RWTH Aachen University Seffenter Weg 23 D 52074 Aachen (Germany) Tel: +49 241 80- 24765 Fax: +49 241 80-624765 [email protected] www.itc.rwth-aachen.de
participants (1)
Joachim Jenke
