Re: [mpich-discuss] coupling
Hi Fereshte, There is the possibility that your application is failing due to a bug in MPICH which could have been already solved. I do a +1 in Huiwei's suggestion to try with the current stable release. Antonio On Sunday, October 27, 2013 02:03:54 PM fereshteh komijani wrote: Sure. ROMS and SWAN models are models for ocean and wave models, respectively. Coupling of them require 3 input files: coupling_test.in[1], swan_test.in[2] and roms_test.in[3] which first one is coupled input file and also one build.bash file which in it user called requested libraries, cpp optins, header file, compilers (for me gcc and gfortran). For example in build.bash file I set USE_MPI=on = on USE_MPIF90 =on WHICH_MPI=mpich2 FORT = gfortran also with regard that for coupling model, MCT (model coupling toolkit) is necessary I have installed it and set its include and lib directories in build.bash file. In coupling_test.in[1] user call swan_test.in[2] and roms_test.in[3] as wave and ocean model's inputs. In _roms_test.in_ some coefficients, solving technique and some input forcing file determined. for choosing number of nodes for each model there are NtileI and Ntilej in _roms_test.in_ and Nthreads (ocean) and Nthreads (wave) in coupling_test.in[1] file ( Nthreads (ocean)=NtileI *Ntilej ) and total nodes are equal to Nthreads (ocean)+Nthreads (wave). whenever i set one node for wave model (SWAN) (Nthreads (wave)=1) after running by mpirun -np 2 ./oceanG coupling_inlet-test.in[4]>mpi.log it replies: application called MPI_Abort(comm=0x84000002, 4) - process 0 But when set Nthreads (wave)>1 (and everything for Nthreads (ocean)) for example mpirun -np 8 ./oceanG coupling_inlet-test.in>mpi.log mpi.log file (attaché file) shows that roms model does not have problems and its nodes are active but nothing happen for swan model after 2 weeks than running. I hope that this information be sufficient. All the best fereshte -------- [1] http://coupling_test.in [2] http://swan_test.in [3] http://roms_test.in [4] http://coupling_inlet-test.in/
participants (1)
Antonio J. Peña
