Re: [mpich-discuss] MCS lock and MPI RMA problem
Shouldn't winsize be 3 integers in your code? (sorry, I spent only 30 seconds looking at the code, so I might have missed something). -- Pavan
On Mar 12, 2017, at 2:44 PM, Ask Jakobsen <[email protected]> wrote:
Interestingly, according to the paper you suggested it appears to include a similar test in pseudo code https://htor.inf.ethz.ch/publications/img/hpclocks.pdf (see Listing 3 in paper).
Unfortunately, removing the test in the release protocol did not solve the problem. The race condition is much more difficult to provoke, but I managed when setting the size of the communicator to 3 (only tested even sizes so far).
From Jeff's suggestion I have attempted to rewrite the code removing local loads and stores in the MPI_Win_lock_all epochs using MPI_Fetch_and_op (see attached files).
This version behaves very similar to the original code and also fails from time to time. Putting a sleep into the acquire busy loop (usleep(100)) will make the code "much more robust" (I hack, I know, but indicating some underlying race condition?!). Let me know if you see any problems in the way I am using MPI_Fetch_and_op in a busy loop. Flushing or syncing is not necessary in this case, right?
All work is done with export MPIR_CVAR_ASYNC_PROGRESS=1 on mpich-3.2 and mpich-3.3a2
On Wed, Mar 8, 2017 at 4:21 PM, Halim Amer <[email protected]> wrote: I cannot claim that I thoroughly verified the correctness of that code, so take it with a grain of salt. Please keep in mind that it is a test code from a tutorial book; those codes are meant for learning purposes not for deployment.
If your goal is to have a high performance RMA lock, I suggest you to look into the recent HPDC'16 paper: "High-Performance Distributed RMA Locks".
Halim www.mcs.anl.gov/~aamer
On 3/8/17 3:06 AM, Ask Jakobsen wrote: You are absolutely correct, Halim. Removing the test lmem[nextRank] == -1 in release fixes the problem. Great work. Now I will try to understand why you are right. I hope the authors of the book will credit you for discovering the bug.
So in conclusion you need to remove the above mentioned test AND enable asynchronous progression using the environment variable MPIR_CVAR_ASYNC_PROGRESS=1 in MPICH (BTW I still can't get the code to work in openmpi).
On Tue, Mar 7, 2017 at 5:37 PM, Halim Amer <[email protected]> wrote:
detect that another process is being or already enqueued in the MCS queue.
Actually the problem occurs only when the waiting process already enqueued itself, i.e., the accumulate operation on the nextRank field succeeded.
Halim www.mcs.anl.gov/~aamer <http://www.mcs.anl.gov/%7Eaamer>
On 3/7/17 10:29 AM, Halim Amer wrote:
In the Release protocol, try removing this test:
if (lmem[nextRank] == -1) { If-Block; }
but keep the If-Block.
The hang occurs because the process releasing the MCS lock fails to detect that another process is being or already enqueued in the MCS queue.
On 3/7/17 6:43 AM, Ask Jakobsen wrote:
Thanks, Halim. I have now enabled asynchronous progress in MPICH (can't find something similar in openmpi) and now all ranks acquire the lock and the program finish as expected. However if I put a while(1) loop around the acquire-release code in main.c it will fail again at random and go into an infinite loop. The simple unfair lock does not have this problem.
On Tue, Mar 7, 2017 at 12:44 AM, Halim Amer <[email protected]> wrote:
My understanding is that this code assumes asynchronous progress. An example of when the processes hang is as follows:
1) P0 Finishes MCSLockAcquire() 2) P1 is busy waiting in MCSLockAcquire() at do { MPI_Win_sync(win); } while (lmem[blocked] == 1); 3) P0 executes MCSLockRelease() 4) P0 waits on MPI_Win_lock_all() inside MCSLockRlease()
Hang!
For P1 to get out of the loop, P0 has to get out of MPI_Win_lock_all() and executes its Compare_and_swap().
For P0 to get out MPI_Win_lock_all(), it needs an ACK from P1 that it got the lock.
P1 does not make communication progress because MPI_Win_sync is not required to do so. It only synchronizes private and public copies.
For this hang to disappear, one can either trigger progress manually by using heavy-duty synchronization calls instead of Win_sync (e.g., Win_unlock_all + Win_lock_all), or enable asynchronous progress.
To enable asynchronous progress in MPICH, set the MPIR_CVAR_ASYNC_PROGRESS env var to 1.
Halim www.mcs.anl.gov/~aamer <http://www.mcs.anl.gov/%7Eaamer> < http://www.mcs.anl.gov/%7Eaamer>
On 3/6/17 1:11 PM, Ask Jakobsen wrote:
I am testing on x86_64 platform.
I have tried to built both the mpich and the mcs lock code with -O0 to avoid agressive optimization. After your suggestion I have also tried to make volatile int *pblocked pointing to lmem[blocked] in the MCSLockAcquire function and volatile int *pnextrank pointing to lmem[nextRank] in MCSLockRelease, but it does not appear to make a difference.
On suggestion from Richard Warren I have also tried building the code using openmpi-2.0.2 without any luck (however it appears to acquire the lock a couple of extra times before failing) which I find troubling.
I think I will give up using local load/stores and will see if I can figure out if rewrite using MPI calls like MPI_Fetch_and_op as you suggest. Thanks for your help.
On Mon, Mar 6, 2017 at 7:20 PM, Jeff Hammond <[email protected]> wrote:
What processor architecture are you testing?
Maybe set lmem to volatile or read it with MPI_Fetch_and_op rather than a load. MPI_Win_sync cannot prevent the compiler from caching *lmem in a register.
Jeff
On Sat, Mar 4, 2017 at 12:30 AM, Ask Jakobsen <[email protected]> wrote:
I have downloaded the source code for the MCS lock from the excellent book "Using Advanced MPI" from http://www.mcs.anl.gov/researc h/projects/mpi/usingmpi/examples-advmpi/rma2/mcs-lock.c
I have made a very simple piece of test code for testing the MCS lock but it works at random and often never escapes the busy loops in the acquire and release functions (see attached source code). The code appears semantically correct to my eyes.
#include <stdio.h> #include <mpi.h> #include "mcs-lock.h"
int main(int argc, char *argv[]) { MPI_Win win; MPI_Init( &argc, &argv );
MCSLockInit(MPI_COMM_WORLD, &win);
int rank, size; MPI_Comm_rank(MPI_COMM_WORLD, &rank); MPI_Comm_size(MPI_COMM_WORLD, &size);
printf("rank: %d, size: %d\n", rank, size);
MCSLockAcquire(win); printf("rank %d aquired lock\n", rank); fflush(stdout); MCSLockRelease(win);
MPI_Win_free(&win); MPI_Finalize(); return 0; }
I have tested on several hardware platforms and mpich-3.2 and mpich-3.3a2 but with no luck.
It appears that the MPI_Win_Sync are not "refreshing" the local data or I have a bug I can't spot.
A simple unfair lock like http://www.mcs.anl.gov/researc h/projects/mpi/usingmpi/examples-advmpi/rma2/ga_mutex1.c works perfectly.
Best regards, Ask Jakobsen
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <main.c><mcs-lock-fop.c><mcs-lock.h>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
