Re: [mpich-discuss] statically linked mpiexec
Ah, sorry. I misread your first email and assumed you were only talking about the MPICH libraries and compiler wrappers. The Intel compilers should accept a '-static' flag that will force link all libraries statically. Try adding it to your CFLAGS to force this behavior on mpiexec. Ken On 04/07/2014 09:50 AM, Andy May wrote:
Ken,
The '--disable-shared' flag removes some of the external references (to the Intel compiler in my case) but still leaves:
ldd ./bin/mpiexec linux-vdso.so.1 (0x00007fff7a7b9000) libnsl.so.1 => /lib64/libnsl.so.1 (0x00007f3298e3f000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f3298c21000) libpciaccess.so.0 => /usr/lib64/libpciaccess.so.0 (0x00007f3298a17000) libxml2.so.2 => /usr/lib64/libxml2.so.2 (0x00007f32986ac000) libdl.so.2 => /lib64/libdl.so.2 (0x00007f32984a8000) libz.so.1 => /lib64/libz.so.1 (0x00007f3298292000) liblzma.so.5 => /usr/lib64/liblzma.so.5 (0x00007f329806c000) libm.so.6 => /lib64/libm.so.6 (0x00007f3297d69000) libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f3297b52000) libc.so.6 => /lib64/libc.so.6 (0x00007f32977a3000) /lib64/ld-linux-x86-64.so.2 (0x00007f3299057000)
whereas what I did gives:
ldd ./bin/mpiexec not a dynamic executable
Is there any option to ensure fully statically linked mpiexec via configure?
Andy
On 07/04/14 13:26, Kenneth Raffenetti wrote:
Andy,
The official way is to add '--disable-shared' to your configure line.
Ken
On 04/07/2014 05:47 AM, Andy May wrote:
Does anyone know if there is a supported or recommended way to build MPICH such that it's binaries (eg. mpiexec) are statically linked?
At present, post building I'm running:
cd src/pm/hydra eval ./configure `./config.status --config` --disable-pci --disable-libxml2 make CCLD='$(CC) -all-static'
which just disables two cases where the static libraries aren't available, then links statically, but is there a better or correct way to do this?
Many thanks,
Andy _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
