Re: [mpich-discuss] can't MPI_Abort a program due to deadlock at pthread_mutex_lock
If you really need this to work, you can also disable pthread cancellation when the thread is in MPI calls:
pthread_setcanceltype(PTHREAD_CANCEL_DISABLE, &cancel_val); MPI_Probe(MPI_ANY_SOURCE, MPI_ANY_TAG, MPI_COMM_WORLD, MPI_STATUS_IGNORE); pthread_setcanceltype(cancel_val, &junk);
With that change, the program you sent works correctly.
Thanks. This is useful info but I have a better way to work around this issue in the code that I actually care about. I'm writing active messages over p2p and it's trivial to tell the polling thread to pthread_exit via an active-message.
It think that adding setcanceltype() to the MPICH thread safety macros might be all that we have to do to make the library cancel-safe, but I'm not a pthreads expert. It could have a nonzero performance cost, so it would likely need to be a compile-time option.
This might be useful as a debugging option but I wouldn't prioritize it.
Pthread_cancel is unsafe in any context where the cancelled thread can hold a mutex needed by other threads. This looks to me like a bad programming practice (e.g. you will also likely leak memory, since you can't free MPI objects allocated by the thread from inside of a cancellation handler), not an MPICH-specific problem; there are safer ways to cancel/cleanup threads.
I don't care about memory leaks since the use case was merely to exit the program.
Do you have a good case for why such functionality is needed?
The use of pthread_cancel is entirely optional. I knew there were many ways to work around this and I've already implemented the one that makes the most sense to me. Thanks for all your comments. Best, Jeff -- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
participants (1)
Jeff Hammond
