Re: [mpich-discuss] Building MPE for use with OpenMPI
MPI_Type_struct is not a part of the MPI standard anymore and is replaced by MPI_Type_create_struct. Both MPICH and Open MPI decided to retain it, but followed different directions for it. MPICH decided to follow the same convention as MPI_Type_create_struct with the const additions. Open MPI decided to keep the old prototypes as is. Unfortunately, MPE got stuck in between the two. The best approach would be to simply remove those functions from MPE and this problem just goes away. Would you be able to do that and contribute a patch? More generally, I think MPICH was overzealous in trying to constify prototypes for the deleted functions. It should have just left them as they are, like what Open MPI did. We'll figure out what to do about that internally, but that's not going to be a quick change because of ABI and other such stuff. Thanks, -- Pavan
On Nov 30, 2015, at 8:14 PM, Schilling, Herbert W. (GRC-VE00) <[email protected]> wrote:
I am trying to build MPE for use with OpenMPI. I built from source Version 1.10.1 of OpenMPI.
I am using this version of MPE ftp://ftp.mcs.anl.gov/pub/mpi/mpe/mpe2.tar.gz
Should this work fine? I followed the instructions to build like this:
${MPE_SRC_DIR}/configure MPI_CC=${OPENMPI_INSTALL_DIR}/bin/mpicc \ CC=<C_COMPILER_used_to_build_OpenMPI> \ MPI_F77=${OPENMPI_INSTALL_DIR}/bin/mpif77 \ F77=<FORTRAN_COMPILER_used_to_build_OpenMPI> \ --with-java2=/usr/local/j2sdk-1.4.2 --prefix=<MPE_INSTALL_DIR> make make install
I keep running into problems with conflicting declarations
log_mpi_core.c:5611: error: conflicting types for 'MPI_Type_struct' /u/hschilli/local/include/mpi.h:1796: error: previous declaration of 'MPI_Type_struct' was here
I think the issue is that MPE's declaration uses some const qualifiers while OpenMPI does not.
I tried hacking my way through this with the macro
HAVE_CONST_IN_MPI_DECL and MPE_CONST but no luck so far.
What am I doing wrong?
Thanks in advance.
--------- Herb Schilling Scientific Applications and Visualization Team http://ocio.grc.nasa.gov/gvis Office of the Chief Information Officer NASA Glenn Research Center [email protected]
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
