Re: [mpich-discuss] Return error code issues - MPICH 3.2.1
Hi Ken, Thank you, I just submitted an issue (#3366). Note that all the reports are associated with the same function call, MPIR_Setup_intercomm_localcomm, apparently used for intercommunicators, so they essentially refer to the same class of bug, but in different files or communication functions. If at least a simple case could be verified (e.g., bcast) it would be useful for us to mark it a as success case and continue improving the analysis. Thank you!! Ignacio On 10/10/18 2:23 PM, Raffenetti, Kenneth J. wrote:
Hi Ignacio,
Would you mind creating a Github issue (https://github.com/pmodels/mpich) to track this? It will take some time to go through all the locations you have identified, but IMO from the example you are onto a real issue.
Ken
On 10/10/18 10:41 AM, Laguna Peralta, Ignacio wrote:
Hi MPICH developers,
I would like to report some (unconfirmed) issues on how return error codes are propagated within the library (e.g., when using the MPI_ERRORS_RETURN handler).
We are developing a static analysis framework that detects the code location of such bugs and we have tested it recently in MPICH 3.2.1. The framework is giving us a number of reports and we would like to confirm with you whether these are real bug cases or just false alarms.
** What the framework does **
It analyzes all functions and call paths within the library trying to identify cases where a return error code is either:
(a) not saved by the calling function (b) saved but later overwritten without MPICH taken an action on the error. An action could be, for example, printing a message, aborting, or returning the error to the calling function.
An example of case (a) we think we found is in src/mpi/coll/bcast.c:1402:
1400 /* Get the local intracommunicator */ 1401 if (!comm_ptr->local_comm) 1402 MPIR_Setup_intercomm_localcomm( comm_ptr ); 1403 1404 newcomm_ptr = comm_ptr->local_comm; 1405 1406 /* now do the usual broadcast on this intracommunicator 1407 with rank 0 as root. */ 1408 mpi_errno = MPIR_Bcast_intra(buffer, count, datatype, 0, newcomm_ptr, errflag);
In line 1402, the MPIR_Setup_intercomm_localcomm function is called but the error code that this function could return is not saved--in line 1408 an error code is saved, however, in mpi_errno, which is what we would expect for line 1402.
We see that MPICH takes actions such the following when an error is observed (from the same file):
1408 mpi_errno = MPIR_Bcast_intra(buffer, count, datatype, 0, newcomm_ptr, errflag); 1409 if (mpi_errno) { 1410 /* for communication errors, just record the error but continue */ 1411 *errflag = MPIR_ERR_GET_CLASS(mpi_errno); 1412 MPIR_ERR_SET(mpi_errno, *errflag, "**fail"); 1413 MPIR_ERR_ADD(mpi_errno_ret, mpi_errno); 1414 }
So we took this code and adapted it to line 1402. Then when we inject an artificial error code (something different from MPI_SUCCESS) to MPIR_Setup_intercomm_localcomm, we see that this fixes the bug and the program receives the error when calling MPI_Bcast; otherwise the artificially injected error is lost and the program cannot see it.
** Reports **
Our framework is reporting the same case in other MPICH 3.2.1 locations:
src/mpi/coll/allgather.c:694 src/mpi/coll/allreduce.c:657 src/mpi/coll/bcast.c:1402 src/mpi/coll/iallgather.c:525 src/mpi/coll/iallreduce.c:551 src/mpi/coll/iscatter.c:505 src/mpi/coll/red_scat_block.c:965 src/mpi/coll/scatter.c:509 src/mpi/comm/comm_create.c:314 src/mpi/comm/comm_split.c:158 src/mpi/comm/intercomm_merge.c:301
** What we need from you **
Could someone take a look at these reports and confirm whether they are real bug cases (where some action is missing) or they are just false reports/alarms since in these locations there is no reason to save the error code and take an action?
Thank you for your help. This will help us improve the framework and hopefully could report issues to MPICH to make it more reliable.
Thanks!
participants (1)
Ignacio Laguna
