Re : MPI process killed and SIGUSR1
Hi Wesley, Please check the client.c. There is explicit "assert" statement, which will terminate the client program abnormally. The server would be waiting on a MPI_Recv at that moment and the receive never times out or completes. Even I replace the assert with sleep (100) and then manually kill the client process by process-id, the result is same. Could you please let me know if a client is abnormally terminated, is there any way to detect that from server or not. Thanks, Hirak
Ok. I don't see where you're killing a process.
On Oct 27, 2014, at 10:51 PM, Roy, Hirak <Hirak_Roy at mentor.com<https://lists.mpich.org/mailman/listinfo/discuss>> wrote:
Hi Wesley,
This is related to the FT problem.
Thanks, Hirak
Is this still related to your FT problems or is this a separate problem?
Thanks, Wesley
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Roy, Hirak
