Re: [mpich-discuss] MPI_Win_fence failed
Oh, yeah, that would be an easier way. I just create a repository in github. you can git clone https://github.com/sufengniu/mpi_app_test.git to run the program. you need to install a tif library. I know ubuntu is sudo apt-get install libtiff4-dev. after you download it. just make then there will be 2 bin file, please change hostfile to your machine, first run mpi: ./run.perl main then run ./udp_client 55Fe_run5_dark.tif Thanks a lot! Sufeng On Wed, Jul 10, 2013 at 11:57 AM, <[email protected]> wrote:
Send discuss mailing list submissions to [email protected]
To subscribe or unsubscribe via the World Wide Web, visit https://lists.mpich.org/mailman/listinfo/discuss or, via email, send a message with subject or body 'help' to [email protected]
You can reach the person managing the list at [email protected]
When replying, please edit your Subject line so it is more specific than "Re: Contents of discuss digest..."
Today's Topics:
1. Re: MPI_Win_fence failed (Jeff Hammond) 2. Re: MPI_Win_fence failed (Sufeng Niu)
Message: 1 Date: Wed, 10 Jul 2013 11:46:08 -0500 From: Jeff Hammond <[email protected]> To: [email protected] Subject: Re: [mpich-discuss] MPI_Win_fence failed Message-ID: <CAGKz= [email protected]> Content-Type: text/plain; charset=ISO-8859-1
Just post the code so we can run it.
Jeff
On Wed, Jul 10, 2013 at 11:39 AM, Sufeng Niu <[email protected]> wrote:
Sorry I forget to add screen shot for backtrace. the screen shot is attached.
Thanks a lot!
Sufeng
Today's Topics:
1. Re: MPI_Win_fence failed (Sufeng Niu)
Message: 1 Date: Wed, 10 Jul 2013 11:30:36 -0500 From: Sufeng Niu <[email protected]> To: [email protected] Subject: Re: [mpich-discuss] MPI_Win_fence failed Message-ID:
<CAFNNHkyLj8CbYMmc_w2DA9_+q2Oe3kyus+g6c99ShPk6ZXVkdA@mail.gmail.com> Content-Type: text/plain; charset="iso-8859-1"
Hi Jim,
Thanks a lot for your reply. the basic way for me to debugging is barrier+printf, right now I only have an evaluation version of
totalview.
the backtrace using totalview shown below. the udp is the udp collection and create RMA window, image_rms doing MPI_Get to access the window
There is a segment violation, but I don't know why the program stopped at MPI_Win_fence.
Thanks a lot!
Today's Topics:
1. Re: MPICH3.0.4 make fails with "No rule to make target..." (Wesley Bland) 2. Re: Error in MPI_Finalize on a simple ring test over TCP (Wesley Bland) 3. Restrict number of cores, not threads (Bob Ilgner) 4. Re: Restrict number of cores, not threads (Wesley Bland) 5. Re: Restrict number of cores, not threads (Wesley Bland) 6. Re: Error in MPI_Finalize on a simple ring test over TCP (Thomas Ropars) 7. MPI_Win_fence failed (Sufeng Niu) 8. Re: MPI_Win_fence failed (Jim Dinan)
Message: 1 Date: Wed, 10 Jul 2013 08:29:06 -0500 From: Wesley Bland <[email protected]> To: [email protected] Subject: Re: [mpich-discuss] MPICH3.0.4 make fails with "No rule to make target..." Message-ID: <[email protected]> Content-Type: text/plain; charset="iso-8859-1"
Unfortunately, due to the lack of developer resources and interest, the last version of MPICH which was supported on Windows was 1.4.1p. You can find that version on the downloads page:
http://www.mpich.org/downloads/
Alternatively, Microsoft maintains a derivative of MPICH which should provide the features you need. You also find a link to that on the downloads page above.
Wesley
On Jul 10, 2013, at 1:16 AM, Don Warren <[email protected]> wrote:
Hello,
As requested in the installation guide, I'm informing this list of a failure to correctly make MPICH3.0.4 on a Win7 system. The specific error encountered is "make[2]: *** No rule to make target `/cygdrive/c/FLASH/mpich-3.0.4/src/mpi/romio/Makefile.am', needed by `/cygdrive/c/FLASH/mpich-3.0.4/src/mpi/romio/Makefile.in'. Stop."
I have confirmed that both Makefile.am and Makefile.in exist in the directory listed. I'm attaching the c.txt and the m.txt files.
Possibly of interest is that the command "make clean" fails at exactly the same folder, with exactly the same error message as shown in m.txt and above.
Any advice you can give would be appreciated. I'm attempting to get FLASH running on my computer, which seems to require MPICH.
Regards, Don Warren
<config-make-outputs.zip>_______________________________________________
discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Sufeng Niu
