Re: [mpich-discuss] MPI process killed and SIGUSR1
Please don’t rely on this feature. We are preparing for MPI-4 Fault Tolerance and are in the process of reworking a bunch of this stuff. This might or might not exist in the future if you are planning to use this for production code. — Pavan On Oct 9, 2014, at 10:57 AM, Roy, Hirak <[email protected]> wrote:
Hi Sangmin,
The readme of mpich says the following :
FAILURE NOTIFICATION: THIS IS AN UNSUPPORTED FEATURE AND WILL ALMOST CERTAINLY CHANGE IN THE FUTURE!
In the current release, hydra notifies the MPICH library of failed processes by sending a SIGUSR1 signal. The application can catch this signal to be notified of failed processes. If the application replaces the library's signal handler with its own, the application must be sure to call the library's handler from it's own handler. Note that you cannot call any MPI function from inside a signal handler.
If this is true, should not I expect SIGUSR1?
Thanks, Hirak First of all, MPI functions are not signal safe. So, if you try to use signals within your MPI program, things might break.
— Sangmin
On Oct 9, 2014, at 7:37 AM, Roy, Hirak <Hirak_Roy at mentor.com<mailto:Hirak_Roy at mentor.com>> wrote:
Hi ,
I have two MPI processes (server and client) launched independently by two different mpiexec command. (mpich-3.0.4, sock-device) 1> mpiexec –disable-auto-cleanup –n 1 ./server 2> mpiexec –disable-auto-cleanup –n 1 ./client
The server opens a port and does MPI_Comm_accept. The client gets the port information and does MPI_Comm_connect and hence we get a new intercommunicator. I don’t do MPI_Comm_merge.
I have installed my own signal handler for SIGUSR1 before even I call MPI_Init ( I guess, this will automatically chain the signal handler).
signal (SIGUSR1, mysignalhandler);
Now suppose, the ‘client’ process gets killed ( I forcefully kill the process by signal 9), I thought I would get SIGUSR1 in the process ‘server’. However, I don’t get any signal in ‘server’ process. Am I doing something wrong? I have noticed that if I start 4 client processes with single mpiexec command, and one client gets killed, rest of the 3 clients receive SIGUSR1.
Does this mean, SIGUSR1 is not forwarded across processes connected using inter-communicator?
Thanks, Hirak _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Pavan Balaji ✉️ http://www.mcs.anl.gov/~balaji _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
