Re: [mpich-discuss] Fatal error in PMPI_Barrier: A process has failed, error stack:
There are numerous instances of "openmpi" in directory paths in the log file. Is the code entirely compiled and linked with MPICH? Rajeev On Mar 26, 2014, at 3:53 PM, Tony Ladd <[email protected]> wrote:
I get this error when I try to use mpich across two different nodes. My program works on a single node. I realize this is a common error but I have checked all of the issues mentioned in the FAQ and I did not find any further discussion in the archives.
I followed the standard installation to /global/usr/bin and /global/usr/lib. The file system /global is automounted on the clients which have passwordless ssh configured.
Running either my network test code or Intel's IMB code produced a similar error (see attached). Both codes run on a single node under mpich and run across the two nodes using openmpi. Also netpipe (using tcp sockets works fine).
I tried including the LD_LIBRARY_PAT via the -genv option but that did not help. I must have some configuration issue but I do not see what. I have had previous versions of mpich/mvapich working without any trouble but I am stuck here. I would be grateful for any hints.
Tony
-- Tony Ladd
Chemical Engineering Department University of Florida Gainesville, Florida 32611-6005 USA
Email: tladd-"(AT)"-che.ufl.edu Web http://ladd.che.ufl.edu
Tel: (352)-392-6509 FAX: (352)-392-9514
<mpich.log>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Rajeev Thakur
