Re: [mpich-discuss] mpirun not running in batch mode.
Hi Reuti and thanks In both cases, terminal or cron, I run the script as a normal user (meteo). The executable is a symbolic link to the actual rams60 owned by root (build with /sudo make/). Didn't mention we are on Ubuntu 12.04. lrwxrwxrwx 1 meteo meteo 39 mar 12 11:57 rams60 -> /usr/local/rams60/build/60/rams-6.0-opt -rwxr-xr-x 1 root root 5009008 jun 11 11:34 /usr/local/rams60/build/60/rams-6.0-opt Sorry but don't know about queuing system, I'm not an expert in system administration but a meteorologist working with computers. Thanks El 11/06/2014 11:24, Reuti escribi�:
Am 11.06.2014 um 10:55 schrieb Francisco Pastor:
Hi mpich users
I know I am using an old version of mpich but this one has been working for a long time so when building a new cluster we decided to use the same one. The point is that we have installed RAMS meteorological model with mpich2-1.0.5 and it runs fine when running from console but not with cron or at. Is it running at root then or by a normal user? The path may be different when starting with these methodes too.
As it's a new cluster: did you look into the option to install a queuing system?
-- Reuti
If the script that runs the model is scheduled with cron it just starts processes on the main node but not in the rest of the cluster nodes.
While waiting for your help I will try to upgrade to a newer mpich version.
I can't find the reason why this is happening, probably I made some mistake. Can you help me? Any idea will be welcome and tried.
Following I attach some information that could be useful to understand my problem.
meteo@ventus:~$ mpich2version Version: 1.0.5 Device: ch3:sock Configure Options: CC: gcc CXX: c++ F77: f95 F90: f95
Processes in the main node when run with `at`
meteo@ventus:~/RAMS/RUN$ ps -ef | grep rams meteo 20324 18460 0 09:32 ? 00:00:00 python2 /usr/local/mpich2-1.0.5p4/bin/mpirun -envall -n 40 ./rams60 -f RAMSIN.operatiu meteo 20331 20326 0 09:32 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 20332 20327 0 09:32 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 20333 20328 0 09:32 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 20334 20329 0 09:32 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 20335 20330 0 09:32 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 20336 20325 0 09:32 ? 00:00:00 ./rams60 -f RAMSIN.operatiu meteo 20343 18113 0 09:33 pts/4 00:00:00 grep --color=auto rams
log of mpirun
meteo@ventus:~/RAMS/RUN$ cat log_rams_operatiu-INITIAL-20140611-0000 in main 1024 numarg: 2 in main 1024 numarg: 2 in main 1024 numarg: 2 in main 1024 numarg: 2 in main 1024 numarg: 2 in main 1024 numarg: 2 in main 1024 numarg: 2 in main 1024 numarg: 2 par init numargs: 3 ./rams60 1024 0 par init args: 0 argvp[i] ./rams60 par init args: 1 argvp[i] -f par init args: 2 argvp[i] RAMSIN.operatiu par init RAMS_MPI defined par init numargs: 3 ./rams60 1024 0 par init args: 0 argvp[i] ./rams60 par init args: 1 argvp[i] -f par init args: 2 argvp[i] RAMSIN.operatiu par init RAMS_MPI defined par init numargs: 3 ./rams60 1024 0 par init args: 0 argvp[i] ./rams60 par init args: 1 argvp[i] -f par init args: 2 argvp[i] RAMSIN.operatiu par init RAMS_MPI defined par init numargs: 3 ./rams60 1024 0 par init args: 0 argvp[i] ./rams60 par init args: 1 argvp[i] -f par init args: 2 argvp[i] RAMSIN.operatiu par init RAMS_MPI defined par init numargs: 3 ./rams60 1024 0 par init args: 0 argvp[i] ./rams60 par init args: 1 argvp[i] -f par init args: 2 argvp[i] RAMSIN.operatiu par init RAMS_MPI defined par init numargs: 3 ./rams60 1024 0 par init args: 0 argvp[i] ./rams60 par init args: 1 argvp[i] -f par init args: 2 argvp[i] RAMSIN.operatiu par init RAMS_MPI defined par init numargs: 3 ./rams60 1024 0 par init args: 0 argvp[i] ./rams60 par init args: 1 argvp[i] -f par init args: 2 argvp[i] RAMSIN.operatiu par init RAMS_MPI defined par init numargs: 3 ./rams60 1024 0 par init args: 0 argvp[i] ./rams60 par init args: 1 argvp[i] -f par init args: 2 argvp[i] RAMSIN.operatiu par init RAMS_MPI defined
Mpich options to compile RAMS model
MPI_PATH=/usr/local/mpich2-1.0.5p4 PAR_INCS=-I$(MPI_PATH)/src/include PAR_LIBS=-L$(MPI_PATH)/lib/ -lmpich PAR_DEFS=-DRAMS_MPI
Thank you very much for your help.
-- ----------- Dr. Francisco Pastor Meteorology department, Instituto Universitario CEAM-UMH http://www.ceam.es ----------- Mendeley profile: http://www.mendeley.com/profiles/francisco-pastor1/ Google Scholar: http://scholar.google.com/citations?user=V3mmCdkAAAAJ&hl=es Researcher ID: http://www.researcherid.com/rid/B-8331-2008 Cosis profile: http://www.cosis.net/profile/francisco.pastor ----------- mail: [email protected] skype: paco.pastor.guzman ----------- Parque Tecnologico, C/ Charles R. Darwin, 14 46980 PATERNA (Valencia), Spain Tlf. 96 131 82 27 - Fax. 96 131 81 90
--------------------------------------------------------------------- Este mensaje y los ficheros anexos son confidenciales. Los mismos contienen informaci�n reservada de la empresa que no puede ser difundida. Si usted ha recibido este correo por error, tenga la amabilidad de eliminarlo de su sistema y avisar al remitente mediante reenv�o a su direcci�n electr�nica; no deber� copiar el mensaje ni divulgar su contenido a ninguna persona.
Su direcci�n de correo electr�nico junto a sus datos personales forman parte de un fichero titularidad de la Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213, cuya finalidad es la de mantener el contacto con Ud. De acuerdo con la Ley Org�nica 15/1999, usted puede ejercitar sus derechos de acceso, rectificaci�n, cancelaci�n y, en su caso, oposici�n enviando una solicitud por escrito, acompa�ada de una fotocopia de su DNI dirigida a: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia).
This message and the attached files are confidential. They contain reserved information belonging to our centre and are not to be broadcast. If you have received this email by mistake, please delete it from your system and alert the sender by returning it to his/her email address. You must not copy or divulge the contents of the message to anyone.
Your email address and personal data are included in a file belonging to the Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213. The purpose of this file is to allow us to keep in contact with you. In accordance with Organic Law 15/1999, you are permitted to access, rectify, cancel or oppose the contents of this file by submitting a written request, accompanied by a photocopy of your DNI, to: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia).
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- ----------- Dr. Francisco Pastor Meteorology department, Instituto Universitario CEAM-UMH http://www.ceam.es ----------- Mendeley profile: http://www.mendeley.com/profiles/francisco-pastor1/ Google Scholar: http://scholar.google.com/citations?user=V3mmCdkAAAAJ&hl=es Researcher ID: http://www.researcherid.com/rid/B-8331-2008 Cosis profile: http://www.cosis.net/profile/francisco.pastor ----------- mail: [email protected] skype: paco.pastor.guzman ----------- Parque Tecnologico, C/ Charles R. Darwin, 14 46980 PATERNA (Valencia), Spain Tlf. 96 131 82 27 - Fax. 96 131 81 90 --------------------------------------------------------------------- Este mensaje y los ficheros anexos son confidenciales. Los mismos contienen informaci�n reservada de la empresa que no puede ser difundida. Si usted ha recibido este correo por error, tenga la amabilidad de eliminarlo de su sistema y avisar al remitente mediante reenv�o a su direcci�n electr�nica; no deber� copiar el mensaje ni divulgar su contenido a ninguna persona. Su direcci�n de correo electr�nico junto a sus datos personales forman parte de un fichero titularidad de la Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213, cuya finalidad es la de mantener el contacto con Ud. De acuerdo con la Ley Org�nica 15/1999, usted puede ejercitar sus derechos de acceso, rectificaci�n, cancelaci�n y, en su caso, oposici�n enviando una solicitud por escrito, acompa�ada de una fotocopia de su DNI dirigida a: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia). This message and the attached files are confidential. They contain reserved information belonging to our centre and are not to be broadcast. If you have received this email by mistake, please delete it from your system and alert the sender by returning it to his/her email address. You must not copy or divulge the contents of the message to anyone. Your email address and personal data are included in a file belonging to the Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM, con CIF: G-46957213. The purpose of this file is to allow us to keep in contact with you. In accordance with Organic Law 15/1999, you are permitted to access, rectify, cancel or oppose the contents of this file by submitting a written request, accompanied by a photocopy of your DNI, to: Fundaci�n de la Comunidad Valenciana Centro de Estudios Ambientales del Mediterr�neo - CEAM. C/ Charles R. Darwin, 14. Parque Tecnol�gico.46980 PATERNA (Valencia).
participants (1)
Francisco Pastor
