Re: [mpich-discuss] problem on configuring MPI with slurm
Please keep the mailing list cc’ed. Run configure without those options: ./configure --prefix=/zhuxm/mpich-3.1 --enable-fast=all,03 CC=icc CXX=icpc F77=ifort FC=ifort — Pavan On May 20, 2014, at 1:02 AM, 朱学明 <[email protected]> wrote:
Pavan,
Thank you for your quickly response. Can you tell me that should I get rid of --with-slurm option only, or any other friend options, such as --with-pmi=slurm --with-pm=no ?
Can you show me the exact options what I need?
-- Xueming Zhu 朱学明 Key Laboratory of Research on Marine Hazards Forecasting (LoMF), SOA National Marine Environmental Forecasting Center (NMEFC) No.8 Dahuisi Road, Haidian District, Beijing, 100081 People's Republic of China Tel: +86-10-82481923
在 2014-05-20 14:24:44 , Balaji, Pavan <[email protected]> 写道:
We should just get rid of the --with-slurm option in MPICH. It’s pretty useless for two reasons:
1. You don’t need to configure mpich with slurm at all, unless you are planning to use srun/salloc directly. You can just build mpich normally and run with mpiexec. mpiexec will internally detect that you are using a slurm environment and use srun internally.
2. If you really want to use srun/salloc, you can just build your application with mpicc -L/path/to/slurm foo.c -lpmi and it’ll pick up slurm’s PMI library. Then you can use srun/salloc.
Xueming,
My suggestion is, forget the slurm option. Just build mpich normally and run it with mpiexec. It’ll automatically use slurm internally.
— Pavan
On May 19, 2014, at 9:28 PM, Kenneth Raffenetti <[email protected]> wrote:
configure expects a directory named slurm under the location you specify. Try using '--with-slurm=/usr/local' in your configure line instead.
Ken
On 05/19/2014 07:06 PM, 朱学明 wrote:
Hello,
I am trying to install MPICH-3.1 on our linux server with Slurm 1.2.25. I configured it with the command as follow,
./configure --prefix=/zhuxm/mpich-3.1 CC=icc CXX=icpc F77=ifort FC=ifort -enable-fast=all,O3 -enable-shared --with-rdma=gen2 --with-pmi=slurm --with-pm=no --with-slurm=/usr/local/slurm --with-ib-include=/usr/local/ib_hpc/include --with-ib-libpath=/usr/local/ib_hpc/lib64 --with-ch3-rank-bits=32 --without-mpe --without-hwloc --disable-rdma-cm -disable-fuse 2>&1 |tee config-min.log
Then I have got the error messages as follow,
Checking slurm/pmi.h usability ... no
Checking slurm/pmi.h presence... no
Checking for slurm/pmi.h... no
configure: error: could not find slurm/pmi.h. Configure aborted
Can you give mu any suggestion how to figure out the issue? Thanks.
-- *Xueming Zhu 朱学明* Key Laboratory of Research on Marine Hazards Forecasting (*LoMF*), SOA National Marine Environmental Forecasting Center (*NMEFC*) No.8 Dahuisi Road, Haidian District, Beijing, 100081 People's Republic of China Tel: +86-10-82481923
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
