Re: [mpich-discuss] Segmentation fault when MPICH is compiled with Portland compiler 17.5
I reproduced this with PGI 17.4 community edition on Linux with your Fortran test and an equivalent C one. GDB indicates the SEGV happens here: Program received signal SIGSEGV, Segmentation fault. MPID_nem_init (pg_rank=0, pg_p=0x60fce0, has_parent=8388607) at ../src/mpid/ch3/channels/nemesis/src/mpid_nem_init.c:305 305 MPID_nem_queue_enqueue(MPID_nem_mem_region.FreeQ[pg_rank], &(MPID_nem_mem_region.Elements[idx])); Jeff On Tue, Jul 11, 2017 at 1:19 AM, Andrew Wood <[email protected]> wrote:
It's hard not to conclude this is a PGI 17 bug from your description.
Have you
reported this to PGI? I would hate for the MPICH team to take support work away from the people PGI pays to do this.
Indeed, and I have done so.
However, in my experience, it tends to be somewhat unpredictable whether incorrect code causes a segmentation fault or not. So I thought it worth checking here too.
Regards, Andy.
On 10/07/17 21:17, Jeff Hammond wrote:
"This occurs with PGI versions 17.1 and 17.5, but not with versions 16.1, 16.5 or 16.7, nor with the current Intel or gcc compilers."
It's hard not to conclude this is a PGI 17 bug from your description. Have you reported this to PGI? I would hate for the MPICH team to take support work away from the people PGI pays to do this.
Jeff
On Mon, Jul 10, 2017 at 6:48 AM Andrew Wood <[email protected] <mailto:[email protected]>> wrote:
I'm getting a segmentation fault in MPI_INIT, when MPICH is compiled with the current version of the Portland compilers:
> mpif90 code.f90 && ./a.out Segmentation fault
code.f90 is in the attached .tar.gz file, along with the .log files generated by configuring and building MPICH.
This occurs with PGI versions 17.1 and 17.5, but not with versions 16.1, 16.5 or 16.7, nor with the current Intel or gcc compilers. It occurs with MPICH versions 3.1.4, 3.2 and the current master branch in the github repository.
The problem does not occur if MPICH is configured with the option '--disable-fast'.
Is this a bug in MPICH or PGI, or have I done something else wrong?
Thanks, Andy.
-- Dr Andrew Wood Fluid Gravity Engineering Ltd. 83 Market Street St Andrews Fife KY16 9NX Tel: +44 (0)1334 460805 Fax: +44 (0)1334 460813
Fluid Gravity Engineering Ltd is registered in the UK with registration number 1674369. The registered address is Fluid Gravity Engineering Ltd, Unit 1, The Old Coach House, 1 West Street, Emsworth, Hampshire, PO10 7DX. _______________________________________________ discuss mailing list [email protected] <mailto:[email protected]
To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] <mailto:[email protected]> http://jeffhammond.github.io/
Fluid Gravity Engineering Ltd is registered in the UK with registration number 1674369. The registered address is Fluid Gravity Engineering Ltd, Unit 1, The Old Coach House, 1 West Street, Emsworth, Hampshire, PO10 7DX. _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
