Re: [mpich-discuss] having problem running MPICH on multiple nodes
Now I'm getting this error with MPICH-3.2a2 Any thought? $ mpirun -hostfile hosts-hydra -np 2 test_dup Fatal error in MPI_Allreduce: Unknown error class, error stack: MPI_Allreduce(912)....................: MPI_Allreduce(sbuf=0x7fffa5240e60, rbuf=0x7fffa5240e68, count=1, MPI_DOUBLE, MPI_MAX, MPI_COMM_WORLD) failed MPIR_Allreduce_impl(769)..............: MPIR_Allreduce_intra(419).............: MPIDU_Complete_posted_with_error(1192): Process failed Fatal error in MPI_Allreduce: Unknown error class, error stack: MPI_Allreduce(912)....................: MPI_Allreduce(sbuf=0x7fffaf6ef070, rbuf=0x7fffaf6ef078, count=1, MPI_DOUBLE, MPI_MAX, MPI_COMM_WORLD) failed MPIR_Allreduce_impl(769)..............: MPIR_Allreduce_intra(419).............: MPIDU_Complete_posted_with_error(1192): Process failed =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 451 RUNNING AT oakmnt-0-a = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== Thanks. Amin Hassani, CIS department at UAB, Birmingham, AL, USA. On Tue, Nov 25, 2014 at 9:25 PM, Amin Hassani <[email protected]> wrote:
Ok, I'll try to test the alpha version. I'll let you know the results.
Thank you.
On Tue, Nov 25, 2014 at 9:21 PM, Bland, Wesley B. <[email protected]> wrote:
It’s hard to tell then. Other than some problems compiling (not declaring all of your variables), everything seems ok. Can you try running with the most recent alpha. I have no idea what bug we could have fixed here to make things work, but it’d be good to eliminate the possibility.
Thanks, Wesley
On Nov 25, 2014, at 10:11 PM, Amin Hassani <[email protected]> wrote:
Here I attached config.log exits in the root folder where it is compiled. I'm not too familiar with MPICH but, there are other config.logs in other directories also but not sure if you needed them too. I don't have any specific environment variable that can relate to MPICH. Also tried with export HYDRA_HOST_FILE=<address to host file>, but have the same problem. I don't do anything FT related in MPICH, I don't think this version of MPICH has anything related to FT in it.
Thanks.
On Tue, Nov 25, 2014 at 9:02 PM, Bland, Wesley B. <[email protected]> wrote:
Can you also provide your config.log and any CVARs or other relevant environment variables that you might be setting (for instance, in relation to fault tolerance)?
Thanks, Wesley
On Nov 25, 2014, at 3:58 PM, Amin Hassani <[email protected]> wrote:
This is the simplest code I have that doesn't run.
#include <mpi.h> #include <stdio.h> #include <malloc.h> #include <unistd.h> #include <stdlib.h>
int main(int argc, char** argv) { int rank, size; int i, j, k; double t1, t2; int rc;
MPI_Init(&argc, &argv); MPI_Comm world = MPI_COMM_WORLD, newworld, newworld2; MPI_Comm_rank(world, &rank); MPI_Comm_size(world, &size);
t2 = 1; MPI_Allreduce(&t2, &t_avg, 1, MPI_DOUBLE, MPI_SUM, world); t_avg = t_avg / size;
MPI_Finalize();
return 0; }
On Tue, Nov 25, 2014 at 2:46 PM, "Antonio J. Peña" <[email protected]> wrote:
Hi Amin,
Can you share with us a minimal piece of code with which you can reproduce this issue?
Thanks, Antonio
On 11/25/2014 12:52 PM, Amin Hassani wrote:
I am having problem running MPICH, on multiple nodes. When I run an multiple MPI processes on one node, it totally works, but when I try to run on multiple nodes, it fails with the error below. My machines have Debian OS, Both infiniband and TCP interconnects. I'm guessing it has something do to with the TCP network, but I can run openmpi on these machines with no problem. But for some reason I cannot run MPICH on multiple nodes. Please let me know if more info is needed from my side. I'm guessing there are some configuration that I am missing. I used MPICH 3.1.3 for this test. I googled this problem but couldn't find any solution.
In my MPI program, I am doing a simple allreduce over MPI_COMM_WORLD.
my host file (hosts-hydra) is something like this: oakmnt-0-a:1 oakmnt-0-b:1
I get this error:
$ mpirun -hostfile hosts-hydra -np 2 test_dup Assertion failed in file ../src/mpi/coll/helper_fns.c at line 490: status->MPI_TAG == recvtag Assertion failed in file ../src/mpi/coll/helper_fns.c at line 490: status->MPI_TAG == recvtag internal ABORT - process 1 internal ABORT - process 0
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 30744 RUNNING AT oakmnt-0-b = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
=================================================================================== [mpiexec@vulcan13] HYDU_sock_read (../../../../src/pm/hydra/utils/sock/sock.c:239): read error (Bad file descriptor) [mpiexec@vulcan13] control_cb (../../../../src/pm/hydra/pm/pmiserv/pmiserv_cb.c:199): unable to read command from proxy [mpiexec@vulcan13] HYDT_dmxu_poll_wait_for_event (../../../../src/pm/hydra/tools/demux/demux_poll.c:76): callback returned error status [mpiexec@vulcan13] HYD_pmci_wait_for_completion (../../../../src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:198): error waiting for event [mpiexec@vulcan13] main (../../../../src/pm/hydra/ui/mpich/mpiexec.c:344): process manager error waiting for completion
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe:https://lists.mpich.org/mailman/listinfo/discuss
-- Antonio J. Peña Postdoctoral Appointee Mathematics and Computer Science Division Argonne National Laboratory 9700 South Cass Avenue, Bldg. 240, Of. 3148 Argonne, IL [email protected]/~apenya
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
<config.log>_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Amin Hassani
