couldn't build mpich-master-v3.1.1-56-g9d5ce23c on Solaris 10 x86_64 with gcc-4.9.0
Hi, today I tried to build "mpich-master-v3.1.1-56-g9d5ce23c" on "Solaris 10 x86_64" with gcc-4.9.0 in a 64-bit version. I was able to configure the package with some warnings, but unable to build it. First I checked my file "log.configure.SunOS.x86_64.64_gcc" for warnings. Some warnings can be avoided, if somebody has time to change a few things in the configure script. configure: WARNING: Unknown architecture i86pc... proceeding anyway You can use "uname -p" or "uname -m" and then "isainfo -k" to check if you build the package on a 32-bit or 64-bit processor for "Solaris x86_64" . sunpc1 fd1026 108 uname -s SunOS sunpc1 fd1026 109 uname -p i386 sunpc1 fd1026 110 uname -m i86pc sunpc1 fd1026 103 isainfo -k amd64 I use the following code in the initialization script for my heterogenous environment to determine the operating system and processor architecture. setenv SYSTEM_ENV `uname -s` if (${SYSTEM_ENV} == Linux) then setenv MACHINE_ENV `uname -m` else setenv MACHINE_ENV `uname -p` if ( (${SYSTEM_ENV} == SunOS) && (${MACHINE_ENV} != sparc) ) then if (`isainfo -k` == amd64) then setenv MACHINE_ENV "x86_64" endif endif endif configure: WARNING: X11/Xutil.h: present but cannot be compiled configure: WARNING: X11/Xutil.h: check for missing prerequisite headers? configure: WARNING: X11/Xutil.h: see the Autoconf documentation configure: WARNING: X11/Xutil.h: section "Present But Cannot Be Compiled" configure: WARNING: X11/Xutil.h: proceeding with the compiler's result You can compile "X11/Xutil.h" on Solaris if you include <X11/Xlib.h> before including "X11/Xutil.h". configure: WARNING: The ch3 device did not set the maximum size of an error string, 512 being used. config.status: WARNING: '../mpich-master-v3.1.1-56-g9d5ce23c/src/packaging/envmods/mpich.module.in' seems to ignore the --datarootdir setting I don't know if the above warnings are important or not. Next I checked my file "log.make.SunOS.x86_64.64_gcc" and got the following error. ... CC adio/common/ad_prealloc.lo CC adio/common/ad_read.lo In file included from /usr/include/unistd.h:18:0, from ../../../../mpich-master-v3.1.1-56-g9d5ce23c/src/mpi/romio/adio/common/ad_read.c :10: /export2/prog/SunOS_x86_64/gcc-4.9.0/lib/gcc/i386-pc-solaris2.10/4.9.0/include-f ixed/sys/feature_tests.h:350:2: error: #error "Compiler or options invalid; UNIX 03 and POSIX.1-2001 applications require the use of c99" #error "Compiler or options invalid; UNIX 03 and POSIX.1-2001 applications \ ^ make[3]: *** [adio/common/ad_read.lo] Error 1 ... I solved this problem setting CFLAGS to "-m64 -std=c11". Starting once more with an empty directory, I got the same error as with mpich-3.1.1. ... CXX src/binding/cxx/initcxx.lo CXXLD lib/libmpicxx.la ld: fatal: file libmpicxx.so.12: open failed: No such file or directory ld: fatal: file processing errors. No output written to lib/.libs/libmpicxx.so.12.0.1 collect2: error: ld returned 1 exit status make[2]: *** [lib/libmpicxx.la] Error 1 ... I would be grateful if somebody could provide a solution for my problem. Do you need anything else? Thank you very much for any help in advance. Kind regards Siegmar
participants (1)
Siegmar Gross
