25 Jun
2026
25 Jun
'26
2:52 p.m.
as less latency than 4KB. I was looking for explanation of this behavior but did not get any. 1. MPIR_CVAR_CH3_EAGER_MAX_MSG_SIZE is set to 128KB. So none of the abov= e message size is using Rendezvous protocol. Is there any partition inside = eager protocol (e.g. 0 - 512 bytes, 1KB - 8KB, 16KB - 64KB)? If yes then wh= at are the boundaries for them? Can I log them with debug-event-logging? Setup I am using: - two nodes has intel core i7, one with 16gb memory another one 8gb - mpich 3.2.1, configured and build to use nemesis tcp - 1gb Ethernet connection - NFS is using for sharing - osu_latency: uses MPI_Send and MPI_Recv - MPIR_CVAR_CH3_EAGER_MAX_MSG_SIZE=3D 131072 (128KB) Can anyone help me on that? Thanks in advance. Best Regards, Abu Naser _______________________________________________ discuss mailing list [email protected]<mailto: [email protected]> To manage subscription options or unsubscribe: https: //lists.mpich.org/mailman/listinfo/discuss -- Jeff Hammond [email protected]<mailto: [email protected]> http: //jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected]<mailto: [email protected]> To manage subscription options or unsubscribe: https: //lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected]<mailto: [email protected]> To manage subscription options or unsubscribe: https: //lists.mpich.org/mailman/listinfo/discuss _______________________________________________ discuss mailing list [email protected]<mailto: [email protected]> To manage subscription options or unsubscribe: https: //lists.mpich.org/mailman/listinfo/discuss --_000_BLUPR0501MB2003DCD7FDB382061050A6B997430BLUPR0501MB2003_ Content-Type: text/html; charset="Windows-1252" Content-Transfer-Encoding: quoted-printable <html><head> <meta http-equiv=3D"Content-Type" content=3D"text/html; charset=3DWindows-1= 252"> <style type=3D"text/css" style=3D"display: none;"><!-- P {margin-top:0;margi= n-bottom: 0;} --></style> </head> <body dir=3D"ltr"> <div id=3D"divtagdefaultwrapper" style=3D"font-size: 12pt; color: rgb(0, 0,= 0); font-family: Calibri, Helvetica, sans-serif, "EmojiFont", &q= uot;Apple Color Emoji", "Segoe UI Emoji", NotoColorEmoji, &q= uot;Segoe UI Symbol", "Android Emoji", EmojiSymbols;" dir=3D= "ltr"> <div id=3D"divtagdefaultwrapper" style=3D"font-size: 12pt; color: rgb(0, 0,= 0); font-family: Calibri, Helvetica, sans-serif, "EmojiFont", &q= uot;Apple Color Emoji", "Segoe UI Emoji", NotoColorEmoji, &q= uot;Segoe UI Symbol", "Android Emoji", EmojiSymbols;" dir=3D= "ltr"> <p style=3D"margin-top: 0;margin-bottom:0">Hello Min,</p> <p style=3D"margin-top: 0;margin-bottom:0"><br> </p> <p style=3D"margin-top: 0;margin-bottom:0">I have downloaded it from <a href= =3D"http: //www.mpich.org/static/downloads/3.2.1/mpich-3.2.1.tar.gz" class= =3D"OWAAutoLink" id=3D"LPlnk943697" previewremoved=3D"true"> http: //www.mpich.org/static/downloads/3.2.1/mpich-3.2.1.tar.gz</a> but it d= id not work. I have received almost same error. Except this time no process= information from my remote machine.</p> <p style=3D"margin-top: 0;margin-bottom:0"><b>Previously I have received thi= s - </b> <br> </p> <p style=3D"margin-top: 0;margin-bottom:0"></p> <div style=3D""><i><span style=3D"font-size: 10pt; color: rgb(255, 0, 0);">= Process 3 of 4 is on dhcp16194</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt; color: rgb(255, 0, 0);">= Process 1 of 4 is on dhcp16194</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt; color: rgb(255, 0, 0);">= Process 0 of 4 is on dhcp16198</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt; color: rgb(255, 0, 0);">= Process 2 of 4 is on dhcp16198</span></i></div> <p></p> <p style=3D"margin-top: 0;margin-bottom:0"><b>With the new source code -</b>= </p> <p style=3D"margin-top: 0;margin-bottom:0"></p> <div><i><span style=3D"font-size: 10pt; color: rgb(255, 0, 0);">Process 0 o= f 4 is on dhcp16198</span></i></div> <div><i><span style=3D"font-size: 10pt; color: rgb(255, 0, 0);">Process 2 o= f 4 is on dhcp16198</span></i></div> <p></p> <p style=3D"margin-top: 0;margin-bottom:0"><br> </p> <p style=3D"margin-top: 0;margin-bottom:0"><b>Entire error message is:</b></= p> <p style=3D"margin-top: 0;margin-bottom:0"></p> <div><i><span style=3D"font-size: 10pt;">Process 0 of 4 is on dhcp16198</sp= an></i></div> <div><i><span style=3D"font-size: 10pt;">Process 2 of 4 is on dhcp16198</sp= an></i></div> <div><i><span style=3D"font-size: 10pt;">Fatal error in PMPI_Bcast: Unknown= error class, error stack:</span></i></div> <div><i><span style=3D"font-size: 10pt;">PMPI_Bcast(1600)..................= ..........: MPI_Bcast(buf=3D0x7ffd1ee145f0, count=3D1, MPI_INT, root=3D0, M= PI_COMM_WORLD) failed</span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_Bcast_impl(1452).............= ..........: </span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_Bcast(1476)..................= ..........: </span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_Bcast_intra(1249)............= ..........: </span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_SMP_Bcast(1081)..............= ..........: </span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_Bcast_binomial(285)..........= ..........: </span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIC_Send(303)....................= ..........: </span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIC_Wait(226)....................= ..........: </span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIDI_CH3i_Progress_wait(242).....= ..........: an error occurred while handling an event returned by MPIDU_Soc= k_Wait()</span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIDI_CH3I_Progress_handle_sock_ev= ent(698)..: </span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIDI_CH3_Sockconn_handle_connect_= event(597): [ch3:sock] failed to connnect to remote process</span></i></div= > <div><i><span style=3D"font-size: 10pt;">MPIDU_Socki_handle_connect(808)...= ..........: connection failure (set=3D0,sock=3D1,errno=3D111:Connection ref= used)</span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_SMP_Bcast(1088)..............= ..........: </span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_Bcast_binomial(310)..........= ..........: Failure during collective</span></i></div> <div><i><span style=3D"font-size: 10pt;">Fatal error in PMPI_Bcast: Other M= PI error, error stack: </span></i></div> <div><i><span style=3D"font-size: 10pt;">PMPI_Bcast(1600)........: MPI_Bcas= t(buf=3D0x7ffe2eeb90f0, count=3D1, MPI_INT, root=3D0, MPI_COMM_WORLD) faile= d</span></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_Bcast_impl(1452)...: </s= pan></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_Bcast(1476)........: </s= pan></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_Bcast_intra(1249)..: </s= pan></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_SMP_Bcast(1088)....: </s= pan></i></div> <div><i><span style=3D"font-size: 10pt;">MPIR_Bcast_binomial(310): Failure = during collective</span></i></div> <br> <p></p> <p style=3D"margin-top: 0;margin-bottom:0">Again if I configure the new sour= ce with tcp, it works fine.</p> <p style=3D"margin-top: 0;margin-bottom:0"><br> </p> <p style=3D"margin-top: 0;margin-bottom:0">Thank You.<br> </p> <div id=3D"Signature"> <div id=3D"divtagdefaultwrapper" dir=3D"ltr" style=3D"font-size: 12pt; color= : rgb(0,0,0); font-family:Calibri,Helvetica,sans-serif,"EmojiFont"= ,"Apple Color Emoji","Segoe UI Emoji",NotoColorEmoji,&q= uot;Segoe UI Symbol","Android Emoji",EmojiSymbols"> <p><br> </p> <p align=3D"left"><span style=3D"font-size: 10pt; font-family:Calibri,Helvet= ica,sans-serif">Best Regards,</span></p> <span style=3D"font-family: Calibri,Helvetica,sans-serif; font-size:10pt"></= span> <div align=3D"left"><span style=3D"font-size: 11pt; font-family:Calibri,Helv= etica,sans-serif"></span></div> <span style=3D"font-family: Calibri,Helvetica,sans-serif; font-size:10pt"></= span> <p align=3D"left"><span style=3D"font-size: 10pt; font-family:Calibri,Helvet= ica,sans-serif">Abu Naser</span><br> </p> </div> </div> </div> <hr style=3D"display: inline-block;width:98%" tabindex=3D"-1"> <div id=3D"divRplyFwdMsg" dir=3D"ltr"><font style=3D"font-size: 11pt" face= =3D"Calibri, sans-serif" color=3D"#000000"><b>From: </b> Min Si <msi@anl.= gov><br> <b>Sent: </b> Monday, July 2, 2018 11:56:51 AM<br> <b>To: </b> [email protected]<br> <b>Subject: </b> Re: [mpich-discuss] osu_latency test: why 8KB takes less ti= me than 4KB and 2KB takes less time than 1KB?</font> <div> </div> </div> <meta content=3D"text/html; charset=3DWindows-1252"> <div style=3D"background-color: #FFFFFF">Hi Abu,<br> <br> Thanks for reporting this. Can you please try the latest release with ch3/s= ock and see if you still have this error ? <br> <br> Min<br> <div class=3D"x_moz-cite-prefix">On 2018/07/01 21: 47, Abu Naser wrote:<br> </div> <blockquote type=3D"cite"> <div id=3D"x_divtagdefaultwrapper" dir=3D"ltr" style=3D"font-size: 12pt; co= lor: rgb(0, 0, 0); font-family: Calibri, Helvetica, sans-serif, "Emoji= Font", "Apple Color Emoji", "Segoe UI Emoji", Noto= ColorEmoji, "Segoe UI Symbol", "Android Emoji", EmojiSy= mbols;"> <div id=3D"x_divtagdefaultwrapper" dir=3D"ltr" style=3D""> <p style=3D"">Hello Min,</p> <p style=3D""><br> </p> <p style=3D"">After compiling my mpich-3.2.1 with sock, while I was trying = to run any program including osu benchmark or examples/cpi&= nbsp; in two machines, I have received following error -</p> <p style=3D""><br> </p> <div style=3D""><i><span style=3D"font-size: 10pt">Process 3 of 4 is on dhcp= 16194</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">Process 1 of 4 is on dhcp= 16194</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">Process 0 of 4 is on dhcp= 16198</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">Process 2 of 4 is on dhcp= 16198</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">Fatal error in PMPI_Bcast= : Unknown error class, error stack:</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">PMPI_Bcast(1600).........= ...................: MPI_Bcast(buf=3D0x7ffc1808542c, count=3D1, MPI_INT, ro= ot=3D0, MPI_COMM_WORLD) failed</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_Bcast_impl(1452)....= ...................: </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_Bcast(1476).........= ...................: </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_Bcast_intra(1249)...= ...................: </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_SMP_Bcast(1081).....= ...................: </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_Bcast_binomial(285).= ...................: </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIC_Send(303)...........= ...................: </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIC_Wait(226)...........= ...................: </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIDI_CH3i_Progress_wait(= 242)...............: an error occurred while handling an event returned by = MPIDU_Sock_Wait()</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIDI_CH3I_Progress_handl= e_sock_event(698)..: </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIDI_CH3_Sockconn_handle= _connect_event(597): [ch3:sock] failed to connnect to remote process</span>= </i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIDU_Socki_handle_connec= t(808).............: connection failure (set=3D0,sock=3D1,errno=3D111:Conne= ction refused)</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_SMP_Bcast(1088).....= ...................: </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_Bcast_binomial(310).= ...................: Failure during collective</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">Fatal error in PMPI_Bcast= : Other MPI error, error stack:</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">PMPI_Bcast(1600)........:= MPI_Bcast(buf=3D0x7ffd9eeebdac, count=3D1, MPI_INT, root=3D0, MPI_COMM_WOR= LD) failed</span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_Bcast_impl(1452)...:= </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_Bcast(1476)........:= </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_Bcast_intra(1249)..:= </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_SMP_Bcast(1088)....:= </span></i></div> <div style=3D""><i><span style=3D"font-size: 10pt">MPIR_Bcast_binomial(310):= Failure during collective</span></i></div> <br style=3D""> <p style=3D""></p> <p style=3D""><span style=3D"font-size: 12pt">I checked the mpich FAQ a= nd also mpich discussion list. Based on that I have checked </span>fol= lowings<span style=3D"font-size: 12pt"> </span><span style=3D"font-size= : 12pt">and found they are fine in my machines -</span><br> </p> <p style=3D""><span style=3D"font-size: 12pt">- firewall is disabled in both= machine</span></p> <p style=3D""><span style=3D"font-size: 12pt">- I can do </span>passwor= d less<span style=3D"font-size: 12pt"> ssh in both machine</span></p> <p style=3D""><span style=3D"font-size: 12pt">- /etc/hosts in both machine c= onfigured with ip address and name properly</span></p> <p style=3D""><span style=3D"font-size: 12pt">- I have updated the library p= ath and used absolute path for mpiexec</span></p> <p style=3D""><span style=3D"font-size: 12pt">- Most importantly when I conf= igured and build mpich with tcp, it works fine.</span></p> <p style=3D""><span style=3D"font-size: 12pt"><br> </span></p> <p style=3D""><span style=3D"font-size: 12pt"> I think I am </span= ><span style=3D"font-size: 12pt">missing something but could not figure out = yet. Any help would be </span>appreciated<span style=3D"font-size: 12pt">.</span></p> <p style=3D""><span style=3D"font-size: 12pt"><br> </span></p> <p style=3D""><span style=3D"font-size: 12pt">Thank you.</span></p> <br> <p style=3D""><br> </p> <p style=3D""><br> </p> <p style=3D""><br> </p> <div id=3D"x_Signature" style=3D""> <div id=3D"x_divtagdefaultwrapper" dir=3D"ltr" style=3D""> <p><br> </p> <p align=3D"left"><span style=3D"font-size: 10pt; font-family:Calibri,Helvet= ica,sans-serif">Best Regards,</span></p> <span style=3D"font-family: Calibri,Helvetica,sans-serif; font-size:10pt"></= span> <div align=3D"left"><span style=3D"font-size: 11pt; font-family:Calibri,Helv= etica,sans-serif"></span></div> <span style=3D"font-family: Calibri,Helvetica,sans-serif; font-size:10pt"></= span> <p align=3D"left"><span style=3D"font-size: 10pt; font-family:Calibri,Helvet= ica,sans-serif">Abu Naser</span><br> </p> </div> </div> </div> <hr style=3D"display: inline-block; width:98%" tabindex=3D"-1"> <div id=3D"x_divRplyFwdMsg" dir=3D"ltr"><font style=3D"font-size: 11pt" face= =3D"Calibri, sans-serif" color=3D"#000000"><b>From: </b> Min Si <a class=3D"x_moz-txt-link-rfc2396E OWAAutoLink" href=3D"mailto: [email protected]= " id=3D"LPlnk191149" previewremoved=3D"true"> <[email protected]></a><br> <b>Sent: </b> Tuesday, June 26, 2018 12:54:29 PM<br> <b>To: </b> <a class=3D"x_moz-txt-link-abbreviated OWAAutoLink" href=3D"mail= to: [email protected]" id=3D"LPlnk414203" previewremoved=3D"true"> [email protected]</a><br> <b>Subject: </b> Re: [mpich-discuss] osu_latency test: why 8KB takes less ti= me than 4KB and 2KB takes less time than 1KB?</font> <div> </div> </div> <meta content=3D"text/html; charset=3DWindows-1252"> <div style=3D"background-color: #FFFFFF">Hi Abu,<br> <br> I think the results are stable enough. Perhaps you could also try the follo= wing tests, and see if similar trend exists: <br> - MPICH/socket (set `--with-device=3Dch3: sock` at configure)<br> - A socket-based pingpong test without MPI. <br> <br> At this point, I could not think of any MPI-specific design for 2k/8k messa= ges. My guess is that it is related to your network connection. <br> <br> Min<br> <br> <div class=3D"x_x_moz-cite-prefix">On 2018/06/24 11: 09, Abu Naser wrote:<br= > </div> <blockquote type=3D"cite"> <meta content=3D"text/html; charset=3DWindows-1252"> <div id=3D"x_x_divtagdefaultwrapper" dir=3D"ltr"> <div id=3D"x_x_divtagdefaultwrapper" dir=3D"ltr"> <p>Hello Min and Jeff,</p> <p><br> </p> <p>Here is my experiment results. Default number of iterations in osu_= latency for 0B =96 8KB is 10,000. With that setting I had run the osu_laten= cy 100 times and found standard deviation 33 for 8KB message size.</p> <p><br> </p> <p>So later I have set the iteration to 50,000 and 100,000 for 1KB =96 16KB= message size. Then run osu_latency for 100 times for each setting and take= the average and standard deviation.</p> <p><br> </p> <table width=3D"665"> <colgroup><col width=3D"99"><col width=3D"112"><col width=3D"118"><col widt= h=3D"154"><col width=3D"140"></colgroup> <tbody> <tr> <td width=3D"99"> <p><b>Msg Size in Bytes</b></p> </td> <td width=3D"112"> <p><b>Avg time in us (50K iterations)</b></p> </td> <td width=3D"118"> <p><b>Avg time in us (100k iterations)</b></p> </td> <td width=3D"154"> <p><b>Standard deviation (50K iterations)</b></p> </td> <td width=3D"140"> <p><b>Standard deviation (100K iterations)</b></p> </td> </tr> <tr> <td width=3D"99"> <p>1k</p> </td> <td width=3D"112"> <p>85.10</p> </td> <td width=3D"118"> <p>84.9</p> </td> <td width=3D"154"> <p>0.55</p> </td> <td width=3D"140"> <p>0.45</p> </td> </tr> <tr> <td width=3D"99"> <p>2k</p> </td> <td width=3D"112"> <p>75.79</p> </td> <td width=3D"118"> <p>74.63</p> </td> <td width=3D"154"> <p>5.09</p> </td> <td width=3D"140"> <p>4.44</p> </td> </tr> <tr> <td width=3D"99"> <p>4k</p> </td> <td width=3D"112"> <p>273.80</p> </td> <td width=3D"118"> <p>274.71</p> </td> <td width=3D"154"> <p>4.18</p> </td> <td width=3D"140"> <p>2.45</p> </td> </tr> <tr> <td width=3D"99"> <p>8k</p> </td> <td width=3D"112"> <p>258.56</p> </td> <td width=3D"118"> <p>249.83</p> </td> <td width=3D"154"> <p>21.14</p> </td> <td width=3D"140"> <p>28</p> </td> </tr> <tr> <td width=3D"99" height=3D"24"> <p>16k</p> </td> <td width=3D"112"> <p>281.31</p> </td> <td width=3D"118"> <p>281.02</p> </td> <td width=3D"154"> <p>3.22</p> </td> <td width=3D"140"> <p>4.10</p> </td> </tr> </tbody> </table> <p><br> </p> <p><br> </p> <p>The standard deviation of 8K message is so high and that implies it actu= ally not producing any consistent latency time. Looks like that's the = reason for 8K is taking less time than 4K.</p> <p><br> </p> <p>Meanwhile, 2K has standard deviation less than 5 but 1K message latency = timing are more densely populated than 2K. So probably this is the explanat= ion for 2K message less latency time.</p> <p><br> </p> <p>Thank you for your suggestions.</p> <br> <p><br> </p> <div id=3D"x_x_Signature"> <div id=3D"x_x_divtagdefaultwrapper" dir=3D"ltr"> <p><br> </p> <p><span>Best Regards,</span></p> <span></span> <div><span></span></div> <span></span> <p><span>Abu Naser</span><br> </p> </div> </div> </div> <hr tabindex=3D"-1"> <div id=3D"x_x_divRplyFwdMsg" dir=3D"ltr"><b>From: </b> Abu Naser<br> <b>Sent: </b> Wednesday, June 20, 2018 1:48:53 PM<br> <b>To: </b> <a class=3D"x_x_moz-txt-link-abbreviated x_OWAAutoLink" href=3D"= mailto: [email protected]" id=3D"LPlnk729146" previewremoved=3D"true"> [email protected]</a><br> <b>Subject: </b> Re: [mpich-discuss] osu_latency test: why 8KB takes less ti= me than 4KB and 2KB takes less time than 1KB? <div> </div> </div> <meta content=3D"text/html; charset=3Diso-8859-1"> <div dir=3D"ltr"> <div id=3D"x_x_x_divtagdefaultwrapper" dir=3D"ltr"> <div id=3D"x_x_x_divtagdefaultwrapper" dir=3D"ltr"> <p>Hello Min,</p> <p><br> </p> <p>Thanks for the clarification. I will do the experiment.<br> </p> <p><br> </p> <div id=3D"x_x_x_Signature"> <div id=3D"x_x_x_divtagdefaultwrapper" dir=3D"ltr"> <p>Thanks.</p> <p><span>Best Regards,</span></p> <span></span> <div><span></span></div> <span></span> <p><span>Abu Naser</span><br> </p> </div> </div> </div> <hr tabindex=3D"-1"> <div id=3D"x_x_x_divRplyFwdMsg" dir=3D"ltr"><b>From: </b> Min Si <a class=3D= "x_x_moz-txt-link-rfc2396E x_OWAAutoLink" href=3D"mailto: [email protected]" id=3D= "LPlnk558260" previewremoved=3D"true"> <[email protected]></a><br> <b>Sent: </b> Wednesday, June 20, 2018 1:39:30 PM<br> <b>To: </b> <a class=3D"x_x_moz-txt-link-abbreviated x_OWAAutoLink" href=3D"= mailto: [email protected]" id=3D"LPlnk472728" previewremoved=3D"true"> [email protected]</a><br> <b>Subject: </b> Re: [mpich-discuss] osu_latency test: why 8KB takes less ti= me than 4KB and 2KB takes less time than 1KB? <div> </div> </div> <meta content=3D"text/html; charset=3DWindows-1252"> <div>Hi Abu,<br> <br> I think Jeff means that you should run your experiment with more iterations= in order to get a stable results.<br> - Increase the iteration of for loop in each execution (I think osu benchma= rk allows you to set it)<br> - Run the experiments 10 or 100 times, and take the average and standard de= viation.<br> <br> If you see a very small standard deviation (e.g., <=3D5%), then the tren= d is stable and you might not see such gaps.<br> <br> Best regards,<br> Min<br> <div class=3D"x_x_x_x_moz-cite-prefix">On 2018/06/20 12: 14, Abu Naser wrote= : <br> </div> <blockquote type=3D"cite"> <div id=3D"x_x_x_x_divtagdefaultwrapper" dir=3D"ltr"> <p>Hello Jeff,</p> <p><br> </p> <p>Yes, I am using a switch and other machines are also connected with= that switch. <br> </p> <p>If I remove other machines and just use my two node with the switch, the= n will it improve the performance by 200 ~ 400 iterations?</p> <p>Meanwhile I will give a try with a single dedicated cable. <span></span>= <br> </p> <p><br> </p> <p>Thank you.<br> </p> <div id=3D"x_x_x_x_Signature"> <div id=3D"x_x_x_x_divtagdefaultwrapper" dir=3D"ltr"> <p><br> </p> <p><span>Best Regards,</span></p> <span></span> <div><span></span></div> <span></span> <p><span>Abu Naser</span><br> </p> </div> </div> </div> <hr tabindex=3D"-1"> <div id=3D"x_x_x_x_divRplyFwdMsg" dir=3D"ltr"><b>From: </b> Jeff Hammond <a = class=3D"x_x_x_x_moz-txt-link-rfc2396E x_x_x_OWAAutoLink" href=3D"mailto: je= [email protected]" id=3D"LPlnk983157" previewremoved=3D"true"> <[email protected]></a><br> <b>Sent: </b> Wednesday, June 20, 2018 12:52:06 PM<br> <b>To: </b> MPICH<br> <b>Subject: </b> Re: [mpich-discuss] osu_latency test: why 8KB takes less ti= me than 4KB and 2KB takes less time than 1KB? <div> </div> </div> <meta content=3D"text/html; charset=3Dutf-8"> <div> <div dir=3D"ltr">Is the ethernet connection a single dedicated cable betwee= n the two machines or are you running through a switch that handles other t= raffic? <div><br> </div> <div>My best guess is that this is noise and that you may be able to avoid = it by running a very long time, e.g. 10000 iterations.</div> <div><br> </div> <div>Jeff</div> </div> <div class=3D"x_x_x_x_x_gmail_extra"><br> <div class=3D"x_x_x_x_x_gmail_quote">On Wed, Jun 20, 2018 at 6: 53 AM, Abu N= aser <span dir=3D"ltr"> <<a href=3D"mailto: [email protected]" target=3D"_blank" id=3D"LPlnk305789= " class=3D"x_x_x_OWAAutoLink" previewremoved=3D"true">[email protected]</a>&= gt;</span> wrote: <br> <blockquote class=3D"x_x_x_x_x_gmail_quote"> <div dir=3D"ltr"> <div id=3D"x_x_x_x_x_m_6077755676379859201divtagdefaultwrapper" dir=3D"ltr"= > <p><br> </p> <p>Good day to all,</p> <p><br> </p> <p>I had run point to point osu_latency test in two nodes for 200 times.&nb= sp; Followings are the average time in microsecond for various size of the = messages -</p> <div>1KB 84.8514 us<br> <span>2KB 73.52535</span> us<br> 4KB 272.55275 us<br> <span>8KB 234.86385</span> us<br> 16KB 288.88 us<br> 32KB 523.3725 us<br> 64KB 910.4025 us</div> <p><br> </p> <p>From the above looks like, 2KB message has less latency than 1 KB and 8K= B has less latency than 4KB. <br> </p> <p>I was looking for explanation of this behavior but did not get any= .</p> <p><br> </p> <ol> <li><span>MPIR_CVAR_CH3_EAGER_MAX_MSG_<wbr>SIZE</span><span> is set to 128K= B. So none of the above message size is using Rendezvous protocol. Is there= any partition inside eager protocol (e.g. 0 - 512 bytes, 1KB - 8KB, 16KB -= 64KB)? If yes then what are the boundaries for them? Can I log them with debug-event-logging? </span><br> </li></ol> <p><br> </p> <p>Setup I am using: </p> <p>- two nodes has intel core i7, one with 16gb memory another one 8gb</p> <p>- mpich 3.2.1, configured and build to use nemesis tcp</p> <p>- 1gb Ethernet connection</p> <p>- NFS is using for sharing<br> </p> <p>- osu_latency: uses MPI_Send and MPI_Recv</p> <p>- <span>MPIR_CVAR_CH3_EAGER_MAX_MSG_<wbr>SIZE</span>=3D <span>131072</sp= an> (128KB)<br> </p> <p><br> </p> <p>Can anyone help me on that? Thanks in advance.<br> </p> <p><br> </p> <p><br> </p> <div id=3D"x_x_x_x_x_m_6077755676379859201Signature"> <div id=3D"x_x_x_x_x_m_6077755676379859201divtagdefaultwrapper" dir=3D"ltr"= > <p><br> </p> <p><span>Best Regards,</span></p> <span></span> <div><span></span></div> <span></span> <p><span>Abu Naser</span><br> </p> </div> </div> </div> </div> <br> ______________________________<wbr>_________________<br> discuss mailing list <a href=3D"mailto: [email protected]= " id=3D"LPlnk816471" class=3D"x_x_x_OWAAutoLink" previewremoved=3D"true">di= [email protected]</a><br> To manage subscription options or unsubscribe: <br> <a href=3D"https: //lists.mpich.org/mailman/listinfo/discuss" rel=3D"norefer= rer" target=3D"_blank" id=3D"LPlnk624595" class=3D"x_x_x_OWAAutoLink" previ= ewremoved=3D"true">https: //lists.mpich.org/<wbr>mailman/listinfo/discuss</a= ><br> <br> </blockquote> </div> <br> <br> <div><br> </div> -- <br> <div class=3D"x_x_x_x_x_gmail_signature">Jeff Hammond<br> <a href=3D"mailto: [email protected]" target=3D"_blank" id=3D"LPlnk3149= 93" class=3D"x_x_x_OWAAutoLink" previewremoved=3D"true">jeff.science@gmail.= com</a><br> <a href=3D"http: //jeffhammond.github.io/" target=3D"_blank" id=3D"LPlnk8614= 34" class=3D"x_x_x_OWAAutoLink" previewremoved=3D"true">http: //jeffhammond.= github.io/</a></div> </div> </div> <br> <fieldset class=3D"x_x_x_x_mimeAttachmentHeader"></fieldset> <br> <pre>_______________________________________________=0A= discuss mailing list <a class=3D"x_x_x_x_moz-txt-link-abbreviated x_x_x= _OWAAutoLink" href=3D"mailto: [email protected]" id=3D"LPlnk657371" previewr= emoved=3D"true">[email protected]</a>=0A= To manage subscription options or unsubscribe: =0A= <a class=3D"x_x_x_x_moz-txt-link-freetext x_x_x_OWAAutoLink" href=3D"https: = //lists.mpich.org/mailman/listinfo/discuss" id=3D"LPlnk669988" previewremov= ed=3D"true">https: //lists.mpich.org/mailman/listinfo/discuss</a>=0A= </pre> </blockquote> <br> </div> </div> </div> </div> <br> <fieldset class=3D"x_x_mimeAttachmentHeader"></fieldset> <br> <pre>_______________________________________________=0A= discuss mailing list <a class=3D"x_x_moz-txt-link-abbreviated x_OWAAuto= Link" href=3D"mailto: [email protected]" id=3D"LPlnk832953" previewremoved= =3D"true">[email protected]</a>=0A= To manage subscription options or unsubscribe: =0A= <a class=3D"x_x_moz-txt-link-freetext x_OWAAutoLink" href=3D"https: //lists.= mpich.org/mailman/listinfo/discuss" id=3D"LPlnk481779" previewremoved=3D"tr= ue">https: //lists.mpich.org/mailman/listinfo/discuss</a>=0A= </pre> </blockquote> <br> </div> </div> <br> <fieldset class=3D"x_mimeAttachmentHeader"></fieldset> <br> <pre>_______________________________________________=0A= discuss mailing list <a class=3D"x_moz-txt-link-abbreviated OWAAutoLink= " href=3D"mailto: [email protected]" id=3D"LPlnk408695" previewremoved=3D"tr= ue">[email protected]</a>=0A= To manage subscription options or unsubscribe: =0A= <a class=3D"x_moz-txt-link-freetext OWAAutoLink" href=3D"https: //lists.mpic= h.org/mailman/listinfo/discuss" id=3D"LPlnk572504" previewremoved=3D"true">= https: //lists.mpich.org/mailman/listinfo/discuss</a>=0A= </pre> </blockquote> <br> </div> </div> </body> </html> --_000_BLUPR0501MB2003DCD7FDB382061050A6B997430BLUPR0501MB2003_-- --===============0610270028680441889== Content-Type: text/plain; charset="us-ascii" Content-Transfer-Encoding: 7bit Content-Disposition: inline _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https: //lists.mpich.org/mailman/listinfo/discuss --===============0610270028680441889==-- Message-ID: <[email protected]>
26
Age (days ago)
26
Last active (days ago)
0 comments
1 participants
participants (1)
None
