Re: [mpich-discuss] [Openmp-dev] Libomptarget fatal error 1: failure of target construct while offloading is mandatory
Hi George,
The problem was related to parallel reduction. Jonas Hahnfeld submitted a patch (thanks Jonas). Your code must now work.
Jonas, thank you very much for your patch.
Please update your copy of libomptarget and recompile it. Let us know if there are any further issues.
It seems to work now. Do you know, why I get more or less the same execution time for CPU and GPU? I would have expected a smaller value for the GPU. loki introduction 143 clang -fopenmp -fopenmp-targets=nvptx64-nvidia-cuda dot_prod_accelerator_OpenMP.c loki introduction 144 /usr/bin/time -p a.out Number of processors: 24 Number of devices: 1 Default device: 0 Is initial device: 1 sum = 6.000000e+08 real 3.93 user 0.66 sys 2.64 loki introduction 145 clang -fopenmp -fopenmp-targets=x86_64-pc-linux-gnu dot_prod_accelerator_OpenMP.c loki introduction 146 /usr/bin/time -p a.out Number of processors: 24 Number of devices: 4 Default device: 0 Is initial device: 1 sum = 6.000000e+08 real 3.51 user 10.35 sys 6.04 loki introduction 147 Best regards and thank you very much for all help once more Siegmar
George
---------------------------------------------------------------------------------------------------------------------------------------------------------------- *From:* Siegmar Gross <[email protected]> *Sent:* 01 October 2018 15:59 *To:* George Rokos; llvm-openmp-dev *Subject:* Re: [Openmp-dev] Libomptarget fatal error 1: failure of target construct while offloading is mandatory Hi George,
thank you very much for your suggestions.
Apparently your application fails to offload to the GPU. And because offloading is mandatory (that's the default behavior) the library terminates the application.
Can you compile libomptarget in debug mode and run the app with LIBOMPTARGET_DEBUG=1 to see the debug output? That will help us identify the problem.
loki introduction 115 clang -fopenmp -fopenmp-targets=nvptx64-nvidia-cuda dot_prod_accelerator_OpenMP.c loki introduction 116 a.out Number of processors: 24 Number of devices: 1 Default device: 0 Is initial device: 1 Libomptarget fatal error 1: failure of target construct while offloading is mandatory
loki introduction 117 setenv LIBOMPTARGET_DEBUG 1 loki introduction 118 a.out Libomptarget --> Loading RTLs... Libomptarget --> Loading library 'libomptarget.rtl.ppc64.so'... Libomptarget --> Unable to load library 'libomptarget.rtl.ppc64.so': libomptarget.rtl.ppc64.so: cannot open shared object file: No such file or directory! Libomptarget --> Loading library 'libomptarget.rtl.x86_64.so'... Libomptarget --> Successfully loaded library 'libomptarget.rtl.x86_64.so'! Libomptarget --> Registering RTL libomptarget.rtl.x86_64.so supporting 4 devices! Libomptarget --> Loading library 'libomptarget.rtl.cuda.so'... Target CUDA RTL --> Start initializing CUDA Libomptarget --> Successfully loaded library 'libomptarget.rtl.cuda.so'! Libomptarget --> Registering RTL libomptarget.rtl.cuda.so supporting 1 devices! Libomptarget --> Loading library 'libomptarget.rtl.aarch64.so'... Libomptarget --> Unable to load library 'libomptarget.rtl.aarch64.so': libomptarget.rtl.aarch64.so: cannot open shared object file: No such file or directory! Libomptarget --> RTLs loaded! Libomptarget --> Image 0x0000000000602090 is NOT compatible with RTL libomptarget.rtl.x86_64.so! Libomptarget --> Image 0x0000000000602090 is compatible with RTL libomptarget.rtl.cuda.so! Libomptarget --> RTL 0x00000000609f95d0 has index 0! Libomptarget --> Registering image 0x0000000000602090 with RTL libomptarget.rtl.cuda.so! Libomptarget --> Done registering entries! Libomptarget --> Call to omp_get_num_devices returning 1 Libomptarget --> Default TARGET OFFLOAD policy is now mandatory (devicew were found) Libomptarget --> Entering target region with entry point 0x00000000004012d0 and device Id -1 Libomptarget --> Checking whether device 0 is ready. Libomptarget --> Is the device 0 (local ID 0) initialized? 0 Target CUDA RTL --> Getting device 0 Target CUDA RTL --> Max CUDA blocks per grid 2147483647 exceeds the hard team limit 65536, capping at the hard limit Target CUDA RTL --> Using 1024 CUDA threads per block Target CUDA RTL --> Max number of CUDA blocks 65536, threads 1024 & warp size 32 Target CUDA RTL --> Default number of teams set according to library's default 128 Target CUDA RTL --> Default number of threads set according to library's default 128 Libomptarget --> Device 0 is ready to use. Target CUDA RTL --> Load data from image 0x0000000000602090 Target CUDA RTL --> CUDA module successfully loaded! Target CUDA RTL --> Entry point 0x0000000000000000 maps to __omp_offloading_2b_1890d30_main_l48 (0x0000000060f23320) Target CUDA RTL --> Entry point 0x0000000000000001 maps to __omp_offloading_2b_1890d30_main_l67 (0x0000000060f27c70) Target CUDA RTL --> Sending global device environment data 4 bytes Libomptarget --> Entry 0: Base=0x0000000000613bf0, Begin=0x0000000000613bf0, Size=800000000, Type=0x22 Libomptarget --> Entry 1: Base=0x00000000301043f0, Begin=0x00000000301043f0, Size=800000000, Type=0x22 Libomptarget --> Looking up mapping(HstPtrBegin=0x0000000000613bf0, Size=800000000)... Libomptarget --> Creating new map entry: HstBase=0x0000000000613bf0, HstBegin=0x0000000000613bf0, HstEnd=0x00000000301043f0, TgtBegin=0x0000000b08c20000 Libomptarget --> There are 800000000 bytes allocated at target address 0x0000000b08c20000 - is new Libomptarget --> Looking up mapping(HstPtrBegin=0x00000000301043f0, Size=800000000)... Libomptarget --> Creating new map entry: HstBase=0x00000000301043f0, HstBegin=0x00000000301043f0, HstEnd=0x000000005fbf4bf0, TgtBegin=0x0000000b38720000 Libomptarget --> There are 800000000 bytes allocated at target address 0x0000000b38720000 - is new Libomptarget --> Looking up mapping(HstPtrBegin=0x0000000000613bf0, Size=800000000)... Libomptarget --> Mapping exists with HstPtrBegin=0x0000000000613bf0, TgtPtrBegin=0x0000000b08c20000, Size=800000000, RefCount=1 Libomptarget --> Obtained target argument 0x0000000b08c20000 from host pointer 0x0000000000613bf0 Libomptarget --> Looking up mapping(HstPtrBegin=0x00000000301043f0, Size=800000000)... Libomptarget --> Mapping exists with HstPtrBegin=0x00000000301043f0, TgtPtrBegin=0x0000000b38720000, Size=800000000, RefCount=1 Libomptarget --> Obtained target argument 0x0000000b38720000 from host pointer 0x00000000301043f0 Libomptarget --> Launching target execution __omp_offloading_2b_1890d30_main_l48 with pointer 0x0000000060ee2ee0 (index=0). Target CUDA RTL --> Setting CUDA threads per block to default 128 Target CUDA RTL --> Using requested number of teams 1 Target CUDA RTL --> Launch kernel with 1 blocks and 128 threads Target CUDA RTL --> Launch of entry point at 0x0000000060ee2ee0 successful! Target CUDA RTL --> Kernel execution at 0x0000000060ee2ee0 successful! Libomptarget --> Looking up mapping(HstPtrBegin=0x00000000301043f0, Size=800000000)... Libomptarget --> Mapping exists with HstPtrBegin=0x00000000301043f0, TgtPtrBegin=0x0000000b38720000, Size=800000000, updated RefCount=1 Libomptarget --> There are 800000000 bytes allocated at target address 0x0000000b38720000 - is last Libomptarget --> Moving 800000000 bytes (tgt:0x0000000b38720000) -> (hst:0x00000000301043f0) Libomptarget --> Looking up mapping(HstPtrBegin=0x00000000301043f0, Size=800000000)... Libomptarget --> Deleting tgt data 0x0000000b38720000 of size 800000000 Libomptarget --> Removing mapping with HstPtrBegin=0x00000000301043f0, TgtPtrBegin=0x0000000b38720000, Size=800000000 Libomptarget --> Looking up mapping(HstPtrBegin=0x0000000000613bf0, Size=800000000)... Libomptarget --> Mapping exists with HstPtrBegin=0x0000000000613bf0, TgtPtrBegin=0x0000000b08c20000, Size=800000000, updated RefCount=1 Libomptarget --> There are 800000000 bytes allocated at target address 0x0000000b08c20000 - is last Libomptarget --> Moving 800000000 bytes (tgt:0x0000000b08c20000) -> (hst:0x0000000000613bf0) Libomptarget --> Looking up mapping(HstPtrBegin=0x0000000000613bf0, Size=800000000)... Libomptarget --> Deleting tgt data 0x0000000b08c20000 of size 800000000 Libomptarget --> Removing mapping with HstPtrBegin=0x0000000000613bf0, TgtPtrBegin=0x0000000b08c20000, Size=800000000 Libomptarget --> Call to omp_get_num_devices returning 1 Number of processors: 24 Number of devices: 1 Default device: 0 Is initial device: 1 Libomptarget --> Entering target region with entry point 0x00000000004012d1 and device Id -1 Libomptarget --> Checking whether device 0 is ready. Libomptarget --> Is the device 0 (local ID 0) initialized? 1 Libomptarget --> Device 0 is ready to use. Libomptarget --> Entry 0: Base=0x0000000000613bf0, Begin=0x0000000000613bf0, Size=800000000, Type=0x21 Libomptarget --> Entry 1: Base=0x00000000301043f0, Begin=0x00000000301043f0, Size=800000000, Type=0x21 Libomptarget --> Entry 2: Base=0x00007fff707a86e8, Begin=0x00007fff707a86e8, Size=8, Type=0x23 Libomptarget --> Looking up mapping(HstPtrBegin=0x0000000000613bf0, Size=800000000)... Libomptarget --> Creating new map entry: HstBase=0x0000000000613bf0, HstBegin=0x0000000000613bf0, HstEnd=0x00000000301043f0, TgtBegin=0x0000000b08c20000 Libomptarget --> There are 800000000 bytes allocated at target address 0x0000000b08c20000 - is new Libomptarget --> Moving 800000000 bytes (hst:0x0000000000613bf0) -> (tgt:0x0000000b08c20000) Libomptarget --> Looking up mapping(HstPtrBegin=0x00000000301043f0, Size=800000000)... Libomptarget --> Creating new map entry: HstBase=0x00000000301043f0, HstBegin=0x00000000301043f0, HstEnd=0x000000005fbf4bf0, TgtBegin=0x0000000b38720000 Libomptarget --> There are 800000000 bytes allocated at target address 0x0000000b38720000 - is new Libomptarget --> Moving 800000000 bytes (hst:0x00000000301043f0) -> (tgt:0x0000000b38720000) Libomptarget --> Looking up mapping(HstPtrBegin=0x00007fff707a86e8, Size=8)... Libomptarget --> Creating new map entry: HstBase=0x00007fff707a86e8, HstBegin=0x00007fff707a86e8, HstEnd=0x00007fff707a86f0, TgtBegin=0x0000000b68220000 Libomptarget --> There are 8 bytes allocated at target address 0x0000000b68220000 - is new Libomptarget --> Moving 8 bytes (hst:0x00007fff707a86e8) -> (tgt:0x0000000b68220000) Libomptarget --> Looking up mapping(HstPtrBegin=0x0000000000613bf0, Size=800000000)... Libomptarget --> Mapping exists with HstPtrBegin=0x0000000000613bf0, TgtPtrBegin=0x0000000b08c20000, Size=800000000, RefCount=1 Libomptarget --> Obtained target argument 0x0000000b08c20000 from host pointer 0x0000000000613bf0 Libomptarget --> Looking up mapping(HstPtrBegin=0x00000000301043f0, Size=800000000)... Libomptarget --> Mapping exists with HstPtrBegin=0x00000000301043f0, TgtPtrBegin=0x0000000b38720000, Size=800000000, RefCount=1 Libomptarget --> Obtained target argument 0x0000000b38720000 from host pointer 0x00000000301043f0 Libomptarget --> Looking up mapping(HstPtrBegin=0x00007fff707a86e8, Size=8)... Libomptarget --> Mapping exists with HstPtrBegin=0x00007fff707a86e8, TgtPtrBegin=0x0000000b68220000, Size=8, RefCount=1 Libomptarget --> Obtained target argument 0x0000000b68220000 from host pointer 0x00007fff707a86e8 Libomptarget --> Launching target execution __omp_offloading_2b_1890d30_main_l67 with pointer 0x0000000060ee2e70 (index=1). Target CUDA RTL --> Setting CUDA threads per block to default 128 Target CUDA RTL --> Using requested number of teams 1 Target CUDA RTL --> Launch kernel with 1 blocks and 128 threads Target CUDA RTL --> Launch of entry point at 0x0000000060ee2e70 successful! Target CUDA RTL --> Kernel execution error at 0x0000000060ee2e70! Target CUDA RTL --> CUDA error is: an illegal memory access was encountered Libomptarget --> Executing target region abort target. Libomptarget fatal error 1: failure of target construct while offloading is mandatory Libomptarget --> Unloading target library! Libomptarget --> Image 0x0000000000602090 is compatible with RTL 0x00000000609f95d0! Libomptarget --> Unregistered image 0x0000000000602090 from RTL 0x00000000609f95d0! Libomptarget --> Done unregistering images! Libomptarget --> Removing translation table for descriptor 0x0000000000613b90 Libomptarget --> Done unregistering library! Target CUDA RTL --> Error when unloading CUDA module Target CUDA RTL --> CUDA error is: an illegal memory access was encountered loki introduction 119
Thank you very much for your help in advance.
Best regards
Siegmar
George
-------------------------------------------------------------------------------- *From:* Openmp-dev <[email protected]> on behalf of Siegmar Gross via Openmp-dev <[email protected]> *Sent:* 01 October 2018 13:26 *To:* llvm-openmp-dev *Subject:* [Openmp-dev] Libomptarget fatal error 1: failure of target construct while offloading is mandatory Hi,
today I've installed llvm-trunk. Unfortunately, I get an error for one of my programs.
loki introduction 110 clang -fopenmp -fopenmp-targets=nvptx64-nvidia-cuda dot_prod_accelerator_OpenMP.c loki introduction 111 a.out Number of processors: 24 Number of devices: 1 Default device: 0 Is initial device: 1 Libomptarget fatal error 1: failure of target construct while offloading is mandatory
loki introduction 112 setenv OMP_DEFAULT_DEVICE 1 loki introduction 113 a.out Libomptarget fatal error 1: failure of target construct while offloading is mandatory
loki introduction 114 clang -v clang version 8.0.0 (trunk 343447) Target: x86_64-unknown-linux-gnu Thread model: posix InstalledDir: /usr/local/llvm-trunk/bin Found candidate GCC installation: /usr/lib64/gcc/x86_64-suse-linux/4.8 Selected GCC installation: /usr/lib64/gcc/x86_64-suse-linux/4.8 Candidate multilib: .;@m64 Candidate multilib: 32;@m32 Selected multilib: .;@m64 Found CUDA installation: /usr/local/cuda-9.0, version 9.0 loki introduction 115
The program works fine with llvm-7.0.0.
loki introduction 125 clang -fopenmp -fopenmp-targets=nvptx64-nvidia-cuda dot_prod_accelerator_OpenMP.c loki introduction 126 a.out Number of processors: 24 Number of devices: 1 Default device: 0 Is initial device: 1 sum = 6.000000e+08
loki introduction 127 setenv OMP_DEFAULT_DEVICE 1 loki introduction 128 a.out Number of processors: 24 Number of devices: 1 Default device: 1 Is initial device: 1 sum = 6.000000e+08
loki introduction 129 clang -v clang version 7.0.0 (tags/RELEASE_700/final) Target: x86_64-unknown-linux-gnu Thread model: posix InstalledDir: /usr/local/llvm-7.0.0/bin Found candidate GCC installation: /usr/lib64/gcc/x86_64-suse-linux/4.8 Selected GCC installation: /usr/lib64/gcc/x86_64-suse-linux/4.8 Candidate multilib: .;@m64 Candidate multilib: 32;@m32 Selected multilib: .;@m64 Found CUDA installation: /usr/local/cuda-9.0, version 9.0 loki introduction 130
Hopefully somebody can fix the problem. Do you need anything else to locate the error? Thank you very much for any help in advance.
Kind regards
Siegmar
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Siegmar Gross
