Building MPICH 3.2.1 with Sun Studio 12.5
Hi, I'm having trouble building MPICH 3.2.1 and I'm hoping for some help resolving the problem(s). Perhaps someone has seen this before. The environment is: % uname -a SunOS spc64sol113ci 5.11 11.3 sun4v sparc sun4v % f95 -V f90: Studio 12.5 Fortran 95 8.8 SunOS_sparc 2016/05/31 The config command I used is: % ./configure --prefix=/export/home4/erhome/jenkins/michaelp/ports/fnl/sol113/mpi/build_area/Mikes_build CC=cc CXX=CC F77=f77 FC=f95 CFLAGS=-m64 CXXFLAGS=-m64 FFLAGS=-m64 FCFLAGS=-m64 LDFLAGS=-m64 Looking at the output from running mpich-3.2.1/make, it appears the problem is an unresolved symbol MPIR_Memcpy: CCLD src/env/mpichversion Undefined first referenced symbol in file MPIR_Memcpy lib/.libs/libmpi.a(lib_libmpi_la-ch3_progress.o) ld: fatal: symbol referencing errors *** Error code 2 The following command caused the error: echo " CCLD " src/env/mpichversion;/bin/sh ./libtool --silent --tag=CC --mode=link cc -m64 -O2 -static -m64 -o src/env/mpichversion src/env/mpichversion.o lib/libmpi.la -lnsl -lsocket -lpthread make: Fatal error: Command failed for target `src/env/mpichversion' I can provide the full output from my config and make commands if that helps, but I didn't want to overload my first email to this mail group. Thanks for any help you are able to provide, --Mike _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Michael Pulverenti
