Re: [mpich-discuss] Error: assert (!closed) failed
One of the proxy processes died suddenly causing everything else to fall apart. Try using the latest version of hydra (3.0.1), and also try running the proxy processes with a debugger (set the environment variable HYDRA_USE_DDD=1). -- Pavan On 08/20/2012 03:46 AM US Central Time, Yann RADENAC wrote:
I'm developing MPI support for XtreemOS (www.xtreemos.eu) so that an MPI program is managed as a single XtreemOS job. To manage all processes as a single XtreemOS job, I've developed the program xos-createProcess that plays the role of the launcher (replacing ssh/rsh) to start a process on a remote machine that is part of the ones reserved for the current job.
I'm running a simple hello world MPI program where each processes sends a string to the process 0 that itself prints them on standard output.
When using MPICH2 with ssh, this program works perfectly on several machines.
When using MPICH2 with my launcher xos-createProcess, it works with an MPI program of 2 processes on 2 different machines.
However I cannot pass through the following error that happens when running an MPI program of 3 processes on 3 different machines (or any n processes on n different machines with n >= 3). Everything terminates almost immediately with these error messages:
Process 0 ends with error code 7 and its standard error output is :
[[email protected]] cmd_response (./pm/pmiserv/pmiserv_pmi_v1.c:29): assert (!closed) failed [[email protected]] fn_barrier_in (./pm/pmiserv/pmiserv_pmi_v1.c:70): error writing PMI line [[email protected]] handle_pmi_cmd (./pm/pmiserv/pmiserv_cb.c:44): PMI handler returned error [[email protected]] control_cb (./pm/pmiserv/pmiserv_cb.c:289): unable to process PMI command [[email protected]] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [[email protected]] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:181): error waiting for event [[email protected]] main (./ui/mpich/mpiexec.c:405): process manager error waiting for completion
On *only* one of the other processes, the standard error output is:
[proxy:0:[email protected]] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:928): assert (!closed) failed [proxy:0:[email protected]] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status [proxy:0:[email protected]] main (./pm/pmiserv/pmip.c:226): demux engine error waiting for event
The run command is:
-bash -c '(mpiexec -launcher-exec /usr/bin/xos-createProcess -np 3 -host `xreservation -a $XOS_RSVID` ./mpi/hello_world_MPI < /dev/null > mpiexec.out) >& mpiexec.err'
Can anyone explain me what this error means ?
I'm using MPICH2 1.4.1p1
Thanks for your help.
-- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
