Re: [mpich-discuss] can't MPI_Abort a program due to deadlock at pthread_mutex_lock
On Wed, Jan 2, 2013 at 9:49 AM, Jeff Hammond <[email protected]> wrote:
I wrote a program that calls MPI from a pthread. MPI_THREAD_MULTIPLE is used. I cancel and then join the pthread back into the main program. After I do this, any calls to MPI, including MPI_Abort (see first gdb+source below) and MPI_Barrier (see second gdb+source below) deadlock on pthread_mutex_lock.
I can understand that canceling the thread while it is holding the MPI pthread mutex is a bad idea, but I'm not sure this is an incorrect program. Is pthread_cancel using signals? I recall that MPICH functions are not guaranteed to be signal-safe.
On Linux, pthread_cancel is implemented using tgkill ("man tgkill").
Is it possible to implement MPI_Abort such that acquisition of the MPI mutex is not required in order to allow deadlocked programs to terminate? It seems rather unfortunate that MPI_Abort does not perform the desired action here. Obviously, I can use abort(), but on some implementations, this will leave the system resources in a dirty state.
I know a bunch of ways to work around this, but it would be helpful to understand exactly what the problem is. I wonder if there is a way to modify MPICH such that the mutex is released when a thread holding it is cancelled.
Is it possible for MPICH to provide an MPIX call or otherwise document an internal, MPICH-specific function to clear the MPI mutex? I could resolve this problem if I could merely call MPIX_Mutex_force_unlock() and let the program terminate as desired.
Jeff
$ make mpicc -g -O0 -Wall -std=gnu99 -c bug.c -o bug.o mpicc -g -O0 -Wall -std=gnu99 safemalloc.o bug.o -lm -o bug.x rm bug.o
======== stuck in abort/finalize ========
$ gdb ./bug.x GNU gdb 6.3.50-20050815 (Apple version gdb-1752) (Sat Jan 28 03:02:46 UTC 2012) Copyright 2004 Free Software Foundation, Inc. GDB is free software, covered by the GNU General Public License, and you are welcome to change it and/or distribute copies of it under certain conditions. Type "show copying" to see the conditions. There is absolutely no warranty for GDB. Type "show warranty" for details. This GDB was configured as "x86_64-apple-darwin"...Reading symbols for shared libraries ...... done
warning: Could not find object file "/Users/jhammond/eclipse/OSPRI/trunk/tests/devices/mpi-pt/bug.o" - no debug information available for "bug.c".
(gdb) run Starting program: /Users/jhammond/eclipse/OSPRI/trunk/tests/devices/mpi-pt/bug.x Reading symbols for shared libraries +++++........................ done test done except for pthread shutdown 0: Progress all done
^C Program received signal SIGINT, Interrupt. 0x00007fff912fdbf2 in __psynch_mutexwait () (gdb) bt #0 0x00007fff912fdbf2 in __psynch_mutexwait () #1 0x00007fff8c80a1a1 in pthread_mutex_lock () #2 0x000000010004912b in MPIU_Thread_CS_enter_lockname_recursive_impl_ () #3 0x0000000100048d64 in MPI_Abort () #4 0x0000000100000cc0 in main () (gdb) quit The program is running. Exit anyway? (y or n) y
$ cat bug.c #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <string.h> #include <assert.h> #include <limits.h> #include <pthread.h>
#include <mpi.h>
#define DEBUG
pthread_t Progress_thread;
static void * Progress_function(void * dummy) { int rank; MPI_Comm_rank(MPI_COMM_WORLD, &rank);
while (1) { #ifdef DEBUG printf("%d: Progress \n", rank); #endif MPI_Probe(MPI_ANY_SOURCE, MPI_ANY_TAG, MPI_COMM_WORLD, MPI_STATUS_IGNORE); //usleep(500); }
return NULL; }
int main(int argc, char * argv[]) { int rc; int rank, size; int provided;
MPI_Init_thread(&argc, &argv, MPI_THREAD_MULTIPLE, &provided); if (provided!=MPI_THREAD_MULTIPLE) MPI_Abort(MPI_COMM_WORLD, 1);
MPI_Comm_rank(MPI_COMM_WORLD, &rank); MPI_Comm_size(MPI_COMM_WORLD, &size);
rc = pthread_create(&Progress_thread, NULL, &Progress_function, NULL); if (rc!=0) MPI_Abort(MPI_COMM_WORLD, rc);
MPI_Barrier(MPI_COMM_WORLD);
printf("test done except for pthread shutdown \n"); fflush(stdout);
rc = pthread_cancel(Progress_thread); if (rc!=0) MPI_Abort(MPI_COMM_WORLD, rc);
void * rv; rc = pthread_join(Progress_thread, &rv); if (rc!=0) MPI_Abort(MPI_COMM_WORLD, rc);
printf("all done \n"); fflush(stdout);
MPI_Abort(MPI_COMM_SELF, 2); MPI_Finalize();
return 0; }
======== stuck in barrier ========
(gdb) run Starting program: /Users/jhammond/eclipse/OSPRI/trunk/tests/devices/mpi-pt/bug.x Reading symbols for shared libraries +++++........................ done before pthread shutdown 0: Progress after pthread shutdown ^C Program received signal SIGINT, Interrupt. 0x00007fff912fdbf2 in __psynch_mutexwait () (gdb) bt #0 0x00007fff912fdbf2 in __psynch_mutexwait () #1 0x00007fff8c80a1a1 in pthread_mutex_lock () #2 0x000000010000f7eb in MPIU_Thread_CS_enter_lockname_recursive_impl_ () #3 0x000000010000f4f7 in MPI_Barrier () #4 0x0000000100000c4d in main () (gdb) quit The program is running. Exit anyway? (y or n) y Jeffs-MacBook-Pro:mpi-pt jhammond$ cat bug.c #include <stdio.h> #include <stdlib.h> #include <unistd.h> #include <string.h> #include <assert.h> #include <limits.h> #include <pthread.h>
#include <mpi.h>
#define DEBUG
return NULL; }
printf("before pthread shutdown \n"); fflush(stdout);
printf("after pthread shutdown \n"); fflush(stdout);
printf("before MPI Abort/Finalize \n"); fflush(stdout);
printf("after MPI Abort/Finalize \n"); fflush(stdout);
return 0; }
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jed Brown
