Re: [mpich-discuss] mpif.h
Dear friend i would like to offer my heartfelt appreciate for your kindly attention. my problem solved base on your suggestion. many thanks again cheers fereshte On Mon, Sep 15, 2014 at 6:28 AM, Gustavo Correa <[email protected]> wrote:
On Sep 14, 2014, at 9:16 PM, Kenneth Raffenetti wrote:
Based on the comments in the Makefile, it looks like you need to set USE_MPI and USE_MPIF90 to "on" and set FORT to "gfortran".
Ken
Agreed.
Also, besides Ken's suggestion, note also these comments in the makefile:
# This makefile is designed to work only with GNU Make version 3.80 or ::: # higher. It can be used in any architecture provided that there is a ::: # machine/compiler rules file in the "Compilers" subdirectory. You ::: # may need to modify the rules file to specify the correct path for ::: # the NetCDF and ARPACK libraries. The ARPACK library is only used in ::: # the Generalized Stability Theory analysis and Laczos algorithm. :::
You may need to look for a Linux/gfortran directory/file (or similar). There may be additional items that you may need to edit there. I would guess one would be the path to your mpif90, maybe the INCLUDE macro mentioned in your original email, and if you're using input/output files in NetCDF format, the location of your NetCDF library.
Anyway, these are mostly guesses, not knowing anything about this model (which seems to be moslty based on ROMS.)
I hope it helps, Gus Correa
On 09/14/2014 02:35 PM, fereshteh komijani wrote:
thanks for your reply in attach there is COAWST make file, i become so appreciate if you help me cheers fereshte
On Sun, Sep 14, 2014 at 1:40 AM, Gustavo Correa <[email protected] <mailto:[email protected]>> wrote:
Hi Fereshteh
<guess> The model probably comes with a Makefile, or a configuration script, where you can choose the compiler (which presumably you chose as F77 or FC=mpif90, which is a good choice, not gfortran, which is not so good a choice). It may also have a INCLUDE variable where you can add the location of your mpif.h file. Something like this:
INCLUDE= [whatever is already there] -I/home/fkomijani/program_install/mpich-3.0.4/include
Normally mpif90 is able to locate the mpif.h include file and all needed mpi libraries as well, which is a big advantage over the barebones compiler (gfortran), as Ken and Junchao said. However, I've seen makefiles and build scripts that go a long way to strip off or override that capability, by redefining the compiler to be the one underlying the mpif90 wrapper (i.e go back to gfortran in your case), which is not a very good idea but happens.
It is hard to tell exactly what is going on not knowing the Makefile, configure script, or the model code. Unfortunately the COAWST model is not readily available to download and check, requires the developer permission. If you post the Makefile or configure script things may become a little clearer.
</guess>
My two cents, Gus Correa
On Sep 13, 2014, at 10:23 AM, fereshteh komijani wrote:
After compiling my model (coawst) it gives me
following
error :
mod_parallel.f90:17: Error: Can't open included
file
'mpif.h'
coaws's developer tell me :
*check your environment and see if the location of mpif.h is in your INCLUDE list*.
But I don't know what is its mean? Where and how
I can
do that? Does environment mean .bashrc?
> thanks so much for your attention > i will check in again > cheers > fereshte > > On Sat, Sep 13, 2014 at 6:30 PM, Junchao Zhang <[email protected] <mailto:[email protected]>> wrote: > As you can see, hello.f90 contains > include 'mpif.h' > and mpif90 found it and correctly compiled the code. > > So, mpich installation is correct. You need to double check your code and compilation commands. > > --Junchao Zhang > > On Sat, Sep 13, 2014 at 8:41 AM, fereshteh komijani <[email protected] <mailto:[email protected]>> wrote: > i have created hello.F90 and after compiling, it gives > > fkomijani@fk1:~/program_install/COAWST$ mpif90 -v -o hello hello.F90 > mpif90 for MPICH version 3.0.4 > Driving: gfortran -v -o hello hello.F90 -I/home/fkomijani/program_install/mpich-3.0.4/include -I/home/fkomijani/program_install/mpich-3.0.4/include -L/home/fkomijani/program_install/mpich-3.0.4/lib -lmpichf90 -lmpich -lopa -lmpl -lrt -lpthread -l gfortran -l m -shared-libgcc > Using built-in specs. > COLLECT_GCC=gfortran > COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.6/lto-wrapper > Target: i686-linux-gnu > Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.3-1ubuntu5' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --enable-targets=all --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu --target=i686-linux-gnu > Thread model: posix > gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) > COLLECT_GCC_OPTIONS='-v' '-o' 'hello' '-I' '/home/fkomijani/program_install/mpich-3.0.4/include' '-I' '/home/fkomijani/program_install/mpich-3.0.4/include' '-L/home/fkomijani/program_install/mpich-3.0.4/lib' '-shared-libgcc' '-mtune=generic' '-march=i686' > /usr/lib/gcc/i686-linux-gnu/4.6/f951 hello.F90 -cpp=/tmp/ccgJjtSb.f90 -quiet -v -I /home/fkomijani/program_install/mpich-3.0.4/include -I /home/fkomijani/program_install/mpich-3.0.4/include -imultilib . -imultiarch i386-linux-gnu hello.F90 -quiet -dumpbase hello.F90 -mtune=generic -march=i686 -auxbase hello -version -fintrinsic-modules-path /usr/lib/gcc/i686-linux-gnu/4.6/finclude -o /tmp/ccV5Pu7p.s > GNU Fortran (Ubuntu/Linaro 4.6.3-1ubuntu5) version 4.6.3 (i686-linux-gnu) > compiled by GNU C version 4.6.3, GMP version 5.0.2, MPFR version 3.1.0-p3, MPC version 0.9 > GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 > ignoring nonexistent directory "/usr/local/include/i386-linux-gnu" > ignoring nonexistent directory "/usr/lib/gcc/i686-linux-gnu/4.6/../../../../i686-linux-gnu/include" > ignoring duplicate directory "/home/fkomijani/program_install/mpich-3.0.4/include" > #include "..." search starts here: > #include <...> search starts here: > /home/fkomijani/program_install/mpich-3.0.4/include > /usr/lib/gcc/i686-linux-gnu/4.6/finclude > /usr/lib/gcc/i686-linux-gnu/4.6/include > /usr/local/include > /usr/lib/gcc/i686-linux-gnu/4.6/include-fixed > /usr/include/i386-linux-gnu > /usr/include > End of search list. > GNU Fortran (Ubuntu/Linaro 4.6.3-1ubuntu5) version 4.6.3 (i686-linux-gnu) > compiled by GNU C version 4.6.3, GMP version 5.0.2, MPFR version 3.1.0-p3, MPC version 0.9 > GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072 > COLLECT_GCC_OPTIONS='-v' '-o' 'hello' '-I' '/home/fkomijani/program_install/mpich-3.0.4/include' '-I' '/home/fkomijani/program_install/mpich-3.0.4/include' '-L/home/fkomijani/program_install/mpich-3.0.4/lib' '-shared-libgcc' '-mtune=generic' '-march=i686' > as --32 -o /tmp/ccPO4WoE.o /tmp/ccV5Pu7p.s > Reading specs from /usr/lib/gcc/i686-linux-gnu/4.6/libgfortran.spec > rename spec lib to liborig > COLLECT_GCC_OPTIONS='-v' '-o' 'hello' '-I' '/home/fkomijani/program_install/mpich-3.0.4/include' '-I' '/home/fkomijani/program_install/mpich-3.0.4/include' '-L/home/fkomijani/program_install/mpich-3.0.4/lib' '-shared-libgcc' '-mtune=generic' '-march=i686' >
COMPILER_PATH=/usr/lib/gcc/i686-linux-gnu/4.6/:/usr/lib/gcc/i686-linux-gnu/4.6/:/usr/lib/gcc/i686-linux-gnu/:/usr/lib/gcc/i686-linux-gnu/4.6/:/usr/lib/gcc/i686-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/i686-linux-gnu/4.6/:/usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu/:/usr/lib/gcc/i686-linux-gnu/4.6/../../../../lib/:/lib/i386-linux-gnu/:/lib/../lib/:/usr/lib/i386-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/i686-linux-gnu/4.6/../../../:/lib/:/usr/lib/
> COLLECT_GCC_OPTIONS='-v' '-o' 'hello' '-I' '/home/fkomijani/program_install/mpich-3.0.4/include' '-I' '/home/fkomijani/program_install/mpich-3.0.4/include' '-L/home/fkomijani/program_install/mpich-3.0.4/lib' '-shared-libgcc' '-mtune=generic' '-march=i686' > /usr/lib/gcc/i686-linux-gnu/4.6/collect2 --sysroot=/ --build-id --no-add-needed --as-needed --eh-frame-hdr -m elf_i386 --hash-style=gnu -dynamic-linker /lib/ld-linux.so.2 -z relro -o hello /usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu/crt1.o /usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu/crti.o /usr/lib/gcc/i686-linux-gnu/4.6/crtbegin.o -L/home/fkomijani/program_install/mpich-3.0.4/lib -L/usr/lib/gcc/i686-linux-gnu/4.6 -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../../lib -L/lib/i386-linux-gnu -L/lib/../lib -L/usr/lib/i386-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/i686-linux-gnu/4.6/../../.. /tmp/ccPO4WoE.o -lmpichf90 -lmpich -lopa -lmpl -lrt -lpthread -lgfortran -lm -lgcc_s -lgcc -lquadmath -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/i686-linux-gnu/4.6/crtend.o /usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu/crtn.o > > > On Sat, Sep 13, 2014 at 5:28 PM, Junchao Zhang <[email protected] <mailto:[email protected]>> wrote: > "gfortran: error: hello.F90: No such file or directory" > You need to create hello.F90 as I said in the previous email. > > "mpif90 -v -o hello hello.F90 ./coawst.bash" > Also, do not add ./coawst.bash > > > > --Junchao Zhang > > On Sat, Sep 13, 2014 at 7:15 AM, fereshteh komijani <[email protected] <mailto:[email protected]>> wrote: > > fkomijani@fk1:~/program_install/COAWST$ mpif90 -v -o hello hello.F90 ./coawst.bash > mpif90 for MPICH version 3.0.4 > Driving: gfortran -v -o hello hello.F90 ./coawst.bash -I/home/fkomijani/program_install/mpich-3.0.4/include -I/home/fkomijani/program_install/mpich-3.0.4/include -L/home/fkomijani/program_install/mpich-3.0.4/lib -lmpichf90 -lmpich -lopa -lmpl -lrt -lpthread -l gfortran -l m -shared-libgcc > gfortran: error: hello.F90: No such file or directory > Using built-in specs. > COLLECT_GCC=gfortran > COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-linux-gnu/4.6/lto-wrapper > Target: i686-linux-gnu > Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.3-1ubuntu5' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --enable-targets=all --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=i686-linux-gnu --host=i686-linux-gnu --target=i686-linux-gnu > Thread model: posix > gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) > > > On Sat, Sep 13, 2014 at 4:33 PM, Junchao Zhang <[email protected] <mailto:[email protected]>> wrote: > That is strange. > Could you compile the following program with "mpif90 -v -o hello hello.F90" and paste the output? > > ! hello.F90 > program main > implicit none > include 'mpif.h' > integer :: ierr > > call MPI_Init(ierr) > call MPI_Finalize(ierr) > end program > > > --Junchao Zhang > > On Sat, Sep 13, 2014 at 6:24 AM, fereshteh komijani <[email protected] <mailto:[email protected]>> wrote: > sorry that is my fault, it is mpif.h > > it seems that COAWST model is searching it, in -I/user/include directory not in > /home/fkomijani/program_install/mpich-3.0.4/include. > so how can i set mentined directory in system environment? > > On Sat, Sep 13, 2014 at 3:45 PM, Junchao Zhang <[email protected] <mailto:[email protected]>> wrote: > The file name should be mpif.h, but not mpih.f. > > On Sep 13, 2014 1:45 AM, "fereshteh komijani" <[email protected] <mailto:[email protected]>> wrote: > yes, /home/fkomijani/program_install/mpich-3.0.4/include contains mpih.f > > On Sat, Sep 13, 2014 at 11:07 AM, Kenneth Raffenetti <[email protected] <mailto:[email protected]>> wrote: > If you 'ls /home/fkomijani/program_install/mpich-3.0.4/include' does it contain an mpif.h file? If not, your MPICH installation might be bad. > > On 09/13/2014 03:24 PM, fereshteh komijani wrote: > gfortran -I/home/fkomijani/program_install/mpich-3.0.4/include > -I/home/fkomijani/program_install/mpich-3.0.4/include > -L/home/fkomijani/program_install/mpich-3.0.4/lib -lmpichf90
-lmpich
> -lopa -lmpl -lrt -lpthread > > > On Sat, Sep 13, 2014 at 10:52 AM, Kenneth Raffenetti > <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>> wrote: > > What is the output from 'mpif90 -show'? > > On 09/13/2014 03:19 PM, fereshteh komijani wrote: > > dear Kenneth Raffenetti > i am using mpif90 compiler. > if it is, why i have got that error? > > On Sat, Sep 13, 2014 at 10:47 AM, Kenneth Raffenetti > <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> > <mailto:[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>>> wrote: > > Are you using the mpif77 or mpif90 compiler wrappers
to
> build your > program? They will automatically add the location of mpif.h > to your > include path. > > On 09/13/2014 02:56 PM, fereshteh komijani wrote: > > Dear friends > > recently I have installed mpich 3.0.4 in my
system
> (Ubuntu). > > After compiling my model (coawst) it gives me following > error : > > mod_parallel.f90:17: Error: Can't open included
file
> 'mpif.h' > > coaws's developer tell me : > > *check your environment and see if the location
of
> mpif.h is in your > INCLUDE list*. > > But I don't know what is its mean? Where and how I can > do that? Does > environment mean .bashrc? > > many thanks for any reply > > fereshteh > > > > -- > ***Angel*** > *__* > > >
> discuss mailing list [email protected] <mailto:[email protected]> > <mailto:[email protected] <mailto:[email protected]>> <mailto:[email protected] <mailto:[email protected]> > <mailto:[email protected] <mailto:[email protected]>>> > To manage subscription options or unsubscribe: > https://lists.mpich.org/____mailman/listinfo/discuss > <https://lists.mpich.org/__mailman/listinfo/discuss> > <
> <https://lists.mpich.org/mailman/listinfo/discuss>> > > ___________________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > <mailto:[email protected] <mailto:[email protected]>> <mailto:[email protected] <mailto:[email protected]> > <mailto:[email protected] <mailto:[email protected]>>> > To manage subscription options or unsubscribe: > https://lists.mpich.org/____mailman/listinfo/discuss > <https://lists.mpich.org/__mailman/listinfo/discuss> > > <https://lists.mpich.org/__mailman/listinfo/discuss > <https://lists.mpich.org/mailman/listinfo/discuss>> > > > > > -- > ***Angel*** > *__* > > > _________________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> > To manage subscription options or unsubscribe: > https://lists.mpich.org/__mailman/listinfo/discuss > <https://lists.mpich.org/mailman/listinfo/discuss> > > _________________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> > To manage subscription options or unsubscribe: > https://lists.mpich.org/__mailman/listinfo/discuss > <https://lists.mpich.org/mailman/listinfo/discuss> > > > > > -- > ***Angel*** > *__* > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > > > > -- > **Angel** > > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > > > > -- > **Angel** > > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > > > > -- > **Angel** > > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > > > > -- > **Angel** > > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss > > > > -- > **Angel** > > > _______________________________________________ > discuss mailing list [email protected] <mailto:[email protected]> > To manage subscription options or unsubscribe: > https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- ***Angel*** *__*
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- ***Angel***
participants (1)
fereshteh komijani
