Re: [mpich-discuss] Error in MPI_IRECV
If Gregor's answer does not solve it try adding -std=legacy to gfortrans compiler flags. Sent from [Proton Mail](https://urldefense.us/v3/__https://proton.me/mail/home__;!!G_uCfscf7eWS!dJKf... ) for Android. -------- Original Message -------- On Friday, 10/17/25 at 14:26 Gregor Corbin via discuss <[email protected]> wrote:
let me guess: this code uses `include mpif.h` and is compiled with gfortran. If so, try to add `-fallow-argument-mismatch' to your compiler flags.
Explanation: With the include file, there are no explicit interfaces and the compiler generates an implicit interface from the call to `MPI_IRECV`. Having two calls with different argument types is an error since some gcc version (10 IIRC).
Cheers,
Gregor Corbin
On 17.10.25 13:30, phani sri via discuss wrote:
Hi all, I am trying to run FLASH4. 8, where I am getting the following error. Can someone please, suggest to me why this error is coming. Thank you in advance. 497 | Call MPI_IRECV(parentt(1,i),2,MPI_INTEGER, & ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd Hi all, I am trying to run FLASH4.8, where I am getting the following error. Can someone please, suggest to me why this error is coming. Thank you in advance. 497 | Call MPI_IRECV(parentt(1,i),2,MPI_INTEGER, & | 2 ...... 633 | Call MPI_IRECV(buffert(1,i),buf_size, & | 1 Error: Type mismatch between actual argument at (1) and actual argument at (2) (REAL(8)/INTEGER(4)). amr_migrate_tree_data.F90:642:23:
497 | Call MPI_IRECV(parentt(1,i),2,MPI_INTEGER, & | 2 ...... 642 | Call MPI_IRECV(newchildt(i),1,MPI_LOGICAL, & | 1 Error: Type mismatch between actual argument at (1) and actual argument at (2) (LOGICAL(4)/INTEGER(4)). amr_migrate_tree_data.F90:717:23:
513 | Call MPI_SSEND (new_loc(1,i),2,MPI_INTEGER, & | 2 ...... 717 | Call MPI_SSEND(buffer(1),buf_size,amr_mpi_real, & | 1 Error: Type mismatch between actual argument at (1) and actual argument at (2) (REAL(8)/INTEGER(4)). amr_migrate_tree_data.F90:725:23:
513 | Call MPI_SSEND (new_loc(1,i),2,MPI_INTEGER, & | 2 ...... 725 | Call MPI_SSEND(newchild(i),1,MPI_LOGICAL, & | 1 Error: Type mismatch between actual argument at (1) and actual argument at (2) (LOGICAL(4)/INTEGER(4)). amr_migrate_tree_data.F90:260:25:
260 | Call MPI_IRECV(buffert(1,i),buf_size, & | 1 ...... 497 | Call MPI_IRECV(parentt(1,i),2,MPI_INTEGER, & | 2 Error: Type mismatch between actual argument at (1) and actual argument at (2) (REAL(8)/INTEGER(4)). amr_migrate_tree_data.F90:269:25:
269 | Call MPI_IRECV(newchildt(i),1,MPI_LOGICAL, & | 1 ...... 497 | Call MPI_IRECV(parentt(1,i),2,MPI_INTEGER, & | 2 Error: Type mismatch between actual argument at (1) and actual argument at (2) (LOGICAL(4)/INTEGER(4)). amr_migrate_tree_data.F90:330:25:
330 | Call MPI_SSEND(buffer(1),buf_size,amr_mpi_real, & | 1 ...... 513 | Call MPI_SSEND (new_loc(1,i),2,MPI_INTEGER, & | 2 Error: Type mismatch between actual argument at (1) and actual argument at (2) (REAL(8)/INTEGER(4)). amr_migrate_tree_data.F90:338:25:
338 | Call MPI_SSEND(newchild(i),1,MPI_LOGICAL, & | 1 ...... 513 | Call MPI_SSEND (new_loc(1,i),2,MPI_INTEGER, & | 2 Error: Type mismatch between actual argument at (1) and actual argument at (2) (LOGICAL(4)/INTEGER(4)). amr_restrict_ec_genorder.F90:310:37:
Dr. D. P. S. L. Kameswari
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://urldefense.us/v3/__https://lists.mpich.org/mailman/listinfo/discuss_...
participants (1)
fistrosan
