Hi, I am trying to use MPE to do a profiling for all the MPI statements in a complex Fortran code with MPICH2-1.4.1 on 1008 cores . The code was compiled with ... MPICH2-1.4.1/bin/mpif90 -mpe=mpilog ... While during converting from clog to slog file with the clog2TOslog2 command, millions of lines like below appeared on the screen and it was out of some time limit eventually. It looks like some events should not be recorded. This also leads to extreme slowness and generated a 177GB profile for the code to be studied. What is the possible cause of this? How to solve the problem? Some clog2print output can be found at the end. State{ Primitive[ infobox[ TimeBBox(30.777848601341248,30.777848601341248) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.77785, 588) (30.77785, 588) ] bsize=32 } State{ Primitive[ infobox[ TimeBBox(30.777848601341248,30.777848601341248) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.77785, 588) (30.77785, 588) ] bsize=32 } Drawable.Order: WARNING! Equal Drawables? State{ Primitive[ infobox[ TimeBBox(30.7866690158844,30.7866690158844) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.786669, 490) (30.786669, 490) ] bsize=32 } State{ Primitive[ infobox[ TimeBBox(30.7866690158844,30.7866690158844) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.786669, 490) (30.786669, 490) ] bsize=32 } Drawable.Order: WARNING! Equal Drawables? State{ Primitive[ infobox[ TimeBBox(30.78674340248108,30.78674340248108) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.786743, 492) (30.786743, 492) ] bsize=32 } State{ Primitive[ infobox[ TimeBBox(30.78674340248108,30.78674340248108) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.786743, 492) (30.786743, 492) ] bsize=32 } Drawable.Order: WARNING! Equal Drawables? State{ Primitive[ infobox[ TimeBBox(30.786930561065674,30.786930561065674) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.78693, 482) (30.78693, 482) ] bsize=32 } State{ Primitive[ infobox[ TimeBBox(30.786930561065674,30.786930561065674) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.78693, 482) (30.78693, 482) ] bsize=32 } Drawable.Order: WARNING! Equal Drawables? State{ Primitive[ infobox[ TimeBBox(30.78696846961975,30.78696846961975) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.786968, 481) (30.786968, 481) ] bsize=32 } State{ Primitive[ infobox[ TimeBBox(30.78696846961975,30.78696846961975) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.786968, 481) (30.786968, 481) ] bsize=32 } Drawable.Order: WARNING! Equal Drawables? State{ Primitive[ infobox[ TimeBBox(30.777848601341248,30.777848601341248) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.77785, 588) (30.77785, 588) ] bsize=32 } State{ Primitive[ infobox[ TimeBBox(30.777848601341248,30.777848601341248) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.77785, 588) (30.77785, 588) ] bsize=32 } Drawable.Order: WARNING! Equal Drawables? State{ Primitive[ infobox[ TimeBBox(30.7866690158844,30.7866690158844) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.786669, 490) (30.786669, 490) ] bsize=32 } State{ Primitive[ infobox[ TimeBBox(30.7866690158844,30.7866690158844) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.786669, 490) (30.786669, 490) ] bsize=32 } Drawable.Order: WARNING! Equal Drawables? State{ Primitive[ infobox[ TimeBBox(30.78674340248108,30.78674340248108) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.786743, 492) (30.786743, 492) ] bsize=32 } State{ Primitive[ infobox[ TimeBBox(30.78674340248108,30.78674340248108) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.786743, 492) (30.786743, 492) ] bsize=32 } Drawable.Order: WARNING! Equal Drawables? State{ Primitive[ infobox[ TimeBBox(30.786930561065674,30.786930561065674) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.78693, 482) (30.78693, 482) ] bsize=32 } State{ Primitive[ infobox[ TimeBBox(30.786930561065674,30.786930561065674) Category=ObjDef{ evts=(210,211), Category[ index=106, name=UnknownType-106, topo=State, color=(153,204,255,255,true), isUsed=true, width=1, vis=true, search=true, ratios=0.0,0.0, count=0 ] }: ] (30.78693, 482) (30.78693, 482) ] bsize=32 } Drawable.Order: WARNING! Equal Drawables? Some outputs from clog2print fe7>clog2print NEMS.x.clog2 | more GUI_LIBDIR is set. GUI_LIBDIR = /home/Yusong.Wang/Tools/MPE2/lib CLOG-02.44 is_big_endian=true is_finalzed=true block_size=65536 num_buffered_blocks=128 max_comm_world_size=1008 max_thread_count=1 known_eventID_start=0 user_eventID_start=600 known_solo_eventID_start=-10 user_solo_eventID_start=5000 known_stateID_count=300 user_stateID_count=0 known_solo_eventID_count=2 user_solo_eventID_count=0 commtable_fptr=189927785472 RecHeader[ time=-0.0014635324478149414, icomm=0, rank=286, thread=0, rectype=11 ] RecTshift[ timeshift=0.0014914274215698242 ] RecHeader[ time=-0.0014625787734985352, icomm=0, rank=286, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=286, wrank=286, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0014625787734985352, icomm=0, rank=286, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=315, rank=0, wrank=286, gcomm=1187486374-1.36148902997195E9-r36i1n3 RecHeader[ time=-0.001454472541809082, icomm=0, rank=278, thread=0, rectype=11 ] RecTshift[ timeshift=0.0014923810958862305 ] RecHeader[ time=-0.0014532804489135742, icomm=0, rank=278, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=278, wrank=278, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0014532804489135742, icomm=0, rank=278, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=307, rank=0, wrank=278, gcomm=1259602162-1.361489029971928E9-r36i1n3 RecHeader[ time=-0.0014530420303344727, icomm=0, rank=283, thread=0, rectype=11 ] RecTshift[ timeshift=0.001490950584411621 ] RecHeader[ time=-0.001452803611755371, icomm=0, rank=279, thread=0, rectype=11 ] RecTshift[ timeshift=0.0014919042587280273 ] RecHeader[ time=-0.0014520883560180664, icomm=0, rank=283, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=283, wrank=283, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0014520883560180664, icomm=0, rank=283, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=312, rank=0, wrank=283, gcomm=2019836162-1.361489029971952E9-r36i1n3 RecHeader[ time=-0.0014518499374389648, icomm=0, rank=279, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=279, wrank=279, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0014518499374389648, icomm=0, rank=279, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=308, rank=0, wrank=279, gcomm=982152232-1.361489029971961E9-r36i1n3 RecHeader[ time=-0.0014477968215942383, icomm=0, rank=276, thread=0, rectype=11 ] RecTshift[ timeshift=0.0014928579330444336 ] RecHeader[ time=-0.0014477968215942383, icomm=0, rank=276, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=276, wrank=276, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0014477968215942383, icomm=0, rank=276, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=305, rank=0, wrank=276, gcomm=1814502021-1.361489029971937E9-r36i1n3 RecHeader[ time=-0.001446366310119629, icomm=0, rank=277, thread=0, rectype=11 ] RecTshift[ timeshift=0.0014933347702026367 ] RecHeader[ time=-0.0014454126358032227, icomm=0, rank=277, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=277, wrank=277, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0014454126358032227, icomm=0, rank=277, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=306, rank=0, wrank=277, gcomm=1537052091-1.361489029971946E9-r36i1n3 RecHeader[ time=-0.0014358758926391602, icomm=0, rank=287, thread=0, rectype=11 ] RecTshift[ timeshift=0.001490950584411621 ] RecHeader[ time=-0.001434922218322754, icomm=0, rank=287, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=287, wrank=287, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.001434922218322754, icomm=0, rank=287, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=316, rank=0, wrank=287, gcomm=910036444-1.361489029971966E9-r36i1n3 RecHeader[ time=-0.0014303922653198242, icomm=0, rank=285, thread=0, rectype=11 ] RecTshift[ timeshift=0.0014914274215698242 ] RecHeader[ time=-0.0014303922653198242, icomm=0, rank=285, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=285, wrank=285, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0014303922653198242, icomm=0, rank=285, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=314, rank=0, wrank=285, gcomm=1464936303-1.361489029971933E9-r36i1n3 RecHeader[ time=-0.0014175176620483398, icomm=0, rank=282, thread=0, rectype=11 ] RecTshift[ timeshift=0.001490473747253418 ] RecHeader[ time=-0.0014165639877319336, icomm=0, rank=282, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=282, wrank=282, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0014165639877319336, icomm=0, rank=282, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=311, rank=0, wrank=282, gcomm=149802444-1.361489029971928E9-r36i1n3 RecHeader[ time=-0.0014106035232543945, icomm=0, rank=281, thread=0, rectype=11 ] RecTshift[ timeshift=0.001490473747253418 ] RecHeader[ time=-0.0014106035232543945, icomm=0, rank=281, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=281, wrank=281, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0014106035232543945, icomm=0, rank=281, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=310, rank=0, wrank=281, gcomm=427252373-1.361489029971947E9-r36i1n3 RecHeader[ time=-0.0013779401779174805, icomm=0, rank=284, thread=0, rectype=11 ] RecTshift[ timeshift=0.001490950584411621 ] RecHeader[ time=-0.0013769865036010742, icomm=0, rank=284, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=284, wrank=284, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0013769865036010742, icomm=0, rank=284, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=313, rank=0, wrank=284, gcomm=1742386233-1.361489029971935E9-r36i1n3 RecHeader[ time=-0.0013734102249145508, icomm=0, rank=280, thread=0, rectype=11 ] RecTshift[ timeshift=0.001490473747253418 ] RecHeader[ time=-0.0013724565505981445, icomm=0, rank=280, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=280, wrank=280, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0013715028762817383, icomm=0, rank=280, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=309, rank=0, wrank=280, gcomm=704702303-1.361489029971955E9-r36i1n3 RecHeader[ time=-0.0012382268905639648, icomm=0, rank=380, thread=0, rectype=11 ] RecTshift[ timeshift=0.001263260841369629 ] RecHeader[ time=-0.0012382268905639648, icomm=0, rank=380, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=380, wrank=380, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0012382268905639648, icomm=0, rank=380, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=409, rank=0, wrank=380, gcomm=646419710-1.361489029982929E9-r36i1n11 RecHeader[ time=-0.001236557960510254, icomm=0, rank=381, thread=0, rectype=11 ] RecTshift[ timeshift=0.001263737678527832 ] RecHeader[ time=-0.001236557960510254, icomm=0, rank=381, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=381, wrank=381, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0012356042861938477, icomm=0, rank=381, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=410, rank=0, wrank=381, gcomm=368969781-1.361489029982935E9-r36i1n11 RecHeader[ time=-0.001231074333190918, icomm=0, rank=379, thread=0, rectype=11 ] RecTshift[ timeshift=0.0012642145156860352 ] RecHeader[ time=-0.0012301206588745117, icomm=0, rank=379, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=379, wrank=379, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0012301206588745117, icomm=0, rank=379, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=408, rank=0, wrank=379, gcomm=923869640-1.361489029982941E9-r36i1n11 RecHeader[ time=-0.001221776008605957, icomm=0, rank=376, thread=0, rectype=11 ] RecTshift[ timeshift=0.0012627840042114258 ] RecHeader[ time=-0.001221776008605957, icomm=0, rank=376, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=376, wrank=376, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.001221776008605957, icomm=0, rank=376, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=405, rank=0, wrank=376, gcomm=1756219428-1.361489029982958E9-r36i1n11 RecHeader[ time=-0.0012112855911254883, icomm=0, rank=373, thread=0, rectype=11 ] RecTshift[ timeshift=0.0012623071670532227 ] RecHeader[ time=-0.001210331916809082, icomm=0, rank=373, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=373, wrank=373, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.001210331916809082, icomm=0, rank=373, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=402, rank=0, wrank=373, gcomm=441085569-1.361489029982914E9-r36i1n11 RecHeader[ time=-0.0012046098709106445, icomm=0, rank=383, thread=0, rectype=11 ] RecTshift[ timeshift=0.0012627840042114258 ] RecHeader[ time=-0.0012036561965942383, icomm=0, rank=383, thread=0, rectype=9 ] RecComm[ etype=CommWorldCreate, icomm=0, rank=383, wrank=383, gcomm=369972154-1.361489029949814E9-r6i2n0 RecHeader[ time=-0.0012036561965942383, icomm=0, rank=383, thread=0, rectype=9 ] RecComm[ etype=CommSelfCreate, icomm=412, rank=0, wrank=383, gcomm=1961553570-1.361489029982915E9-r36i1n11 RecHeader[ time=-0.0011996030807495117, icomm=0, rank=382, thread=0, rectype=11 ] RecTshift[ timeshift=0.001261591911315918 ] Thanks, Yusong
participants (1)
Yusong Wang - NOAA Affiliate
