Re: [mpich-discuss] Bug reporting for some mpi/rma tests
Hi C. FOYER, Thanks for reporting bugs to us. However, the places in test rma/lockcontention3.c are correct. The buffers' size is RMA_SIZE (2048) count of int. In case 9, 10, 11 the operations' size is longcount(512) count of int, and the largest target displacement is OFFSET_3(157), which means the window buffer is accessed in range int[157: 157+512]. Thus no overflows. In rma/manyrma3.c, as you reported, we missed verification and winbuf initialization. We will fix it. Min On 7/12/16 3:08 AM, Cl�ment Foyer wrote:
Hi everyone,
I think I may have found some bugs in mpich tests for RMA operations.
First, in rma/lockcontention3.c. When calling RMA operations, the different offsets are not taken in account on the origin_count and target_count parameters. As the buffers are the same sizes, when the count arguments are equal to "longcount" (such as in the tests cases 9, 10 and 11), it either overflows when the operation is actually done, or, as it should preferably be done, it fails with the returns of the MPI_ERR_RMA_RANGE error code. Also, on the check function, there are some array overflows, as the loops go from 0 to longcount-1, and the array is accessed with the OFFSET (buf[OFFSET_1+j]). The easiest solution would be to set bufsize (l.111) and getbufsize (l.118) to RMA_SIZE+OFFSET_3 (OFFSET_3 being the bigger one), and maybe allocate change l.123 to srcbuf = malloc((RMA_SIZE + OFFSET_3)*sizeof(*srcbuf)); Also, the window is defined with the bufsize as size, which should mean that the window is bufsize bytes long. But as it is an array of int's, it would rather be bufsize*sizeof(int) long. There might be a problem there as well, given the fact that the displacement unit given is actually "sizeof(int)".
rma/manyrma3.c No verification is done. Just accumulate, and then we assume the result is correct. Also, winbuf is not initialized.
Sincerely yours,
C. FOYER
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Min Si
