Re: [mpich-discuss] channel initialization failed
Can you try these suggestions: https://wiki.mpich.org/mpich/index.php/Frequently_Asked_Questions#Q:_My_MPI_... On 7/5/15, 10:53 PM, "Victor Rodriguez" <[email protected]> wrote:
Hi
I am facing the following issue on my MPICH build from source code:
(the only change in config was disable fortran )
Any help is more than welcome
root@intel-corei7-64:~/test# mpirun -n 2 ./mpi_hello Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(498)..............: MPID_Init(187).....................: channel initialization failed MPIDI_CH3_Init(89).................: MPID_nem_init(320).................: MPID_nem_tcp_init(171).............: MPID_nem_tcp_get_business_card(418): MPID_nem_tcp_init(377).............: gethostbyname failed, intel-corei7-64 (errno 1)
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 483 RUNNING AT intel-corei7-64 = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES ===================================================================================
Source code : https://github.com/VictorRodriguez/parallel/blob/master/mpi/hello.c
All help is more than welcome
Best Regards
Victor Rodriguez _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Balaji, Pavan
