Cygwin+Mpich2: Internal Error: Failed to convert MPI_INTEGER value to hex!
Hello all, I am trying to compile mpich-3.1.2 under Cygwin 64bit. I am using the mingw64- x86_64-gcc-g++ and mingw64-x86_64-gcc-gfortran compilers, i.e. the mingw compilers shipped in the latest Cygwin. I encountered an internal error "Failed to convert MPI_INTEGER value to hex!" when configuring. ======================================================== checking whether real*4 is supported... yes checking whether real*8 is supported... yes checking whether real*16 is supported... yes : integer expression expected: 4 : integer expression expected: 4 : integer expression expected: 4 : integer expression expected: 8 : integer expression expected: 8 : integer expression expected: 8 checking for C type matching Fortran real... unavailable checking for C type matching Fortran double... unavailable expr: syntax error expr: syntax error expr: non-integer argument ./configure: line 38715: test: : integer expression expected ./configure: line 38720: test: -gt: unary operator expected ./configure: line 38734: test: -lt: unary operator expected ./configure: line 38715: test: : integer expression expected ./configure: line 38720: test: -gt: unary operator expected ./configure: line 38734: test: -lt: unary operator expected ./configure: line 38715: test: : integer expression expected ./configure: line 38720: test: -gt: unary operator expected ./configure: line 38734: test: -lt: unary operator expected expr: non-integer argument ./configure: line 38783: test: -ge: unary operator expected expr: syntax error expr: syntax error expr: syntax error expr: syntax error configure: error: Internal Error: Failed to convert MPI_INTEGER value to hex! O riginal value was 0x4c001b ============================================================= In config.log, it shows ============================================================= configure:38248: checking for size of Fortran type double precision configure:38289: gcc -c -O2 -I/cygdrive/c/Library/mpich2/mpich-3.1.2/src/mpl/include -I/cygdrive/c/Library/mpich2/mpich-3.1.2/src/mpl/include -I/cygdrive/c/Library/mpich2/mpich-3.1.2/src/openpa/src -I/cygdrive/c/Library/mpich2/mpich-3.1.2/src/openpa/src -D_REENTRANT -I/cygdrive/c/Library/mpich2/mpich-3.1.2/src/mpi/romio/include conftest.c
&5 configure:38289: $? = 0 configure:38293: mv conftest.o pac_conftest.o configure:38296: $? = 0 configure:38323: gfortran -o conftest.exe -O2 conftest.f pac_conftest.o >&5 configure:38323: $? = 0 configure:38323: ./conftest.exe configure:38323: $? = 0 configure:38361: result: 8
configure:38384: checking whether integer*1 is supported configure:38395: gfortran -c -O2 conftest.f >&5 configure:38395: $? = 0 configure:38402: result: yes configure:38404: checking whether integer*2 is supported configure:38415: gfortran -c -O2 conftest.f >&5 configure:38415: $? = 0 configure:38422: result: yes configure:38424: checking whether integer*4 is supported configure:38435: gfortran -c -O2 conftest.f >&5 configure:38435: $? = 0 configure:38442: result: yes configure:38444: checking whether integer*8 is supported configure:38455: gfortran -c -O2 conftest.f >&5 configure:38455: $? = 0 configure:38462: result: yes configure:38464: checking whether integer*16 is supported configure:38475: gfortran -c -O2 conftest.f >&5 configure:38475: $? = 0 configure:38482: result: yes configure:38484: checking whether real*4 is supported configure:38495: gfortran -c -O2 conftest.f >&5 configure:38495: $? = 0 configure:38502: result: yes configure:38504: checking whether real*8 is supported configure:38515: gfortran -c -O2 conftest.f >&5 configure:38515: $? = 0 configure:38522: result: yes configure:38524: checking whether real*16 is supported configure:38535: gfortran -c -O2 conftest.f >&5 configure:38535: $? = 0 configure:38542: result: yes configure:38641: checking for C type matching Fortran real configure:38659: result: unavailable configure:38664: checking for C type matching Fortran double configure:38681: result: unavailable configure:38842: error: Internal Error: Failed to convert MPI_INTEGER value to hex! Original value was 0x4c001b ============================================================= Can you help? Thanks, Mengda _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Mengda Wu
