Re: [mpich-discuss] [PATCH] Use attribute layout_compatible for pair types
In addition, I suggest guarding these definitions. Leaving these in increases the total number of symbols in an example executable linking PETSc by a factor of 2. (They're all read-only, but they're still there.) Clang is smart enough to remove these, presumably because it understands the special attributes. static const MPI_Datatype mpich_mpi_float_int MPICH_ATTR_TYPE_TAG_LAYOUT_COMPATIBLE(struct mpich_struct_mpi_float_int) = MPI_FLOAT_INT; static const MPI_Datatype mpich_mpi_double_int MPICH_ATTR_TYPE_TAG_LAYOUT_COMPATIBLE(struct mpich_struct_mpi_double_int) = MPI_DOUBLE_INT; static const MPI_Datatype mpich_mpi_long_int MPICH_ATTR_TYPE_TAG_LAYOUT_COMPATIBLE(struct mpich_struct_mpi_long_int) = MPI_LONG_INT; static const MPI_Datatype mpich_mpi_short_int MPICH_ATTR_TYPE_TAG_LAYOUT_COMPATIBLE(struct mpich_struct_mpi_short_int) = MPI_SHORT_INT; static const MPI_Datatype mpich_mpi_2int MPICH_ATTR_TYPE_TAG_LAYOUT_COMPATIBLE(struct mpich_struct_mpi_2int) = MPI_2INT; static const MPI_Datatype mpich_mpi_long_double_int MPICH_ATTR_TYPE_TAG_LAYOUT_COMPATIBLE(struct mpich_struct_mpi_long_double_int) = MPI_LONG_DOUBLE_INT;
On Tue, Jan 1, 2013 at 11:48 AM, Jed Brown <[email protected]> wrote:
--- src/include/mpi.h.in | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
participants (1)
Jed Brown
