Re: [mpich-discuss] Fail on MPI_Wait
Apparently I was having some issues with respect to the libraries that were getting configured when I built MPICH versus the libraries that were available on the compute nodes. I’ve got that sorted out. I configure with --with-device=ch4:ofi and got rid of the --without-ucx flag. I’m still getting a crash on MPI_Wait. If I don’t set FI_PROVIDER, then I get the error Bad : modifier in $ (-). Abort(944950159) on node 1: Fatal error in internal_Wait: Other MPI error, error stack: internal_Wait(68205)..........: MPI_Wait(request=0x5e88690, status=0x7ffc63581a40) failed MPIR_Wait(780)................: MPIR_Wait_state(737)..........: MPIDI_progress_test(134)......: MPIDI_OFI_handle_cq_error(791): OFI poll failed (ofi_events.c:793:MPIDI_OFI_handle_cq_error:Input/output error) If I set FI_PROVIDER=verbs, I get Abort(673331087) on node 5 (rank 5 in comm 496): Fatal error in internal_Recv: Other MPI error, error stack: internal_Recv(61700)..........: MPI_Recv(buf=0x2b4e0fa00000, count=4194304, MPI_CHAR, 0, 27624, comm=0x84000001, status=0x7ffdb2e9bdd0) failed MPIR_Wait(780)................: MPIR_Wait_state(737)..........: MPIDI_progress_test(134)......: MPIDI_OFI_handle_cq_error(791): OFI poll failed (ofi_events.c:793:MPIDI_OFI_handle_cq_error:Bad address) This error appears on ranks 2 and 5 of a 6 processor job on 2 nodes, but the remaining nodes still appear to be failing on an MPI_Wait call. From: Zhou, Hui <[email protected]> Date: Friday, June 21, 2024 at 11:03 AM To: Palmer, Bruce J <[email protected]>, [email protected] <[email protected]> Subject: Re: Fail on MPI_Wait
../configure --prefix=/people/d3g293/mpich/mpich-4.2.1/build_decptn/install \ --with-device=ch4:ofi:sockets --with-libfabric=embedded \ --without-ucx CC=gcc CXX=g++
You are statically using "sockets" provider. Try --with-device=ch4:ofi Hui ________________________________ From: Palmer, Bruce J <[email protected]> Sent: Friday, June 21, 2024 12:27 PM To: Zhou, Hui <[email protected]>; [email protected] <[email protected]> Subject: RE: Fail on MPI_Wait Hui, When I set FI_PROVIDER=tcp, the code crashes in MPI_Init. Specifically, this code will fail on one process: #include "mpi. h" int main(int argc, char **argv) { MPI_Init(&argc, &argv); MPI_Finalize(); } I’m running on a ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Hui, When I set FI_PROVIDER=tcp, the code crashes in MPI_Init. Specifically, this code will fail on one process: #include "mpi.h" int main(int argc, char **argv) { MPI_Init(&argc, &argv); MPI_Finalize(); } I’m running on a system with the following modules [d3g293@deception02 testing]$ module list Currently Loaded Modulefiles: 1) gcc/11.2.0 3) python/3.7.0 5) mkl/2019u4 2) cmake/3.21.4 4) git/2.42.0(default) 6) cuda/11.8 and a home-built version of mpich-4.2.1 configured with ../configure --prefix=/people/d3g293/mpich/mpich-4.2.1/build_decptn/install \ --with-device=ch4:ofi:sockets --with-libfabric=embedded \ --without-ucx CC=gcc CXX=g++ I thought it might have something to do with using a build configuration in my application build that is set up to include Cuda, but it also fails in MPI_Init with a non-Cuda configuraton if I set the FI_PROVIDER variable. Bruce From: Zhou, Hui <[email protected]> Sent: Friday, June 14, 2024 9:27 AM To: Palmer, Bruce J <[email protected]>; [email protected] Subject: Re: Fail on MPI_Wait Never mind. It is v4.2.1. ________________________________ From: Zhou, Hui <[email protected]<mailto:[email protected]>> Sent: Friday, June 14, 2024 11:26 AM To: Palmer, Bruce J <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: Fail on MPI_Wait Bruce, What is the mpich version, BTW? -- Hui ________________________________ From: Zhou, Hui <[email protected]<mailto:[email protected]>> Sent: Friday, June 14, 2024 10:55 AM To: Palmer, Bruce J <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: Fail on MPI_Wait Bruce, You are using the sockets provider. Could try set FI_PROVIDER=tcp to see if it makes a difference? Meanwhile, if you can get a small reproducer – with the sockets provider or any provider, I'll try to debug it. It is difficult to guess the true source of the issue without a reproducer. -- Hui ________________________________ From: Palmer, Bruce J <[email protected]<mailto:[email protected]>> Sent: Friday, June 14, 2024 10:47 AM To: Zhou, Hui <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Subject: Re: Fail on MPI_Wait The output to standard out from running on 2 nodes and one process per node is attached. From: Zhou, Hui <zhouh@ anl. gov> Date: Tuesday, June 11, 2024 at 5: 49 PM To: discuss@ mpich. org <discuss@ mpich. org> Cc: Palmer, Bruce J <Bruce. Palmer@ pnnl. gov> ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd The output to standard out from running on 2 nodes and one process per node is attached. From: Zhou, Hui <[email protected]<mailto:[email protected]>> Date: Tuesday, June 11, 2024 at 5:49 PM To: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Cc: Palmer, Bruce J <[email protected]<mailto:[email protected]>> Subject: Re: Fail on MPI_Wait
MPIDI_OFI_handle_cq_error(793): OFI poll failed (ofi_events.c:793:MPIDI_OFI_handle_cq_error:Input/output error)
This is an error coming from the libfabric provider. First we need find out which provider are you using. Try set environment variable MPIR_CVAR_DEBUG_SUMMARY=1 and run a simple MPI_INIT+MPI_Finalize test code. Could post its console output? -- Hui ________________________________ From: Palmer, Bruce J via discuss <[email protected]<mailto:[email protected]>> Sent: Tuesday, June 11, 2024 3:17 PM To: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> Cc: Palmer, Bruce J <[email protected]<mailto:[email protected]>> Subject: [mpich-discuss] Fail on MPI_Wait Hi, I’m trying to debug a GPU-aware runtime for the Global Arrays library. We had a version of this working a while ago, but it has mysteriously started failing and we are trying to track down why. Currently, we are getting failures in MPI_Wait ZjQcmQRYFpfptBannerStart This Message Is From an External Sender This message came from outside your organization. ZjQcmQRYFpfptBannerEnd Hi, I’m trying to debug a GPU-aware runtime for the Global Arrays library. We had a version of this working a while ago, but it has mysteriously started failing and we are trying to track down why. Currently, we are getting failures in MPI_Wait and were wondering if anyone could provide some information on what exactly seems to be failing inside the wait call. The error we are getting is Abort(206752655) on node 0: Fatal error in internal_Wait: Other MPI error, error stack: internal_Wait(68205)..........: MPI_Wait(request=0x500847a0, status=0x7ffff9331800) failed MPIR_Wait(780)................: MPIR_Wait_state(737)..........: MPIDI_progress_test(134)......: MPIDI_OFI_handle_cq_error(793): OFI poll failed (ofi_events.c:793:MPIDI_OFI_handle_cq_error:Input/output error) I’ve verified that the handle corresponding to 0x500847a0 is getting set earlier in the code in an MPI_Isend call and that no MPI_Wait or MPI_Test is called on the handle before it crashes with the above error message. I’m using MPICH 4.2.1 using gcc/8.3.0. The MPICH library was configured with ../configure --prefix=/people/d3g293/mpich/mpich-4.2.1/build_newell/install \ --with-device=ch4:ofi:sockets --with-libfabric=embedded \ --without-ucx --enable-threads=multiple --with-slurm \ CC=gcc CXX=g+ I’ve tried building with UCX and gotten the same results. Are these errors indicative of corruption of the request handle or problems with some internal MPI data structures or something else? Any information you can provide would be appreciated. Thanks, Bruce
participants (1)
Palmer, Bruce J
