Re: [mpich-discuss] where is two-phase I/O implemented
* Matthieu Dorier <[email protected]> [2013-05-01 11:41:52]:
Alright :-)
Thanks for your answers. If I understand correctly, for instance when performing a strided read, ADIOI_GEN_ReadStridedColl is called, optimizes the access and then call ADIOI_BGL_ReadContig itself (possibly several times)?
Btw how does Mpich knows which ADIO backend to use, in general? (and more specifically how does ADIOI_GEN_ReadStridedColl knows that it has to use ADIOI_BGL_ReadContig?) Does it have something to do with the fact that for instance with PVFS2 when the kernel module is not used, the filename should be prefixed by pvfs2:// ? If I want to develop a new ADIO backend, how can I make it such that filenames prefixed with myfilesystem:// will use this backend? (Maybe there's a documentation for that somewhere?)
Sort of the way virtual functions are implemented in C. There is a struct of function pointers (ADIOI_Fns_struct); The ADIO_File structure (and others) has a pointer to it. Then there is a set of wrapper functions that tries to find the pointer to the ADIOI_Fns_struct based on the arguments passed to the function. For example, #define ADIOI_OpenColl(fd, rank, access_mode, error_code) \ (*(fd->fns->ADIOI_xxx_OpenColl))(fd, rank, access_mode, error_code) so, when calling ADIOI_OpenColl the ADIOI_Fns_struct gets located through the fd argument (identifying the file), and then the macro calls the specific function for this file. If openfile wans to call the independent open function (or any other ADIOI_Fns_struct function), the same will happen. Dries
participants (1)
Dries Kimpe
