Re: [mpich-discuss] Extent of support for MPI_T_... interface?
OK that's working now. I see 10 performance variables. Are any more likely to become available as processes/comms are started? In particular what will happen if I run MPI_Comm_spawn to generate new processes? Thanks for the help thus far. On Mon, Jun 19, 2017 at 3:40 PM, Halim Amer <[email protected]> wrote:
Tracking performance variables incurs overhead, thus disabled by default. You can enable tracking pvars with --enable-mpit-pvars at configure time. Feel free to look at "configure --help" to get what pvars are tracked in the MPICH version you are using.
Halim www.mcs.anl.gov/~aamer
On 6/19/17 9:27 AM, Alexander Rast wrote:
I just ran a simple program to output the list of performance variables available at MPI initialisation. That it compiled and ran indicates that MPICH does at least support the interface, however it returned 0 variables available. Is this true - that MPICH supports the interface but exports no performance variables?
The other possible scenario I could envisage is that MPICH exports possibly many variables but these aren't available at initialisation time, rather they are dynamically exported as processes and communicators are created. However, if this is the case I don't understand the expected usage model. It's not clear how you could make use of this data without very awkward processing because the underlying datatypes are only exported as an MPI_Datatype opaque handle.
Does either of these 2 scenarios reflect the extent of MPI_T support?
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Alexander Rast
