Re: [mpich-discuss] Bug reporting for some mpi/rma tests
Hi, On 05/31/2016 09:31 AM, Clément Foyer wrote:
Hi everyone,
As I was using your tests I was surprised by some of them.
The first one is test/mpi/rma/get_acc_local.c, as you accumulate NITER times acc_val into out_val, initialized at 0. At each step of the loop you check whether the out_val is equal to i times acc_val. As i start from 0, you expect the result to be 0 instead of acc_val. I suppose you should have had i start from 1, or change the test line 36 to "if (out_val != acc_val * (i + 1)) {", with an adaptation of the debug message as well.
This test looks correct to me. Consider the values of the first few interations. Iteration 0 before Get_accumulate: i = 0, counter = 0, acc_val = 3, out_val = N/A; Iteration 0 after Get_accumulate: i = 0, counter = 3, acc_val = 3, out_val = 0 == (acc_val * i); Iteration 1 before Get_accumulate: i = 1, counter = 3, acc_val = 3, out_val = 0; Iteration 1 after Get_accumulate: i = 1, counter = 6, acc_val = 3, out_val = 3 == (acc_val * i); And so on...
The second test in which I found errors is mpi/rma/selfrma.c. The parameters given to the printf function at lines 66, 80 and 95 are in the wrong order. It should be "j, winbuf[j], sbuf[j]" instead of "winbuf[j], j, sbuf[j]". And at the line 95, the header to the debug line is "AccVec", as it seems it should have been "GetVec".
Yes, this looks like a bug. We will commit a fix soon. Thanks for reporting. Ken _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Kenneth Raffenetti
