Good Day All, We’re trying to get a build of 3.2 for our centos7 hpc environment using IB. we don’t have mxm installed so I’m trying this: ./configure --prefix=/software/tools/apps/mpich/gnu/3.2 --with-pm=hydra -with-device=ch3:nemesis --with-ibverbs=/usr --with-pbs=/opt/torque But we end up with backtraces of the form: mpi_script_launcher.run:17440 terminated with signal 7 at PC=7f8caca067f4 SP=7fff7c4ffb20. Backtrace: mpi_script_launcher.run:17441 terminated with signal 7 at PC=7fece77297f4 SP=7ffd3b5ff100. Backtrace: /software/tools/apps/mpich/gnu/3.2/lib/libmpi.so.12(MPID_nem_init+0x964)[0x7f8caca067f4] /software/tools/apps/mpich/gnu/3.2/lib/libmpi.so.12(MPID_nem_init+0x964)[0x7fece77297f4] /software/tools/apps/mpich/gnu/3.2/lib/libmpi.so.12(MPIDI_CH3_Init+0x29)[0x7f8cac9f7609] /software/tools/apps/mpich/gnu/3.2/lib/libmpi.so.12(MPIDI_CH3_Init+0x29)[0x7fece771a609] /software/tools/apps/mpich/gnu/3.2/lib/libmpi.so.12(MPID_Init+0x18b)[0x7f8cac9ececb] /software/tools/apps/mpich/gnu/3.2/lib/libmpi.so.12(MPID_Init+0x18b)[0x7fece770fecb] /software/tools/apps/mpich/gnu/3.2/lib/libmpi.so.12(MPIR_Init_thread+0x34c)[0x7f8cac95345c] /software/tools/apps/mpich/gnu/3.2/lib/libmpi.so.12(MPIR_Init_thread+0x34c)[0x7fece767645c] /software/tools/apps/mpich/gnu/3.2/lib/libmpi.so.12(MPI_Init+0x7e)[0x7f8cac952ede] /home/m8a/mpi_script_launcher/mpi_script_launcher.run[0x4008d0] /software/tools/apps/mpich/gnu/3.2/lib/libmpi.so.12(MPI_Init+0x7e)[0x7fece7675ede] /home/m8a/mpi_script_launcher/mpi_script_launcher.run[0x4008d0] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f8cac4fcb15] /home/m8a/mpi_script_launcher/mpi_script_launcher.run[0x4007c9] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7fece721fb15] /home/m8a/mpi_script_launcher/mpi_script_launcher.run[0x4007c9] Similarly with mvapich we get failures of this form: mpirun -n 4 /home/m8a/mpi_script_launcher/MVAPICH/mpi_script_launcher.run /home/m8a/mpi_script_launcher/mpi_bash_script_example.sh [cli_0]: aborting job: Fatal error in MPI_Init: Other MPI error, error stack: MPIR_Init_thread(514)..........: MPID_Init(365).................: channel initialization failed MPIDI_CH3_Init(495)............: MPIDI_CH3I_SHMEM_Helper_fn(921): write: Success =================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 17901 RUNNING AT mod-condo-login02.ornl.gov = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES =================================================================================== I suspect we are doing something silly here but I’m not sure what, and openmpi code on the same cluster runs fine. Is there a current recommendation for IB/pbs/torque build flags? — michael _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Galloway, Michael D.
