Re: [mpich-discuss] MPI_Comm_split and end with Finalize
Hi Lena, On Mon, Feb 29, 2016 at 7:04 PM, Oden, Lena <[email protected]> wrote:
A few more points from my side to MPI_Comm_disconnect
1.) MPI_Comm_disconnect should be called from all processes in the communicator, it is a collective operation 2.) You have to disconnect/ all communicators your server is connected to.
Insofar as I understand your problem: If you have connected multiple clients and the server into one intra-communicator, you first should call com-split to get a communicator without the server.
However, you still have to disconnect the old communicator (on all processes) - called "intra comm” in your example.
Besides, you also should disconnect all inter-communicator(s) created with MPI_Comm_connect and MPI_Comm_accept.
Lena
Thank you so much for this input. With those changes, it works now and the server process terminates at the Finalize call. I had been calling Disconnect only on the intra-communicators earlier. Calling it on the inter-communicators and doing the same thing on the client, did the trick :). Very useful and interesting. Thanks again. Regards, K.N.Ramachandran _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
K. N. Ramachandran
