Re: [mpich-discuss] Help troubleshooting a session
Hi Mark, That's not enough information for us to determine if your code is doing something inappropriate or if you're hitting a bug in MPICH. Usually we request reporters to submit the smallest piece of code with which that they can reproduce the problem. From your description, though, I'd say you could have something wrong on your code, so I'd suggest first asking for assistance in some place like stackoverflow to discard this before you file a possible bug to us. Thanks, Antonio On 06/30/2014 06:56 AM, mark wrote:
Στις 30/06/2014 01:09 μμ, ο/η mark έγραψε:
Hello. I wrote a program in MPI and for some combinations of data and number of nodes it runs ok, but other times it fails to run and returns errors (i.e. rank 0 in job 29 Calliope_50394 caused collective abort of all ranks exit status of rank 0: killed by signal 9). How i see it, for some reason, the division of data into the nodes keeps failing the execution. Because if i use 16 nodes and use for example a 320-line array as data collection, it executes fine. But if i use a 50-line array it fails the execution. Is there a way to troubleshoot the code and find where it fails? Also some examples would be great.
PS. Because i have wrote other programs in MPI that worked, the only difference they have with this one, that keeps failing, is that in this one i use loops like this:
for(i=id*(n/p); i< (id+1)*n/p; i++){.....
to parse the data accordingly, but again for some combinations of data and number of nodes it worked... Sorry for double posting.
discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Antonio J. Peña Postdoctoral Appointee Mathematics and Computer Science Division Argonne National Laboratory 9700 South Cass Avenue, Bldg. 240, Of. 3148 Argonne, IL 60439-4847 [email protected] www.mcs.anl.gov/~apenya
participants (1)
"Antonio J. Peña"
