Re: [mpich-discuss] MPICH 3.2.1 build error with icc+ifort: undefined reference to `_Static_assert'
You can also just #define HAVE_C11__STATIC_ASSERT 0 in the aforementioned header file to override the bad preprocessor test. On Wed, Jun 13, 2018 at 4:36 PM, Jeff Hammond <[email protected]> wrote:
Why don't you just use a newer ICC? September 28, 2012 was a long time ago...
Jeff
On Wed, Jun 13, 2018 at 4:32 PM, Gus Correa <[email protected]> wrote:
Thank you Jeff and Min!
Would you know if MPICH 3.2 has the same issue? I would rather use an older version instead, as long as it builds.
Many thanks, Gus Correa
On 06/13/2018 06:34 PM, Min Si wrote:
I was just creating the issue on MPICH github when Jeff replied.
Please use this issue to keep track: https://github.com/pmodels/mpich/issues/3178
Min On 2018/06/13 15:19, Jeff Hammond wrote:
_Static_assert comes from C11.
src/include/mpir_assert.h does a direct test for C11 support based upon the GCC version, which is unsafe since ICC (and other non-GCC compilers) define these macros.
/* GCC 4.6 added support for _Static_assert: * http://gcc.gnu.org/gcc-4.6/changes.html */ #if (__GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 6)) && !defined __cplusplus #define HAVE_C11__STATIC_ASSERT 1 #endif
MPICH needs to test for _Static_assert properly using configure. You should file a GitHub issue to track this.
Jeff
On Wed, Jun 13, 2018 at 2:33 PM, Gus Correa <[email protected] <mailto:[email protected]>> wrote:
Hi MPICH experts
I am trying to build MPICH 3.2.1 with Intel compilers (icc, ifort). C++ is disabled.
The configuration step goes well, but make fails, after a lot of stuff is compiled, with the error below (undefined reference to `_Static_assert').
FYI, the OS is Linux Fedora Core 26:
Linux 4.15.17-200.fc26.x86_64 #1 SMP Thu Apr 12 18:28:26 UTC 2018 x86_64 x86_64 GNU/Linux
The Intel compiler version is 12.1.6: ifort (IFORT) 12.1.6 20120928 icc (ICC) 12.1.6 20120928
The Intel compiler environment is set the standard way recommended by Intel:
source /path/to/intel/bin/compilervars.sh intel64
Any help is appreciated. Gus Correa
****** make errror message ************************************* make[2]: Entering directory '/home/sw/mpich/inst/3.2.1/mpich-3.2.1/build_intel-2011.13.367' CCLD src/env/mpivars lib/.libs/libmpi.a(lib_libmpi_la-ch3_progress.o): In function `MPIDI_CH3I_Shm_send_progress': ../src/mpid/ch3/channels/nemesis/src/ch3_progress.c:(.text+0x1ea2): undefined reference to `_Static_assert' lib/.libs/libmpi.a(lib_libmpi_la-ch3i_eagernoncontig.o): In function `MPIDI_CH3I_SendNoncontig': ../src/mpid/ch3/channels/nemesis/src/ch3i_eagernoncontig.c:( .text+0x1d3): undefined reference to `_Static_assert' make[2]: *** [Makefile:19701: src/env/mpivars] Error 1 make[2]: Leaving directory '/home/sw/mpich/inst/3.2.1/mpich-3.2.1/build_intel-2011.13.367' make[1]: *** [Makefile:38608: all-recursive] Error 1 make[1]: Leaving directory '/home/sw/mpich/inst/3.2.1/mpich-3.2.1/build_intel-2011.13.367' make: *** [Makefile:10337: all] Error 2 *******************************************************************
_______________________________________________ discuss mailing list [email protected] <mailto:[email protected]> To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss <https://lists.mpich.org/mailman/listinfo/discuss>
-- Jeff Hammond [email protected] <mailto:[email protected]> http://jeffhammond.github.io/
_______________________________________________ discuss mailing [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Jeff Hammond
