Re: [mpich-discuss] MPI static library link problem.
Hi Yanfei , It works. Thank you very much. I should review my compile / link flags. Regards, Anatoly. On Wed, Jan 4, 2017 at 10:38 PM, Guo, Yanfei <[email protected]> wrote:
Hi Anatoly,
I tried you example and cannot reproduce the problem. I saw your compile and link command has many options that are redundant. mpicxx will give the essential options for compile and link with MPICH (see `mpicxx –show`).
Can you try compile and link it with simple options (like the following commands)?
mpicxx –o mpi_hello_world.o –c mpi_hello_world.cpp mpicxx –o mpi_hello_world mpi_hello_world.o
Yanfei Guo Postdoctoral Researcher MCS Division, ANL
On 1/4/17, 2:12 AM, "Anatoly G" <[email protected]> wrote:
Hi Yanfei ,
Test file attached.
compile command: /mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/bin/mpicxx -c -ftemplate-depth-200 -Wall -Wno-reorder -Wno-comment -Wno-unknown-pragmas -Wno-unused -Wno-non-virtual-dtor -W -fPIC -g -O2 -I/mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/include -o ./mpi_hello_world.o ./mpi_hello_world.cpp -MMD
link command: /mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/bin/mpicxx -L/usr/lib/x86_64-linux-gnu/ -L/usr/lib/ -Wl,-rpath=/usr/lib -lcurses -lnsl -lpthread -ldl -lrt -rdynamic -o ./mpi_hello_world ./mpi_hello_world.o -L/usr/lib/x86_64-linux-gnu/ -lpthread
mpich-3.1 compile and link pass without any warning or errors.
mpich-3.2
* Program pass compile and link.
* if you will remove comment from line with MPI_Recv, link will fail.
Please advice, Anatoly.
On Tue, Jan 3, 2017 at 8:22 PM, Guo, Yanfei <[email protected]> wrote:
Hi Anatoly,
It looks like a linking order problem at the first glance. How did you compile and link using the static library?
On 1/3/17, 8:20 AM, "Anatoly G" <[email protected]> wrote:
Dear MPICH,
I use MPICH 3.2 configured (without shared libraries): ./configure --prefix=/mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04 --enable-error-checking=runtime --enable-g=dbg CFLAGS=-fPIC CXXFLAGS=-fPIC FFLAGS=-fpic --enable-threads=runtime --enable-totalview --enable-shared=no --disable-fortran
When I try to compile my program I get linkage errors: /mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/lib/libmpicxx.a(initcxx.o): In function `MPI::File::Create_errhandler(void (*)(MPI::File&, int*, ...))': /mpis/Mpich-3.2/mpich_3.2_config/mpich-3.2/src/binding/cxx/initcxx.cxx:693: undefined reference to `MPIR_Errhandler_set_cxx' /mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/lib/libmpicxx.a(initcxx.o): In function `MPI::Comm::Create_errhandler(void (*)(MPI::Comm&, int*, ...))': /mpis/Mpich-3.2/mpich_3.2_config/mpich-3.2/src/binding/cxx/initcxx.cxx:704: undefined reference to `MPIR_Errhandler_set_cxx' /mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/lib/libmpicxx.a(initcxx.o): In function `MPI::Win::Create_errhandler(void (*)(MPI::Win&, int*, ...))': /mpis/Mpich-3.2/mpich_3.2_config/mpich-3.2/src/binding/cxx/initcxx.cxx:714: undefined reference to `MPIR_Errhandler_set_cxx' /mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/lib/libmpicxx.a(initcxx.o): In function `MPI::Comm::Create_keyval(int (*)(MPI::Comm const&, int, void*, void*, void*, bool&), int (*)(MPI::Comm&, int, void*, void*), void*)': /mpis/Mpich-3.2/mpich_3.2_config/mpich-3.2/src/binding/cxx/initcxx.cxx:510: undefined reference to `MPIR_Keyval_set_proxy' /mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/lib/libmpicxx.a(initcxx.o): In function `MPI::Datatype::Create_keyval(int (*)(MPI::Datatype const&, int, void*, void*, void*, bool&), int (*)(MPI::Datatype&, int, void*, void*), void*)': /mpis/Mpich-3.2/mpich_3.2_config/mpich-3.2/src/binding/cxx/initcxx.cxx:574: undefined reference to `MPIR_Keyval_set_proxy' /mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/lib/libmpicxx.a(initcxx.o): In function `MPI::Win::Create_keyval(int (*)(MPI::Win const&, int, void*, void*, void*, bool&), int (*)(MPI::Win&, int, void*, void*), void*)': /mpis/Mpich-3.2/mpich_3.2_config/mpich-3.2/src/binding/cxx/initcxx.cxx:638: undefined reference to `MPIR_Keyval_set_proxy' /mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/lib/libmpicxx.a(initcxx.o): In function `MPI::Op::Init(void (*)(void const*, void*, int, MPI::Datatype const&), bool)': /mpis/Mpich-3.2/mpich_3.2_config/mpich-3.2/src/binding/cxx/initcxx.cxx:393: undefined reference to `MPIR_Op_set_cxx' /mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04/lib/libmpicxx.a(initcxx.o): In function `MPI::Comm::Reduce_scatter_block(void const*, void*, int, MPI::Datatype const&, MPI::Op const&) const': /mpis/Mpich-3.2/mpich_3.2_config/mpich-3.2/./src/binding/cxx/mpicxx.h:1490: undefined reference to `MPI_Reduce_scatter_block' collect2: error: ld returned 1 exit status
When I configure MPI with shared libraries: ./configure --prefix=/mpis/Mpich-3.2/mpich-3.2/Ubuntu14.04 --enable-error-checking=runtime --enable-g=dbg CFLAGS=-fPIC CXXFLAGS=-fPIC FFLAGS=-fpic --enable-threads=runtime --enable-totalview --disable-fortran
my program's build completed correctly.
When I used MPICH 3.1 I didn't see these problems. Can you please advice?
Regards, Anatoly.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Anatoly G
