Re: [mpich-discuss] Issue in MPI_Win_get_attr(MPI_WIN_SIZE)
On Mon, Feb 9, 2015 at 12:29 PM, Hajime Fujita <[email protected]> wrote:
Hello,
I think I found an issue in MPI_Win_get_attr, when MPI_WIN_SIZE is specified. It is supposed to return the size of the window, but it seems to give a random number.
Just wanted to confirm one thing: I think MPI_Win_get_attr is supposed to return a value of type MPI_Aint, when MPI_WIN_SIZE is specified. Is it correct?
No. According to p415 of MPI-3.0 spec, in C bindings, MPI_Win_get_attr(..., MPI_WIN_SIZE, &size, ...) return in size "pointer" to the size of the window. In Fortran bindings, it returns a value instead.
Test program: See the attached file
Result I got: hfujita@lssg-lp-00:~/work/mpi_win_size_test$ ./win_size_test Got size=140729394560728, while expecting 1024 hfujita@lssg-lp-00:~/work/mpi_win_size_test$ ./win_size_test Got size=139994694213336, while expecting 1024 hfujita@lssg-lp-00:~/work/mpi_win_size_test$ ./win_size_test Got size=139739628887768, while expecting 1024 hfujita@lssg-lp-00:~/work/mpi_win_size_test$ ./win_size_test Got size=140131810524888, while expecting 1024 hfujita@lssg-lp-00:~/work/mpi_win_size_test$ ./win_size_test Got size=139859819581144, while expecting 1024
Expected result: If the MPI library works as I expected, the test program won’t show any message.
MPICH version and configuration: $ mpichversion MPICH Version: 3.2a2 MPICH Release date: unreleased development copy MPICH Device: ch3:nemesis MPICH configure: CC=gcc CXX=g++ FC=gfortran F77=gfortran CFLAGS=-O0 --prefix=/home/hfujita/opt/mpich-3.2 --disable-mpe --disable-romio --enable-g=all --enable-spawn --enable-maintainer-mode --enable-error-checking=all --with-pm=hydra --with-pmi=simple --disable-cxx --enable-fortran --enable-strict=noopt --disable-fast --disable-perftest --no-create --no-recursion MPICH CC: gcc -O0 -Wall -Wextra -Wno-missing-field-initializers -Wmissing-prototypes -DGCC_WALL -Wno-unused-parameter -Wno-unused-label -Wshadow -Wmissing-declarations -Wno-long-long -Wundef -Wno-endif-labels -Wpointer-arith -Wbad-function-cast -Wwrite-strings -Wno-sign-compare -Wno-multichar -Wno-deprecated-declarations -Wpacked -Wnested-externs -Winvalid-pch -Wno-pointer-sign -Wvariadic-macros -Wno-format-zero-length -Wtype-limits -Werror-implicit-function-declaration -D_POSIX_C_SOURCE=200112L -std=c99 -D_STDC_C99= -g -O0 MPICH CXX: no -g MPICH F77: gfortran -g -O0 MPICH FC: gfortran -g -O0
Git revision info: I got the MPI source from git (http://git.mpich.org/mpich.git master) and the id is 7dfe2840
Platform: Ubuntu 12.04 amd64
Thanks, Hajime
-- Hajime Fujita Postdoctoral Scholar, Large-Scale Systems Group Department of Computer Science, The University of Chicago http://www.cs.uchicago.edu/people/hfujita
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Junchao Zhang
