Re: [mpich-discuss] Increasing MPI ranks
Thank you both for your time. I respond to each question below: Huiwei Lu, the outputs from the two commands are below: [jlarson@mintthinkpad test]$ mpiexec --version HYDRA build details: Version: 3.1 Release Date: Thu Feb 20 11:41:13 CST 2014 CC: gcc CXX: g++ F77: gfortran F90: gfortran Configure options: '--disable-option-checking' '--prefix=/home/jlarson/software/mpich-install' '--cache-file=/dev/null' '--srcdir=.' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread ' 'CPPFLAGS= -I/home/jlarson/software/mpich-3.1/src/mpl/include -I/home/jlarson/software/mpich-3.1/src/mpl/include -I/home/jlarson/software/mpich-3.1/src/openpa/src -I/home/jlarson/software/mpich-3.1/src/openpa/src -I/home/jlarson/software/mpich-3.1/src/mpi/romio/include' Process Manager: pmi Launchers available: ssh rsh fork slurm ll lsf sge manual persist Topology libraries available: hwloc Resource management kernels available: user slurm ll lsf sge pbs cobalt Checkpointing libraries available: blcr Demux engines available: poll select [jlarson@mintthinkpad test]$ mpicc -v mpicc for MPICH version 3.1 Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/4.6/lto-wrapper Target: x86_64-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.6.3-1ubuntu5' --with-bugurl=file:///usr/share/doc/gcc-4.6/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.6 --enable-shared --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.6 --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-gnu-unique-object --enable-plugin --enable-objc-gc --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu Thread model: posix gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) Jed Brown, I don't know how else to have the function communicate with the worker that spawned it. If I replace the lines: ---- comm_to_function_wrapper = MPI.Comm.Get_parent() rank = comm_to_function_wrapper.Get_rank() ---- with: ---- comm_to_function_wrapper = MPI.COMM_WORLD.Get_parent() rank = comm_to_function_wrapper.Get_rank() ---- then I still get valid output for 3 ranks, but not 30. Is there a valid way for a spawned task to communicate with the worker that spawned it? I was using the example from the mpi4py manual: http://mpi4py.scipy.org/docs/mpi4py.pdf (See the lines directly below "Worker (or child, or server) side:" in Section 4.3: Dynamic Process Management) Thank you again! Jeff On Tue, Mar 11, 2014 at 5:52 PM, Jed Brown <[email protected]> wrote:
Jeffrey Larson <[email protected]> writes:
Thank you for your response. Attached are the script and the simple function that it calls.
The command: $ mpiexec -n 3 python script.py works great, but 30 crashes.
I don't think this is valid:
| comm_to_function_wrapper = MPI.Comm.Get_parent() | rank = comm_to_function_wrapper.Get_rank()
$ make intercomm CC=/opt/mpich/bin/mpicc && /opt/mpich/bin/mpiexec -n 2 ./intercomm /opt/mpich/bin/mpicc intercomm.c -o intercomm Fatal error in PMPI_Comm_rank: Invalid communicator, error stack: PMPI_Comm_rank(108): MPI_Comm_rank(MPI_COMM_NULL, rank=0x7fff9fe6a118) failed PMPI_Comm_rank(66).: Null communicator Fatal error in PMPI_Comm_rank: Invalid communicator, error stack: PMPI_Comm_rank(108): MPI_Comm_rank(MPI_COMM_NULL, rank=0x7fff5e484d48) failed PMPI_Comm_rank(66).: Null communicator
=================================================================================== = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = PID 8474 RUNNING AT batura = EXIT CODE: 1 = CLEANING UP REMAINING PROCESSES = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
=================================================================================== $ /opt/mpich/bin/mpichversion MPICH Version: 3.1 MPICH Release date: Thu Feb 20 11:41:13 CST 2014 MPICH Device: ch3:nemesis MPICH configure: --prefix=/opt/mpich --enable-shared --enable-sharedlibs=gcc --enable-error-checking=runtime --enable-error-messages=all --enable-timer-type=clock_gettime --with-python=python2 MPICH CC: gcc -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -O2 MPICH CXX: g++ -march=x86-64 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 MPICH F77: gfortran -O2 MPICH FC: gfortran
participants (1)
Jeffrey Larson
